Died While driving - JeepForum.com
post #1 of 29 Old 02-15-2010, 09:18 AM Thread Starter
tuckdog74
Died While driving
I have looked through some other topics and have not found an answer to my issue. So sorry if i missed something. 1995 grand cherokee AWD limited. I was diving on the highway then the jeep just died no spit or sputter. got it towed home and checked the timming, it is good. checked all the fuses and relays all are good. my alarm system has been disabled and will not reset. so i checked for spark. none...i put on a new coil still no spark. all she does is crank. fuel pump just replaced 1 yr go. i read some where about a crankshft ot cam shaft positon sensor. do these allow the coil to get spark? i also checked on the wires comming to the coil from the loom no power. Thanks for all your help in advace.
J.
tuckdog74 is offline
post #2 of 29 Old 02-15-2010, 09:28 AM
ZeeJay1997
Sounds like ECM is not working. Do you have gauges?
The engine is timed by the ECM, and cam and crankshaft sensors
The CrankPositionSensor can short the ECM and cause it not to work. Usually when this happens, the gauges do not work. If this is the case, disconnect the CPS and see if you get gauges.
If disconnecting the CPS does not change the state of the gauges, suspect power to ECM. This would be a good time to be sure all the main charging system wiring is corrosion free.
If power to ECM is good, suspect ECM.
ZeeJay1997 is offline
post #3 of 29 Old 02-15-2010, 10:14 AM
BlackDaddyZJ
1994 ZJ
This same thing happened to me a while back and it ended up being that the factory coil had finally given out just replaced it with a BWD one from advance auto
Bob
'94 ZJ
5.2L
IRO 4.5" Lift
35x12.5 Mickey Thompson Baja MTZ's
98 5.9
Restored and daily driven
BlackDaddyZJ is offline
post #4 of 29 Old 02-15-2010, 10:26 AM
terryj
2015 WK
Check the CPS first, it will save you allot of time, sound like it has failed.
terryj is offline
post #5 of 29 Old 02-15-2010, 10:32 AM Thread Starter
tuckdog74
Ecm is new as well as the alten and all connections where cleaned at that time. a month ago. does the crankshaft and cam shaft sensor both tell the coil to get power? which one should i check first? one is 56 and one is 28.00. what are the gauges supposed to do when i turn the key one, since you say check gauges. just look at the fuel gauge to see if it goes up?
post #6 of 29 Old 02-15-2010, 10:47 AM
BlackDaddyZJ
1994 ZJ
you cant really say its one exact part if he says his heep died it could almost literally be anything. checking the coil with a circuit tester literally takes about 30 seconds, but id say check everything you can.
Bob
'94 ZJ
5.2L
IRO 4.5" Lift
98 5.9
post #7 of 29 Old 02-15-2010, 11:38 AM
ZeeJay1997
Battery, fuel, CEL for 3 seconds.
post #8 of 29 Old 02-15-2010, 02:20 PM Thread Starter
tuckdog74
turned the key on and the amp, oil raise just a little. fuel is stuck on full, i had just filled it up the morning i was driving it. but drove about70 miles before it quit.
post #9 of 29 Old 02-15-2010, 02:24 PM
ZeeJay1997
Does the CEL come on for 3 seconds, then go out?
post #10 of 29 Old 02-15-2010, 02:29 PM Thread Starter
tuckdog74
sorry if i sound dumb but what is CEL?
post #11 of 29 Old 02-15-2010, 02:32 PM
bigbill888
check engine light
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #12 of 29 Old 02-15-2010, 02:33 PM
kingvm
kingvm's Avatar
2005 WK
Did you check the fuses in the box under the hood.
When mine had the same problem as yours there was a fuse under the hood blowing that controlled the ASD relay which stops power to the coil and other things.
The fuse was blowing because the 02 sensor wire had dropped down onto the driveshaft and was shorting out causing the fuse to blow.
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline
post #13 of 29 Old 02-15-2010, 02:34 PM Thread Starter
tuckdog74
no it does not...what does that mean?
post #14 of 29 Old 02-15-2010, 02:34 PM
ZJ5point2GCL
have you tried the ASD relay?
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #15 of 29 Old 02-15-2010, 02:34 PM Thread Starter
tuckdog74
all fuses good.
yes switched out for another that is good and still nothin
grand cherokee , jeep zj , no spark , no start
Driving On Icy Roads Type Of Driving kopite77 ZJ Grand Cherokee Forum 22 01-06-2010 03:03 PM
Help ZJ just died while driving SouthZJ ZJ Grand Cherokee Forum 12 06-06-2009 07:55 AM
95 ZJ V8 died while driving jheck74 ZJ Grand Cherokee Forum 0 07-11-2008 06:27 PM
it just died????? rustycherokee18 ZJ Grand Cherokee Forum 7 02-04-2007 06:36 AM
zj died! papashango ZJ Grand Cherokee Forum 21 01-07-2005 04:18 PM
