Defrost not working, blowing out vents instead - JeepForum.com
post #1 of 9 Old 11-27-2006, 09:11 AM Thread Starter
mattadams
This is my first post, please be gentle . I wasn't able to use the search feature, I guess because it is broken.
My girlfriend has a 99 Jeep Grand Cherokee. This morning it got fairly cold, around 20 degrees, and the defrost wouldn't work at all. Even once the vehicle heated up it was just blowing cold air out the vents and nothing was coming out of defroster. I drove it to work since I only have to drive 5 miles to work, and had to pull over several times to scrape the windshield, even then it was still a pretty foggy drive.
I tried setting it to reciculate, a/c on just to see if that might get it back in its grind... its like it ignored most of anything I was doing on the controls... if it was off, it was off, but anything else just equaled cold air out the front vents. It doesn't have the slide-style heater selection thing so it sh ouldn't be anything with a cable or anything, it has the electronic, dual temperature zone setups.
A bit of history, it has worked pretty reliably up until now, though two summers we did have an issue with it where it was blowing out hot air even if we set it to a/c... any help before we take it to a shop? I'm super comfortable working on my Ford F-150 but this Grand CHerokee is a bit of an enigma to me.
mattadams is offline
post #2 of 9 Old 11-27-2006, 09:17 AM
Double E
Double E's Avatar
Let's see...
#1 Welcome on!! Glad you're here.
#2 Go here...wjjeeps.com and click this link or search for blend doors on that site http://www.wjjeeps.com/hvac_sub_assembly.htm
#3 Dress warm tomorrow.
#4 Save some $ or go after it yourself.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 9 Old 11-27-2006, 09:32 AM Thread Starter
mattadams
Thanks for the response! Any idea how much this type of job would run from a dealer?
post #4 of 9 Old 11-27-2006, 09:38 AM
Double E
Double E's Avatar
Nope. However, at about $75 an hour and 8 hours of labor (plus parts) you can get an idea.
You caould also probably call them. They'll be familiar with the work that needs to happen as about every "Limited" owner has had the issue and I'm guessing they've probably done 10 a month for the past year.
There are write ups and tricks that you can follow to save big money on this repair though. Google the terms and you'll find some. These threads, (going back a couple of months) will also make reference to a link describing a shortcut on going through (the removed) glove box with a Dremel tool and fixing it in 45 mins or so.
I sure love my Laredo right now....
Double E is offline
post #5 of 9 Old 11-27-2006, 09:48 AM
veso_Ht
i guess it's time to search for the short cut... wish the search worked... what's up with it?
veso_Ht is offline
post #6 of 9 Old 11-27-2006, 10:25 AM
Double E
Double E's Avatar
Here is one write up...
There is a shortcut to getting to these doors and seeing if they work. It's sort of the half A** way of doing thing but it will save you about 7 hours of labor and about $1200 in cost. Solution... open the glove box and with a screwdrive pry the glove box all the way down. You will see directly behing there the black housing to the blens doors. With any type of Roto Zip wheel you will want to cut the opening of the housing then revealing the Blens doors. You may then R&R them as needed. P.S. Prior to cutting check the actuator located there before you cut. It is a triangular piece about the size of small cell phone with 3 screws. This piece should be turning as you increase or decrease the heat. If you have the money bring it into a Jeep Dealership or respected mechanic. If not, this is the easy way of doing it. Good Luck!!!!!!!
I'll see if I can find more.
Double E is offline
post #7 of 9 Old 11-27-2006, 12:20 PM
KingPrat
Well, the search works if you are a paying member. Admin disabled it to non-paying because of server stress.
Now, I will repost the link from above http://www.wjjeeps.com/hvac_blend_remove.htm
If you're gonna do it, do it right. Follow these directions or splurge the $1000 or so at the dealer.
Just my .02
New: Steel Blue 2001 Laredo 4.7, QD, Exhaust
Nokian Vatiiva tires: 235/65-17
Previous:1997 ZJ TSi 4.0. Some stuff added
Western New England College '08
Golden Bear Lacrosse #13
Week 11 USILA Rank: #15
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
post #8 of 9 Old 11-27-2006, 12:33 PM
Double E
Double E's Avatar
I found the post I added a few months ago that referred to cutting an access hole to repair the blend door without having to remove the dash.
It was a link over on jeepsunlimited but has since been archived. I'm not a member there so google does not give it and I cannot search there.
Here ya go, the long way...... http://www.jeepforum.com/forum/f13/no-heat-dreaded-blend-door-341518/
Double E is offline
post #9 of 9 Old 11-27-2006, 12:52 PM
veso_Ht
i started taking the dash off today.. no hurry since my mom is out of town... while i'm at it i'll be fixing my heated seat as well...
veso_Ht is offline
No air coming from defrost vents D73 ZJ Grand Cherokee Forum 0 01-28-2010 07:09 AM
No Air from Defrost Vents D73 ZJ Grand Cherokee Forum 9 01-04-2010 12:11 PM
Vents will not switch. '04 WJ stuck on defrost. zj+3 ZJ Grand Cherokee Forum 24 07-07-2009 11:10 PM
problems with air blowing only through my defrost vents joshhuwa ZJ Grand Cherokee Forum 1 07-19-2008 08:45 PM
AC blowing out defrost only??? 10achik WJ Grand Cherokee Forum 2 05-27-2004 03:52 PM
