Dies on throttle release - JeepForum.com
post #1 of 13 Old 06-09-2013, 02:04 PM Thread Starter
pete99
1994 ZJ
I recently replaced spark plugs, spark plug wires, rotor and cap, and installed new Accel Ignition Coil. It purrs like a kitten (technical description, idles nice and smooooth). When I blip the throttle it's fine, RPM increases good, but when I let go of the throttle, it stumbles really bad and almost dies. The idle manifold vacuum is 20 InHg at around 800 RPM. The only DTC is 55 as I disconnected the battery, no other codes. I am the original owner and only have 30,000 miles on it. Thanks for any suggestions!
pete99 is offline
post #2 of 13 Old 06-09-2013, 02:29 PM
vonericsen
If you disconnected the battery for longer than 20 minutes it's probably relearning the idle. Once it's done it should stop stumbling.
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #3 of 13 Old 06-09-2013, 02:56 PM
zj97ltd
If your battery is on its way out or connections are loose it can cause this too.
zj97ltd is offline
post #4 of 13 Old 06-09-2013, 03:46 PM
JasonStebbins
Original owner with 30,000 miles?!
Does it only do this when idling or when you are driving as well? Has it ever actually stalled?
Does it accelerate fine?
Check and make sure all the grounds are are clean and tight.
Poop
JasonStebbins is offline
post #5 of 13 Old 06-09-2013, 04:26 PM Thread Starter
pete99
1994 ZJ
Sorry, newbie here.
Yes, I know, only 30k miles. My work was only 4 miles away, so over 18 years or so, not much mileage. Trips to Moab, Tahoe, etc didn't add much.<g>
Idles and accels nicely. Just stumbles on throttle release. Engine died once, usually RPM drops to near zero then recovers. This is all inside garage. I drove it around block and it drives very good, accel and decel. Just don't know if I can trust it not to stall when slowing for light or stop sign, or have to get off throttle for some reason out on the road. Checked TPS, manifold Temp, and MAP sensors, all okay. Bought a Fuel Pressure gage and the fuel pressure read correctly. Battery has been maintained with charge maintainer and is in good shape. Vacuum is steady at idle (20 InhG). CORRECTION- The only error code on the CEL is 12 for battery disconnect, not 55. Thanks for any ideas....
pete99 is offline
post #6 of 13 Old 06-09-2013, 04:54 PM
JasonStebbins
Hmm, you've checked a lot of things I would have suggested.
Have you checked all the grounds already?
Poop
post #7 of 13 Old 06-09-2013, 06:11 PM
ZeeJay1997
I nominate the IAC... clean it up and see how it does.
ZeeJay1997 is offline
post #8 of 13 Old 06-09-2013, 06:11 PM
dusterdude
Clean iac and you may need a crank sensor
dusterdude is offline
post #9 of 13 Old 06-09-2013, 06:15 PM
HurricaneRZA
x2
When I swapped my throttle body the IAC was acting up and I ended up having to idle manually until I cleaned and put back the original IAC
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #10 of 13 Old 06-09-2013, 10:17 PM
jnicewan
I bet this is it too, clean it and see what happens, also clean out the passage the IAC plunger goes into along with the throttle plate and bore. If you are picky about keeping parts replaced then buy a new one after you discover it was dirty or bad.
jnicewan is offline
post #11 of 13 Old 06-09-2013, 10:55 PM
kachink
x2
Remove the throttle body and clean it throughly. If you remove it you can clean the entire IAC passage all the way through.
kachink is offline
post #12 of 13 Old 06-09-2013, 11:10 PM
dnuccio
Originally Posted by kachink View Post
x2
this^
mine ran so much better after i cleaned the TB
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #13 of 13 Old 06-30-2013, 02:08 PM Thread Starter
pete99
1994 ZJ
I removed and cleaned the TB and sensors. That seems to have fixed it! Thanks so much to all that provided input.
pete99 is offline
