The Definitive Injector Swap HOW TO - Page 34 - JeepForum.com
 1Likes
post #496 of 677 Old 09-22-2013, 12:44 PM
PolkaPower
Originally Posted by coltonflak12 View Post
Anyone know about how much the 703's are going for at the JY?
I think I got all 8 for 30- 40 bucks. Rebuild kits was 15.
PolkaPower is offline
post #497 of 677 Old 09-22-2013, 09:19 PM
coltonflak12
Oh thats not bad at all, how do you know if they need to be rebuilt?
coltonflak12 is offline
post #498 of 677 Old 09-22-2013, 09:31 PM
PolkaPower
For one they were old and they were sitting in a junk yard with bad gas in them. lol
post #499 of 677 Old 09-23-2013, 01:49 PM
PolkaPower
Just got 8 green Bosch 789's with harness's in the mail today. I have been running slightly rich. I think since I put in the 703's. I tested them for leaks twice and listened to them while the motor was running. They all seem to be working fine but I'm just not satisfied. We will see how the 789's work out. The 703's are rated for 23lbs P/H and the 789's are rated for 21.
If it works out I will have 8 703's for sale. They are not flow matched. I got them out of the yard and cleaned them up really well then rebuilt them with new filter baskets, pintle caps, and o rings.
post #500 of 677 Old 09-23-2013, 04:09 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Those are purdy Polka, Where did you get the adapter harnesses?
Originally Posted by HighLonesome
coralman is offline
post #501 of 677 Old 09-23-2013, 04:51 PM
PolkaPower
They came with them. I found them on Ebay. Super fast shipping too.
post #502 of 677 Old 09-25-2013, 03:08 PM
PolkaPower
Got the injectors in today. All I can say is that the 789's are smoother than the 703's I got from the JY and rebuilt. Acceleration is very good and pulls strong and smooth. At idle it's so smooth I had to check if I had an engine. Listening to the exhaust note purr at idle is like music. So far I love them. Looking to see if my slightly rich situation is gone. I'll know in a few days.
post #503 of 677 Old 09-25-2013, 04:02 PM
Scopez
1994 ZJ
Definitely let us know. I'll gladly order 789s instead of 703s for my 5.2L.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #504 of 677 Old 09-25-2013, 06:58 PM
KyBoy1991
Is this a difference of 6 cyl vs 8cyl or is it a mind game or has anyone else been able to verify why polka had the rich issue?
I thought these were all verified, now it seems like the 789s with the tails is a better option?????
Polka how much did you end up giving for the set?
KyBoy1991 is offline
post #505 of 677 Old 09-25-2013, 07:00 PM
PolkaPower
Originally Posted by kyboy1991 View Post
is this a difference of 6 cyl vs 8cyl or is it a mind game or has anyone else been able to verify why polka had the rich issue?
160-170 I'll know in the next few days at start up if it was the injectors. My exhaust was smelling a little like gas for a while now. It didn't start until I put the 703's in. I tested them for a leaks twice and they were not leaking but they are not flow tested and matched. I pulled them out of the yard and rebuilt them. On start up today with the 789's I didn't notice an unusually gas smelling exhaust but I need a few more cold start ups to be sure. Either way they are an improvement over what I had in there.
post #506 of 677 Old 09-25-2013, 08:06 PM
KyBoy1991
So the 703s could still be the best or equally as good of an option IF the are a matched set... Cause I can get a set of them on eBay matched for $99---or could. Haven't looked for any in a long while as I haven't had the funding to consider the upgrade.
post #507 of 677 Old 09-25-2013, 09:15 PM
PolkaPower
The difference between the numbers on them are small. The plugs are different. 789 are a bit newer. I think 2000+. I have not tried a professional rebuild or new 703's so I can't compare my old ones vs the new ones. I actually looked for OEM replacements first but they were expensive. Or the ones I saw were.
post #508 of 677 Old 09-26-2013, 03:58 AM
ejschultz
ejschultz's Avatar
My buddy's 4.0 started running rich after his 99+ intake and rebuilt 703s. His 703 were impedance matched. That's the reason he's going back and putting rebuilt 778s in there.
ejschultz is offline
post #509 of 677 Old 09-26-2013, 11:53 AM Thread Starter
zander21510
This might be a good option for folks who can't find 703s in JYs. If you are satisfied with your results let me know I'll add 789s to OK to use with adapters
zander21510 is offline
post #510 of 677 Old 09-26-2013, 12:47 PM
PolkaPower
I had a lot of fun driving today. I noticed that I do not have to depress the pedal as much to get going. Especially if I am already moving and need to accelerate. I am still in shock at how smooth it idles. Not a lot of room to do any WOT runs yet. Need to get to a bigger or more deserted road. I need to adjust the TV cable again from having the TB off.
I'm not going to put the 703's back in so if anyone wants them let me know. I cleaned them with seafoam and they have new baskets, pintle caps, and O rings. There is about 2000 miles on them since the rebuild.
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
