The Definitive Injector Swap HOW TO - Page 38 - JeepForum.com
post #556 of 676 Old 11-27-2013, 08:29 AM
BLarkin
Are those the 703 injectors? If so, seems like a fair deal.
BLarkin is offline
post #557 of 676 Old 11-27-2013, 10:34 AM
SpectralZJ98
BLarkin: they are indeed 703s. Just bought a set from them for my wife's jeep the other day. I even sprung to have them flow matched to within 1%. Worth every penny
SpectralZJ98 is offline
post #558 of 676 Old 11-27-2013, 12:42 PM
ejschultz
ejschultz's Avatar
I'll have a set of 703s for an I6. They're impedance matched but not flow matched. They have about 3000 miles on them since the rebuild. My buddy (todd4198 on here) wanted to swap back to the 778s as an experiment. He's not planning on swapping the 703s back in. They're 100% functional. PM me for more info.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Trail Gear front bumper, 31" Duratracs on 15x8s
ejschultz is offline
post #559 of 676 Old 12-03-2013, 04:54 AM
Football47
Think I found some decent injectors... what do you guys think? http://www.ebay.com/itm/96-97-98-Jee...9ef509&vxp=mtr I think they are flow matched Bosch 778s, I want injectors that will give me the best fuel economy. They claim better fuel economy and that's the only reason I want new injectors! Ejschultz how did your friend Todd4198's experiment go?
Can't beat a Jeep
Football47 is offline
post #560 of 676 Old 12-03-2013, 05:01 AM
SpectralZJ98
They look good, and I love that the wiring adapters are included. Allows for use of both style injectors. May have to get a set just to test them out.
post #561 of 676 Old 12-03-2013, 05:34 AM
ejschultz
ejschultz's Avatar
His experiment went the way he hoped. His stock Siemens 778s rebuilt perform better than his Bosh 703s rebuilt, in his case. Earlier in this thread you read about people having issues with their Jeeps not learning the 703s and running really rich. His was one of those Jeeps for whatever reason.
post #562 of 676 Old 12-03-2013, 10:45 AM
SpectralZJ98
Contacted the seller on eBay about those injectors:
"these are xf2e injectors. 235cc and the harnesses come with them."
post #563 of 676 Old 12-03-2013, 04:11 PM
Football47
The flow rate is 22 lbs/hr, 230 cc/min at 43.5 psi... that sounds about right...right? Stock 4.0 Injector (96-98): Siemens 53030778 are 23.7lb/hr @ 49psi and the 703's are 24.0lb/hr @ 49psi...
Can't beat a Jeep
post #564 of 676 Old 12-04-2013, 04:47 AM
Football47
Those injectors with the adapters are actually Siemens fuel injectors... even though it said Bosch right in the description model XF2E 22lbs/hr @ 43.5psi. So lower Psi and lbs/hr means what? Weaker throttle response? Better gas mileage???
Can't beat a Jeep
post #565 of 676 Old 12-04-2013, 06:10 AM
SpectralZJ98
He'll if I know. Your pump should be operating at 49psi anyway.
http://m.ebay.com/itm/251338643115?nav=WATCHING&sbk=1
Like these better
post #566 of 676 Old 12-05-2013, 04:02 PM
Football47
Well just purchased those injectors online off eBay... will be posting my overall gas mileage and distance traveled before I put the new injectors in and test them out!
Can't beat a Jeep
post #567 of 676 Old 12-05-2013, 05:23 PM
SpectralZJ98
The ones with the wiring harnesses, or the direct fit yellow ones?
post #568 of 676 Old 12-09-2013, 12:51 PM
zjosh93
That's 22 lbs/hr at 43.5 psi. That's just what they are rated at. 43.5 is a common pressure rating for injectors so they can be easily compared. If your Jeep's fuel pressure is 49 psi the actual flow in your application will be about 23.3 lbs/hr. http://www.csgnetwork.com/fiflowcalc.html If the stock injectors are 23.7 lbs/hr at 49 psi then you will probably run a little leaner in open loop and the computer will recalibrate in closed loop for no net change in A/F ratio.
zjosh93 is offline
post #569 of 676 Old 12-10-2013, 02:24 AM
Football47
Adapter harness. Well got my injectors today and put them in, took it for a test drive and woah did I feel a difference. I had a noticeable gain in throttle response, seemed to idle a little bit smoother, but I'm not sure about my mpg. I had 5190 miles clocked in at 18.3mpg, it has been dropping ever since it's been getting colder out. I usually get about 17.5mpg in the winter time/ 19-20 in the summer time and with 38 miles on my new injectors I'm getting 17.3mpg... shouldn't the computer have corrected this by now. I should probably wait and get some more miles accumulated. Thoughts?
Can't beat a Jeep
post #570 of 676 Old 12-10-2013, 11:26 AM
PolkaPower
Going by the trip computer is a very inaccurate way to determine MPG. It's never correct.
PolkaPower is online now
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 07:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 05:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 07:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 06:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 06:28 PM
