The Definitive Injector Swap HOW TO - Page 40 - JeepForum.com
post #586 of 676 Old 12-13-2013, 04:04 AM
SpectralZJ98
Originally Posted by Football47 View Post
Intake swap? Link please
Ok. Forgot that's something sometimes over looked. I got two links for you, in this case.
Just the intake thread: http://www.jeepforum.com/forum/f13/9...d-how-1345931/
Upgrades for the I6: http://www.jeepforum.com/forum/f13/4...rades-1254969/
Still in the process of slowly upgrading according to the thread. Intake was easy, though there is some cutting and splicing to get things lined out. Cake-simple, though
SpectralZJ98 is offline
post #587 of 676 Old 12-13-2013, 04:21 AM
SpectralZJ98
And also, for the record, every time I'm at PullaPart in Louisville, I make it a point to scout out the I6 WJs and grab their intakes. Doesn't matter if I need them or not, since most of the people I hang with have I6s and its easier to give them one than for them to go find one. I also get bored a lot, which is why I'm always messing with my Jeep. One of these days, I'm just going to get another one and rebuild my DD. Its about time for it, anyway
post #588 of 676 Old 12-15-2013, 09:25 AM
Pierre_r
1989 XJ Cherokee
I have read the first post a number of times but i still dont really understand
I have a 93 w5.2 what injectors should i buy for it?
Is it the 710 i can use on it?
Whats is the differance between them and rebuilt stock injectors?
Will i gain some mpg with 710 or will it be the same as with the stock injectors?
Pierre_r is offline
post #589 of 676 Old 12-15-2013, 07:05 PM
Football47
Thanks Spectral!
Can't beat a Jeep
Football47 is offline
post #590 of 676 Old 12-22-2013, 06:40 AM
KyBoy1991
Spectral, I'm in the same pullapart several times a year. We should talk sometime, maybe we could help one another when in need. I'm only 30 min from Louisville. Also, have you seen the thread on here about swapping the header from a WJ on to our ZJs? Makes it a 3-2-1 style with 2.5" out. That's my next step to go along with the injectors and manifold swap. Just waiting to get all the parts at once rather than do the same work twice.
***edit: exhaust manifold is 99-00WJ not TJ****
http://www.jeepforum.com/forum/f13/9...-swap-1234191/
KyBoy1991 is offline
post #591 of 676 Old 12-22-2013, 06:45 AM
KyBoy1991
Originally Posted by Pierre_r
I have read the first post a number of times but i still dont really understand I have a 93 w5.2 what injectors should i buy for it? Is it the 710 i can use on it? Whats is the differance between them and rebuilt stock injectors? Will i gain some mpg with 710 or will it be the same as with the stock injectors?
It's most likely going to give you a smoother idle and better throttle response, most see a gain in the mpg's, however that's not everyone to my knowledge. Go back to the first pages and watch the videos, it shows the same amounts of gas being used I think but look at the actual gas spray coming out. One is basically a solid stream while the other(newer 4hole style) is a fine mist cloud of fuel which provides a better burn and atomization....the better idle and response.
post #592 of 676 Old 12-22-2013, 07:14 AM
SpectralZJ98
We should, I agree. Up until 2 months ago, I lived right off Preston by Roosters, and PAP was only 3 or 4 miles down the road. Every hour I had available was spent there. Sadly, I'm now all the way up in Jasper Indiana, commuting to Toyota every day. But I still schedule PAP and Range trips every month.
I haven't seen that exhaust swap thread yet, but I definitely need to.
post #593 of 676 Old 12-22-2013, 07:46 AM
OverlandZJ
I'd like to see that WJ header swap too.. just happen to have a spare WJ header set.
OverlandZJ is offline
post #594 of 676 Old 12-22-2013, 12:50 PM
KyBoy1991
I'm trying this from my phone app, but there's the link. If it doesn't show, lookup TurboTPI, he started the thread.
post #595 of 676 Old 12-22-2013, 01:57 PM
OverlandZJ
Is that header a copy of OEM Federal emission equipment? And it has 2.5" tubes?
My wife's 99 is CA emission and has dual cast manifolds.. with 1-5/8" ID passages. (just measured spare manifolds)
Thanks for the link..
post #596 of 676 Old 12-22-2013, 02:53 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
That is one wild looking header!
Originally Posted by HighLonesome
coralman is offline
post #597 of 676 Old 12-22-2013, 08:30 PM
Brendan4862
2003 WJ
I just did a 789 swap into my 5.9 and it idles SOOO much smoother than with the original injectors that had been in there for 130k miles. It also has a much smoother throttle response. I haven't done any trips yet to check the mileage but I will update.
I wanted to post because after reading this whole thread I saw a mention of the wire harness adapters needed for the 789s ev6 style electrical connector to ev1 harness connector. I used a one piece connector set I got off eBay and I had plenty of room to use that style. I did it to minimize extra wires under the hood. So they definitely work with plenty of room for the 5.9. I'm not sure about the 5.2, but it is probably the same. So happy I did the swap! Thank you jeep forum and its members!
There is no substitute for a Jeep
Brendan4862 is offline
post #598 of 676 Old 12-25-2013, 12:15 PM
KyBoy1991
Originally Posted by OverlandZJ
Is that header a copy of OEM Federal emission equipment? And it has 2.5" tubes? My wife's 99 is CA emission and has dual cast manifolds.. with 1-5/8" ID passages. (just measured spare manifolds) Thanks for the link..
I couldn't tell you if it is OEM I just read the thread and want to go it to mine. In the thread, TurboTPI did say there are pre-welded o2 bungs. So to me that says they are legal...will it pass CA emission regs, that's a whole other topic
post #599 of 676 Old 01-09-2014, 07:22 PM
dbmorris99
has any one used the Bosch 0280155740 injectors they were also in the 95-97 neons but in the sohc were as the 0280155703 came in the dohc? i know the specs beteen the 703 and the 740 is close. just wondering if anyone has used them
dbmorris99 is offline
post #600 of 676 Old 01-21-2014, 11:12 PM
StPaul59
Anyone know which ones these are? Just says Bosch 4 hole... And they come with adapters. The guy has really good feedback, so maybe they are legit.
http://www.ebay.com/itm/96-97-98-Jee...901850&vxp=mtr
StPaul59 is online now
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
