Defrost (Heat) Comes On By Itself - JeepForum.com
post #1 of 3 Old 04-03-2006, 11:15 AM Thread Starter
UnDeR EsTiMaTeD
Yesterday I took a drive out to the desert where the outside temperature was around 100 all day. As I would climb a few inclines, the defrost would come on all by itself. It was blowing hot air from the defrost vents only. It would stop once the engine didn't have any kind of load. It didn't do it around town or cruising. It only happened as I would put load on the engine. What is causing this?
1994 Jeep Grand Cherokee 4x4
4.0L - I6 @ 200k & Counting!
UnDeR EsTiMaTeD is offline
post #2 of 3 Old 04-03-2006, 11:18 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
A leak in a vacuum like OR you need to place a one way valve in your HVAC control lines to prevent it from switching on you...Someone will chime in with exactly what kind and where the valve goes.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 3 Old 04-03-2006, 11:35 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Here you go - sounds like you need the check valve if it does it when under load. If you had a leak, it might ONLY blow out through the defroster.
http://dodgeram.info/tsb/1996/24-01-96a.htm
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
Heater only shoots heat out of the defrost vents hmmhoyhoy ZJ Grand Cherokee Forum 23 04-08-2013 03:46 PM
96 GC blows to defrost but not A/C or heat outlets mnwilly ZJ Grand Cherokee Forum 0 07-18-2009 02:43 PM
Help: Heat only from defrost dmarko3 ZJ Grand Cherokee Forum 7 03-10-2009 01:12 PM
Heat only on defrost dmarko3 ZJ Grand Cherokee Forum 4 03-09-2009 12:42 PM
Heat Only Blows Out Defrost Z06_GIRL ZJ Grand Cherokee Forum 4 01-19-2008 08:56 AM
