delay by a couple of seconds - JeepForum.com
post #1 of 11 Old 06-19-2013, 09:51 AM Thread Starter
cryptic3
This morning getting ready to go to work I started my jeep and it cranked but cranked a couple if seconds longer to get the car started... Could this be the starter going out?
cryptic3 is offline
post #2 of 11 Old 06-19-2013, 09:52 AM
WhiteOut
WhiteOut's Avatar
Good chance of it. Just be glad it's an easy 20 minute fix to swap a new one.
WhiteOut is offline
post #3 of 11 Old 06-19-2013, 10:07 AM
PolkaPower
Check the battery too. Also low pressure in the fuel line can cause long starts.
PolkaPower is offline
post #4 of 11 Old 06-19-2013, 10:08 AM
bigbill888
If the cranking sounded normal, it probably isn't the starter. Try cracking the throttle while cranking, see if that makes a difference. Might be Idle Air Control valve (IAC)
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #5 of 11 Old 06-19-2013, 10:41 AM
Martin600
I'd place my bets on low fuel pressure, if it still cranks as normal. Easy check for that is to cycle your ignition (switching it on and off) a few times before cranking from cold or first thing in the morning. if it fires right up that's likely to be the problem.
I just live with it
I'm new on this forum, but from what I've gathered the fuel pumps and regulators aren't great.
Martin600 is offline
post #6 of 11 Old 06-19-2013, 10:22 PM Thread Starter
cryptic3
OK so I tried throttling while cranking and it started right away and revved ..... I'm going to try the switching the ignition on and off a few times tomorrow morning and see if that does anything.... This all great information and tips guys thank you
cryptic3 is offline
post #7 of 11 Old 06-20-2013, 12:25 AM
PolkaPower
Might be a failing fuel pressure regulator.
post #8 of 11 Old 06-20-2013, 06:34 AM Thread Starter
cryptic3
OK tried switching the ignition on and off without crank like 4 times then when I cranked it didn't give me a delay...
cryptic3 is offline
post #9 of 11 Old 06-20-2013, 07:42 AM
dellis
2005 WK
bigbill888 is correct about the starter ... if it is cranking normally, but not turning over, then this is not your starter.
Everything at this point is indicating a fuel problem (clogged filter, failing pump, etc). Still, you should put a fuel pressure gauge on your rail and check the pressure (prior to starting, at idle, and while revving) and see behavior.
dellis is offline
post #10 of 11 Old 06-26-2013, 08:23 AM Thread Starter
cryptic3
So this morning when I was about to move my jeep from the driveway there it was .... My battery was dead it has been delaying since I first posted... So I guess it was the battery
cryptic3 is offline
post #11 of 11 Old 06-26-2013, 05:28 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Mine started the same thing, presently running a test in bigbills advice. Kinda pointing to the IAC.
Originally Posted by HighLonesome
coralman is offline
