The Definitive Injector Swap HOW TO - Page 39 - JeepForum.com
 1Likes
post #571 of 677 Old 12-10-2013, 03:20 PM
Football47
Originally Posted by PolkaPower View Post
Going by the trip computer is a very inaccurate way to determine MPG. It's never correct.
Yeah but its saying I'm getting 16.6mpg now, and with my stock ones I got 18.3mpg.... the upgraded injector must not be as good as my one hole stock injectors...
Can't beat a Jeep
Football47 is offline
post #572 of 677 Old 12-10-2013, 03:27 PM
PolkaPower
Or the computer hasn't learned yet. Did you unplug the battery?
PolkaPower is online now
post #573 of 677 Old 12-10-2013, 05:08 PM
ejschultz
ejschultz's Avatar
You should never go by the overhead. They especially lie when you do a 703 swap. If you never hand calculated your MPGs before, you'll never know what kind of difference they actually make other than maybe a few more/less miles per tank.
ejschultz is offline
post #574 of 677 Old 12-11-2013, 01:04 AM
Football47
No I haven't... you're talking about the main battery right? Not something unique that specifically goes to the computer right?
Can't beat a Jeep
post #575 of 677 Old 12-11-2013, 01:06 AM
Football47
This one actually was spot on with the overhead since I hand calculated the mpg myself before. Good to know though.
Can't beat a Jeep
post #576 of 677 Old 12-11-2013, 04:03 AM
SpectralZJ98
Agreed. I always reset mine after I've worked on the engine. When I swapped in the junkyard 703s, I went from 12.5 (previous reading) to 22.3 (after intake and injector swap). Its reading 19.7 now, but I think that's more because Indiana people drive 10mph when it's snowing.
SpectralZJ98 is offline
post #577 of 677 Old 12-11-2013, 04:10 AM
torchd
2003 WJ
My OVHD display reads 15.5 mpg. But I have an excel spreadsheet that I created where I calculate my mpg. I am no where near the 15.5 mpg now that winter is upon us.
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #578 of 677 Old 12-11-2013, 05:30 AM
ejschultz
ejschultz's Avatar
Hey now... Not all Hoosiers are bad drivers. I'll admit, I don't speed more than maybe 5 mph over the speed limit and exactly the speed limit in neighborhoods; that does piss off some people. This morning I was one of the fastest on the highway in my ZJ going 5 under because of the snow. I've been commuting to Chicago every morning for work. That's with Illinois drivers.
post #579 of 677 Old 12-11-2013, 07:35 AM
SpectralZJ98
I agree about Illinois drivers. I have a 1.5hr commute from where I live and TMMI one way. I ain't got time for slow drivers
post #580 of 677 Old 12-11-2013, 08:58 AM
ejschultz
ejschultz's Avatar
If you do the math, 55 vs 65 over 100 miles only saves you 10 minutes. Speeding, unless you're going a long distance, doesn't get you anything other than frustrated with the dude in front of you who's going the speed limit and possibly a ticket. Look at me, I'm talking like an old fart...
post #581 of 677 Old 12-11-2013, 09:13 AM
zjosh93
It's actually 17 minutes.
100 m / 55 mph x 60 min/hr = 109 min
100 m / 65 mph x 60 min/hr = 92 min
Assuming that's a one way the time savings is almost 3 hours (2.8) per week.
zjosh93 is offline
post #582 of 677 Old 12-11-2013, 09:48 AM
SpectralZJ98
Forgot to factor in the trains that cut 3 of the town's in half. Timing is everything, but 60mph means the difference between ahead of the train and on time, or 20 minutes late because the same train goes through all 3 towns.
post #583 of 677 Old 12-11-2013, 11:17 AM
ejschultz
ejschultz's Avatar
Yeah. I failed there. If I wrote it out I would have realized I ended up with 1.82 and 1.54 hours, respectively, for the trips. My brain has been in an extreme lack of sleep for the last 15 months or so and it's been worse the last 2 months. If I would have slowed down a little I would have caught my mistake. Regardless, that's assuming you have a 100 mile trip. Most of the a-holes that get on the interstates around here only commute a few miles, 30 miles max. To make a difference there, you'd have to be flying.
post #584 of 677 Old 12-12-2013, 03:11 PM
Football47
I did this method for resetting the ECU this morning:
Disconnect the POSITIVE battery Terminal and touch it to ground for 30 seconds.
Reconnect the Battery Cable
Turn Ignition Switch to the “ON” position
Turn Headlight “ON”
Turn Headlights “OFF”
Turn Ignition Key “OFF”
My gas mileage is down to 15.7mpg which it's never been so low. I think my ECU was reset since my radio preset channels were swiped clean, but who knows.
Can't beat a Jeep
post #585 of 677 Old 12-13-2013, 03:44 AM
Football47
Intake swap? Link please
Can't beat a Jeep
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
