The Definitive Injector Swap HOW TO - Page 32 - JeepForum.com
 1Likes
post #466 of 677 Old 07-31-2013, 07:24 PM
ejschultz
ejschultz's Avatar
I'm going to pose a question: has anyone reconditioned their stock injectors to see what kind of difference it yields compared to 703s? I have a gut feeling that might be a better option than 703s. I'm throwing this out there as food for thought. I have 703s and I'd say they perform marginally better than stock injectors with 90k on them. I'm thinking about reconditioning my stocks to see how they compare.
ejschultz is offline
post #467 of 677 Old 07-31-2013, 07:39 PM Thread Starter
zander21510
I think the whole point of the 703s are their better 4-hole atomization design. I didn't recondition my 703s personally...they came out of a couple of 97s in the junkyard...so they were probably comparable in age and condition.
zander21510 is offline
post #468 of 677 Old 07-31-2013, 07:42 PM
DickDickle
I'm STILL looking for two more so I can do this swap I've searched three entire junkyards and came up with four
DickDickle is offline
post #469 of 677 Old 07-31-2013, 07:53 PM
ejschultz
ejschultz's Avatar
I understand the argument and halfway believe it. I'm running 703s, as I stated. I just want to do an experiment and figured I'd pose the question. I bet no one one this forum has reconditioned their stock injectors.
post #470 of 677 Old 07-31-2013, 08:07 PM Thread Starter
zander21510
That is probably true. It would be interesting to see
post #471 of 677 Old 07-31-2013, 08:31 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I had batted that idea around myself. If I had the time, I would carry it a step further and do some mod analysis on the wj intake and header combo as well. I wouldn't be quite insane enough to test them individually { which would negate the results of individual benefit} but say stock injector new or rebuilt, cleaned stock manifold, and new bellows style exhaust manifold{OE or dorman} vs 703's new or rebuilt,wj manifold, and a apn header. Both on an updated cat and cat back.
I have watched these mods for over a year and labor wise there is not much difference,except you would be doing everything twice. Its just the uncertain aspects of them that have kept me on the fence. Eventually, I will have to commit one way or the other or both, but it will have to cool off some first.
Originally Posted by HighLonesome
coralman is offline
post #472 of 677 Old 08-01-2013, 05:51 AM
zj97ltd
I've been wondering this too. To me, "reconditioned" 703s vs. 100,000+ mile stock injectors isn't an apples to apples comparison.
zj97ltd is offline
post #473 of 677 Old 08-01-2013, 05:53 AM
ejschultz
ejschultz's Avatar
If I can free up some time between work and my other infinite number of projects, I'll do it.
post #474 of 677 Old 08-01-2013, 03:10 PM
jnowak
That stinks. I got two sets out of one yard. And passed up more cause they didn't pop with my tester.
jnowak is offline
post #475 of 677 Old 08-01-2013, 04:18 PM
CatSplat
1994 ZJ
I didn't recondition them, no, but I did pull a few filter baskets out of my old stockers to see what 400,000k looked like. Turns out that the inline fuel filter does a pretty good job - the injector filters, apart from being discoloured from years of gasoline, didn't have any noticeable gunk in them. I was actually quite surprised. When I ran the spray pattern tests before flow matching, it was done with new baskets in both styles of injector.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #476 of 677 Old 08-01-2013, 09:53 PM
bigb229
I reconditioned my stock injectors while rebuilding my 4.0l recently. Only difference to note is a smoother idle. I'm running a comp cam 99 intake bored throttle body, msd ignition, plugs gapped to 45 thousandths. And manga flow exhaust. It's a standard bore. I swapped in some 703s and haven't noticed any loss or gain but a silky smooth idle.
bigb229 is offline
post #477 of 677 Old 08-22-2013, 04:13 PM
NJ2MDJim
Great write-up. Thanks very much!
NJ2MDJim is offline
post #478 of 677 Old 08-22-2013, 06:40 PM
Mity White 96
Mileage has absolutely improved with the 703s
With about 175K on the odometer, I used to be lucky to get close to 15mpg on average. Sometimes I'd get close to 16 under really special conditions but that was rare. Having swapped out the injectors for 703s, I recently measured almost a full tank usage at 17.7mpg. That's way better no matter how you choose to measure it. But what's really valuable is that my fuel tank range has also picked up at least another 35 miles or so. I'm absolutely enjoying this conversion to the 703s.
Mity White 96 is offline
post #479 of 677 Old 08-27-2013, 05:47 PM
Phreaq
I think I got hosed ...
http://www.ebay.com/itm/96-97-98-Jee...item3a7e15d137
(The adapters pictured do not come with the injectors .... Nor did he sell them .... Found that out a little late)
Turned out to be XF2E-C4B ford injectors. The description did not mention parts number, my fault for not checking.
Is anyone familiar with these injectors?
I installed them on a 98 ZJ 4.0
I am having rough idle and p0301 (if the adapters were not working there would be a p020x for that cylinder)
Edit: swapped injectors one and two, same code returns. While I still question the injectors, they do not seem to be causing my p0301.
Phreaq is offline
post #480 of 677 Old 09-14-2013, 05:03 PM
riot1987
Just put 703's in my 5.2. It stumbled for a bit at first and then the idle smoothed out and it seems to run great. Throttle response seems to be better and it seems smoother between shifts with less lag. Took about 2.5 hours to do. Pretty painless all in all.
Build thread^^
riot1987 is offline
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
