The Definitive Injector Swap HOW TO - Page 30 - JeepForum.com
 1Likes
post #436 of 677 Old 04-15-2013, 02:15 PM Thread Starter
zander21510
Originally Posted by DickDickle View Post
What basic tools do you need to remove them from a stratus or cirrus? Heading to the junk yard on saturday
Just a ratchet kit. Only a couple of bolts to remove the rail.
zander21510 is offline
post #437 of 677 Old 04-15-2013, 02:19 PM
dnuccio
IIRC the fuel rail ios held in with a couple 13mm bolts. 13mm socket. then just pull it up out of the way and pop the clips off the injectors, then the injectors just pull out of the rail. super easy
if theyre stuck in there good, a pry tool helps as well. im sure you could improvise something you find in the JY, such as a jack handle or hood prop rod.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #438 of 677 Old 04-15-2013, 02:28 PM
DickDickle
Thanks I just wanted to make sure I had everything I needed. I try to keep my tools in my breast pocket cause the yard I go to searches tool bags inside and out
DickDickle is offline
post #439 of 677 Old 04-15-2013, 06:11 PM
Moparmissus
1994 ZJ
This whole thread has been helpful, but I want to make sure I'm clear on a couple of things. For a '94 4.0 the 703s are the way to go. I could try a junkyard and hope to find a good set from a single engine, or buy a balanced set online. Anybody have a link to some place online selling matched sets for less than an arm or leg?
Moparmissus is offline
post #440 of 677 Old 04-20-2013, 10:13 AM
DickDickle
Will the 740 injectors work out of a 97 dodge neon?
I was only wondering because I searched two seperate junk yards and could only find 4 703 injectors which I thought was insane and I checked for everything on the list and a lot of the neons I saw had the 740s
post #441 of 677 Old 04-20-2013, 02:34 PM
ejschultz
ejschultz's Avatar
I think the 740s are the same flow and pressure as the 703s but they're physically shorter according to research I did before getting my 703s.
ejschultz is offline
post #442 of 677 Old 04-20-2013, 03:58 PM
DickDickle
Yea I didn't end up taking them, just going to have to try a new yard next weekend and hope I can come across at least two more just bummed because I wanted to put them in today
post #443 of 677 Old 04-30-2013, 08:12 PM
davidtownsend
2006 WK
I'm going to get the 710 for my 94 5.2. Are these good or are the 703 better for my engine. Is there any way I could test the injectors at the jy?
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #444 of 677 Old 04-30-2013, 08:38 PM Thread Starter
zander21510
Those are the recommended type. Idk of any way you can test them at the JY other than a visual inspection...or putting them in your jeep in the parking lot lol.
post #445 of 677 Old 04-30-2013, 08:41 PM
davidtownsend
2006 WK
Thanks for replying. I haven't read all the posts but how can I test them when I get home? And what rebuild kit should I buy for them? The ev6 our ev3?
post #446 of 677 Old 04-30-2013, 08:55 PM Thread Starter
zander21510
Ev6, all the info u need is in the OP
post #447 of 677 Old 04-30-2013, 09:29 PM
davidtownsend
2006 WK
Thanks dude! Just re read it! Came in handy!
post #448 of 677 Old 05-01-2013, 04:57 PM
davidtownsend
2006 WK
Picked up some 710. I can't wait to put them in and see the results. I will post the output in the morning.
post #449 of 677 Old 05-02-2013, 12:04 PM
davidtownsend
2006 WK
710 of of a 98 Ford exploder. It was a PITA to get to. Pot then in and it ran rough for a little. Took it out for a test drive and she smoothed out. Can't really tell anything else yet but when I do I'll let you guys know.
post #450 of 677 Old 05-15-2013, 12:53 PM
tetatdo
1994 ZJ
anyone else having a slight hesitation on takeoff from idle with the 703s? mine are newly refurbished units with a guarantee. It runs pefrectly fine but i notice from a stop at idle if i take off it has a slight hesitation before taking off..
any ideas?
tetatdo is offline
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
