Quantcast Did the 242 swap tonight and now - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Did the 242 swap tonight and now
Old 03-26-2009, 09:29 PM   #1
limited_pit
Did the swap and now after I changed the plugs behind the VIC it reads "FULL TIME" no matter what gear the case is in any Ideas why???
94 Ta A4 (my summer project)
97 ZJ TSi 5.2
B5 VW (wifes car)
limited_pit is offline   Reply With Quote
Old 03-26-2009, 09:34 PM   #2
Kruzin
Could be a bad switch on the tcase.
DD: 98 ZJ Laredo 5.2, all stock
Wheeler/Beater: 93 ZJ Laredo
4.0, AW4, 231 conversion from 249
3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard
Colorado Jeep Club Member 242 (4.0L)
Kruzin is offline   Reply With Quote
Old 03-26-2009, 09:55 PM   #3
StellaTheZJ
What happens if you disconnect the plugs? If there's no change, maybe one of your plugs wasn't in or a wire off it is bad...
StellaTheZJ is offline   Reply With Quote
Old 03-26-2009, 10:06 PM   #4
limited_pit
if I unplug the black wire or unplug the lead on the t-case??
Anyone have a 242 bezel lying around???
97 ZJ TSi 5.2
B5 VW (wifes car)
Old 03-27-2009, 08:28 AM   #5
limited_pit
Drove the dam thing this morning and my speedo doesn't work either
The case is from a 93 my heep is a 95 I had to switch the sending unit for the speedo to be able to plug it in but are there other differences that would make it not work?? I can't imagine that the sender went bad just from switching it
Help me please!!!
97 ZJ TSi 5.2
B5 VW (wifes car)
Old 03-27-2009, 08:32 AM   #6
j.love
1994 ZJ
got the gear in correct?
http://www.stu-offroad.com/engine/speedo/speed1.htm
David.
94 ZJ laredo 5.2 V8 soon to be 5.9!!
In Delaware, the largest growth of population is Indian Americans, moving from India. You cannot go to a 7/11 or a Dunkin’ Donuts unless you have a slight Indian accent. I’m not joking. Joe Biden
j.love is offline   Reply With Quote
Old 03-27-2009, 08:43 AM   #7
bigbluezj94
1994 ZJ
you speedo gear isnt in there properly.... just twist it like a half turn in either direction and that should do it. the gears just need to line up
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms
http://www.jeepforum.com/forum/f197/bigbluezj94-build-thread-679496/
BigBlue build 3/4 ton axles, LAs, 37s
http://www.jeepforum.com/forum/f197/3-4-ton-zj-build-818891/
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
bigbluezj94 is offline   Reply With Quote
Old 03-27-2009, 09:54 AM   #8
limited_pit
I will have to check that tonight but I do remember I had to turn the plug the opposite direction when I plugged it in but it felt like it meshed when it went in
Thanks
97 ZJ TSi 5.2
B5 VW (wifes car)
Old 03-27-2009, 10:16 AM   #9
FPKites
ZJjazzyJim
FPKites's Avatar
Take a look at the sensor body itself - it has numbers etched into it...those correspond to the tooth count on your speedo gear. Now, look at the TC tail cone. It has a little bump - align the appropriate number range with that little bump. Speedo should work.
Turning the plug the opposite direction doesn't sound very good
Jim Karlin
"Duh! Big RED Jeep!!!"
Best mod you'll ever do on ANY vehicle!!!!
FPKites is offline   Reply With Quote
Old 03-27-2009, 10:36 AM   #10
limited_pit
I'll check but wouldn't you guys think if it went all the way into the case it would have lined up
Just asking
97 ZJ TSi 5.2
B5 VW (wifes car)
Old 03-27-2009, 11:14 AM   #11
ratmonkey
Living dead mod
ratmonkey's Avatar
Just asking
the only reason it wouldn't go all the way into the case is if it was lined up for a smaller diameter gear than the one you have.
you have it lined up to a larger diameter gear than the one you have, so of course it will still go in and obviously not read anything.
ratmonkey is offline   Reply With Quote
Old 03-27-2009, 11:14 AM   #12
limited_pit
My sending unit should work with the gears in the new case right???
97 ZJ TSi 5.2
B5 VW (wifes car)
Old 03-27-2009, 11:20 AM   #13
limited_pit
being at work sucks cuz I'm going to think about this all dam day!!!!
97 ZJ TSi 5.2
B5 VW (wifes car)
Old 03-27-2009, 11:24 AM   #14
FPKites
ZJjazzyJim
FPKites's Avatar
The speedo gear actually just rides on a splined sleeve that runs on the output shaft. It's possible that you may have gotten a case that needs either the long or short speedo gear, but not very likely.
Jim Karlin
Old 03-27-2009, 12:32 PM   #15
limited_pit
Thanks for the help!
97 ZJ TSi 5.2
B5 VW (wifes car)
Glock Forum
