The Definitive Injector Swap HOW TO - Page 42 - JeepForum.com
 1Likes
post #616 of 677 Old 04-23-2014, 04:44 PM
cbeam2
1994 ZJ
One of the ebay guys selling injectors recommends the 710's instead of 703's on stock 4.0. His reason was you don't need the higher flow. I see most talk about using the 703,s, are they bring used more for a higher flow?
What about you guys using the 710's? Happy happy happy or what?
Chuck
cbeam2 is offline
post #617 of 677 Old 04-23-2014, 04:50 PM
CatSplat
1994 ZJ
Originally Posted by zander21510 View Post
You all might have noticed I redid the original post so that it's a little better organized and easier to understand, and removing some useless information. Hope you all like it!
Your removal of my primer on connector and injector body designs displeases me.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #618 of 677 Old 04-24-2014, 02:33 AM
Zjrookie
Finally read it all but it's great
Zjrookie is offline
post #619 of 677 Old 04-29-2014, 12:21 PM
hezx
Just did this swap with these 789 Ford branded injectors. This Jeep has never run better. Defiantly worth the money.
hezx is offline
post #620 of 677 Old 05-05-2014, 11:29 AM
MountainMan303
Haven't scoped this thread fully, only partially. But for time's sake, any opinions on paying $150 for local pickup of 6 Bosch '703's that have been cleaned, pressure tested, and repaired, considering getting them at the JY is $5-$10 per injector, and $25 on the rebuild kit?
I spent 2 separate trips this weekend looking for these the the local JY's, and either already pulled or trashed beyond repair.....
1995 ZJ Grand Cherokee 4.0L, 3.5" Iron-Rock Benchmark kit, 31x10.5x15 Duratracs, 15x8 Cragar Soft 8's, Front and Rear Adjustable Tracks, Up-Country Skids
MountainMan303 is offline
post #621 of 677 Old 05-05-2014, 12:09 PM Thread Starter
zander21510
You can check eBay but I don't know of anything that can be local pickup unless you can find a local place that will sell those injectors new
zander21510 is offline
post #622 of 677 Old 05-05-2014, 12:12 PM
tirus89
The 5.2l/5.9l swap how to link doesn't work. Still.
Not that I need it, just for continuity sake and for the newbies.
tirus89 is offline
post #623 of 677 Old 05-10-2014, 07:00 PM
MountainMan303
Just replaced mine with the 703's I bought off of eBay. Didn't undo the throttle cable or anything like that, just loosened the bracket out of the way. Replaced them, and now it sounds like I'm running rich or misfiring or something.........what am I doing wrong? Can anyone help? The injector closest to my firewall seems as though it has more space between the intake manifold and the injector, just a hair more than the other ones. Everything seemed to go in smoothly? I have no clue what could be happening.
post #624 of 677 Old 05-11-2014, 04:13 PM
cbeam2
1994 ZJ
Sounds like injector is stuck.
cbeam2 is offline
post #625 of 677 Old 05-18-2014, 12:13 PM
MountainMan303
Tried the install of the 703's yesterday on my 4.0l. Nothing leaking, full fuel pressure in the rail. Seems like its either running rich, or missing a cylinder somehow. Hard to determine what's happening with my manifold leak, but I definitely don't think it should sound or perform the way it is (chuffing/non-smooth sounding exhaust). Anyone have any suggestions? Does the computer need a couple days to learn? If it is stuck like cbeam2 says, any quick ways to resolve this?
post #626 of 677 Old 05-18-2014, 12:22 PM Thread Starter
zander21510
Did you unhook the battery? Let it sit overnight without the battery to reset it
post #627 of 677 Old 05-19-2014, 02:33 AM
ejschultz
ejschultz's Avatar
My buddy's 96 4.0 did the same thing. No matter what we tried with it, it kept running rich. He ended up rebuilding his stock 778s and put them back.
ejschultz is offline
post #628 of 677 Old 05-19-2014, 08:44 AM
MountainMan303
Battery unhooked while I was swapping, and again last night. No difference this morning, still running poorly.
Fairly certain that one could be stuck open or malfunctioning. Anyone have ideas as to a quick way to find out/test which one is stuck? I really don't want to give up on these.
post #629 of 677 Old 05-19-2014, 09:52 AM Thread Starter
zander21510
Best way to find a leak is described in op
post #630 of 677 Old 05-19-2014, 11:02 AM
tetatdo
1994 ZJ
So im having trouble passing CA smog with the 703 injectors installed. My truck is a 94 ZJ 4.0. with the 99+ WJ manifold installed. Do the 703's not flow enough fuel for my setup?
Im passing the 15 mph with flying colors but it seems to be leaning out on 25mph under load.
From what I read on here, the 703's flow about 1.2 or 1.3 lb less than the stock siemens? would this make a huge difference?
tetatdo is offline
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
