did the gas tank lift today.. - JeepForum.com
post #1 of 16 Old 04-07-2009, 11:13 PM Thread Starter
dmolaver15
1st off, pics will be up when i wake up in 2-3 days
2nd.. Don't attempt this project without atleast 1 or 2 somewhat knowledgeable friends, and give yourself atleast a day to complete it.
that being said, it was well worth it. i kind of went my own way for sealing up the spare tire well and running the filler lines, etc, but it came out really clean
i drilled a 3 inch hole in the unibody and sent the filler and the other small line that goes with it through that, and capped the hole with a 3" peice of exhaust pipe.
I cut the stock gas tank skid and used the brackets already on it just by welding them back on the skid, like Agitatedpancake did in his wj
and for capping off the old spare tire well, i cut out the bottom of the well, made several vertical cuts down it about 1-2" deep, and then bent it out and welded it back in place, that way the tank could be nice and tucked up against it like in stock form
overall i gained an estimated 6-8" of clearance from what it used to be
my hitch and the evap. box thing are now the lowest hanging things in the rear end.
overall i'd say the project was well worth it, and i deffinately recommend doing this for anyone who wheels their wj anywhere near rocks
04 WJ 4.0
6.5" IRO Front and Rear Longarms
Soft 8's, 285/75/16 BFG Mall Terrains
Super 44 with 3" Side Dump
Dana 44a, 4.56's
My Build Thread:
dmolaver15 is offline
post #2 of 16 Old 04-08-2009, 08:13 AM
spife7980
Pics!!!!!! surely you know this...
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #3 of 16 Old 04-08-2009, 08:35 AM
perfectcircle
you stayed up til 1 in the morning and you're whinning about being tired? hahaha drag your *** outside and take some pictures!
perfectcircle is offline
post #4 of 16 Old 04-08-2009, 08:43 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Were you always landing on the skid or something??
The thing I hit most on the rocks is the thing that holds the hitch wiring harness in place.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #5 of 16 Old 04-08-2009, 08:45 AM
DothanJeep
PICSSS..........
00' WJ 4'' IRO 285 Tire...Ect-SOLD 7/2/2009
98' ZJ STORM TROOPIN' SOLD
97' ZJ with 117K THE DD mi SOLD
01'WJ Project Cheap fix.
DothanJeep is offline
post #6 of 16 Old 04-08-2009, 08:51 AM
coupleofjeeps
you've gotta be awake by now...
coupleofjeeps is offline
post #7 of 16 Old 04-08-2009, 10:56 AM
AgitatedPancake
I had landed on my tank so hard and so many times in the stock location that my 20.5 gallon tank ended up in the 17 gallon range. When i did my gas tank lift i also upgraded to the beefier skidplate as well
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #8 of 16 Old 04-08-2009, 11:08 AM Thread Starter
dmolaver15
ok, heres the pics
and yes, i did just wake up. 1:05
hole for filler neck and other hoses
brackets and edge of spare tire well cleaned up for welds
finished hole for filler neck and hoses
cover getting welded back in place (i did it this way so the tank could be tucked up right against it, just like in the stock location)
clearance without the tank
making sure everything still fits after the skid was welded up
my normally very clean garage after the project
clearance!
04 WJ 4.0
Dana 44a, 4.56's
My Build Thread:
post #9 of 16 Old 04-08-2009, 12:33 PM
doublejz
nice job, I plan on doing this eventually.
04 WJ with some stuff -
doublejz is offline
post #10 of 16 Old 04-08-2009, 01:07 PM
ZtotheJ
2008 WK
can some one tell me how the WJ rear upper wish bone works? Tank looks good man..
  • 2008 brilliant black SRT-8, 180 t-state k&n cai, predator, resonators removed, MHP CMR tune, eibach springs, fan mod, esp/abs mod, X-50 radar, elite catch can, debaged/rebadged, stubby antenna.
  • 1997 ZJ LIMTED 6.5 SOLD!
  • 09 APBRA JET PILOT FREESTYLE ATTENDEE.
  • ZtotheJ build
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
INAPPROPRIATE CONTENT KING!
ZtotheJ is offline
post #11 of 16 Old 04-08-2009, 01:16 PM Thread Starter
dmolaver15
instead of using a true 4-link setup, it's got an a-arm that meets ontop of the differential, and has a ball joint type thing connecting the 2 together
04 WJ 4.0
Dana 44a, 4.56's
My Build Thread:
post #12 of 16 Old 04-08-2009, 01:38 PM
zippome
looks awesome!
about the a-arm. installing that damn a-arm spacer was a pain in the ***. if my tank was lifted like that, it would have been much easier.
Im 20 with a 2000 Grand SOLD!
4" Zone Offroad Kit, 16x7 Cragar Soft 8's, 265/75/16 Maxxis Bighorns, Rock-It Sliders, Rancho SS, Yakima Load Warrior, Flowmaster Super 40, Reverse Lights, 2 Lights Up Front, Custom 6 Switch Plate, Cobra 76 XTR CB with PA, Lightbar, Custom Hitch Tire Carrier, Fleabay Warm Air Intake
zippome is offline
post #13 of 16 Old 04-08-2009, 01:44 PM
CrazyWalnut13
Originally Posted by zippome View Post
looks awesome!
That's what i was just thinking. I'll be replacing the a-arm ball joint next week, it would be so much simpler if my gas tank weren't in the way.
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #14 of 16 Old 04-08-2009, 01:51 PM
zippome
thats a good reason to do the tank lift NOW
zippome is offline
post #15 of 16 Old 04-08-2009, 01:56 PM
Shinobi
good **** ... I did pretty much the same thing you did but since I didn't know how to weld I just used some self threading screws .
but x2 on having a friend who knows a thing or two ... I couldn't have done it with out my buddy helping me
BTW when you put the filler Tube back in is your kinked ? mine is kinda kinked but fills up fine
hahha I see we both have the same taste in diff cover color
Shinobi is offline
WJ Gas Tank Lift. AgitatedPancake WJ Grand Cherokee Forum 15 09-25-2016 03:23 AM
WJ gas tank lift mod ( do i need to cut my exhaust) lakailimited06 ZJ Grand Cherokee Forum 8 11-17-2010 07:09 PM
Wj Gas Tank lift Clayton00grand ZJ Grand Cherokee Forum 2 12-04-2008 03:07 PM
Does the CRD have a lift pump in the tank? magellan WK Grand Cherokee & XK Commander Forum 2 10-01-2008 07:58 PM
Raised my fuel tank today Death-Mobile ZJ Grand Cherokee Forum 16 09-27-2006 08:22 PM
