The Definitive Injector Swap HOW TO - Page 29 - JeepForum.com
post #421 of 675 Old 03-21-2013, 04:11 PM
PeteNnewburg
Originally Posted by zander21510 View Post
Very descriptive post! I added you.
We only need 1 more success to confirm '95 5.2 w/703s; and 2 more successes to confirm the 5.9. Every other combo is confirmed!
It all makes you wonder why they didn't use 4-holes in the first place lol
Cheaper to drill one hole?
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
PeteNnewburg is offline
post #422 of 675 Old 03-21-2013, 04:30 PM
jetjr91
I did the swap on my 95 v8 as well
703's from dodge neons
Engine ran a lot smoother and definitely idles better
703's in 95 v8 confirmed!!
jetjr91 is offline
post #423 of 675 Old 03-23-2013, 11:08 AM
Boxybrown1989
5.9 confirmed
I literally joined this forum just to confirm a 99 dodge 5.9l with the 703 injectors. I had been reading and figured i would try it. Bought used neon injectors and the recommended rebuild off ebay and was going good a week later. I'm getting roughly 2 more mile to the gallon both by the overhead and the miles to gallons math.
Boxybrown1989 is offline
post #424 of 675 Old 04-04-2013, 05:55 PM
NYCXJ90
NYCXJ90's Avatar
2014 JK Wrangler
Just finished installing 703's in my 5.9. Pulled em off a few stratus's with 2.4l. All the neons I looked at had different injectors.
World of difference, smooth idle, better acceleration. Too soon to tell on the gas mileage yet.
'90 XJ Laredo RE 3.5" Super Ride
'95 ZJ 5.9 Stock
NYPD Jeep Club Member #2
Marine Corps Jeep Club Member #3
So I tell the swampdonkey to sock it before I give her a trunky in the tradesman's entrance and I have her lick me yardballs.
NYCXJ90 is offline
post #425 of 675 Old 04-09-2013, 08:31 AM
JAMS201075
Did this last week. 703's in my 4.0. Fresh fuel filter, mopar tune up kit and a K&N drop in filter. 200 miles later, my overhead went from 13.1 to 16.8. Haven't done the math yet. Great upgrade. Almost has tha fresh motor zip to it.
BTW: used reman injectors off ebay. $100
JAMS201075 is offline
post #426 of 675 Old 04-11-2013, 05:59 PM
Primordial
Would there be any benefit or problem with converting to uscar injectors using plug and play adapters such as those found on ebay? I recently picked up four different types of Ford 24# blue injectors and am debating on which set(s) to keep and which to sell. Here's what I have:
Denso F55E-A2E === out of a 2nd gen Lincoln Mark VIII 4.6 DOHC (basically same as a Cobra) - single pintle type w/Jetronic connector
Bosch 0280150947 === Ford p/n F1TE-D9A (4 hole Jetronic)
Bosch 0280155715 === Ford p/n F5DE-B5A (4 hole Jetronic)
Bosch 0280155849 === Ford p/n XF1E-A5B (4 hole USCAR)
One thing I noticed is that although all three of the Bosch injectors have 4 holes, the holes are much closer together on the 947 which uses the same pintle cap as the Denso injectors (which practically look identical to the 947). From what I've read elsewhere the 947 style is known as a Bosch type 1 or type 2 - not sure of the difference - and the 715 and 849 style are Bosch type 3 (sorry if it was covered here but 29 pages is a bit to read through without stuff starting to blend together).
Primordial is offline
post #427 of 675 Old 04-11-2013, 06:47 PM
PeteNnewburg
I would try to keep all injectors of the same type in the engine. There are too many variables in injector performance (spray pattern, ohm resistance) plus adding adapters to mix and (try) match.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #428 of 675 Old 04-11-2013, 06:49 PM
Primordial
Well yeah. Maybe I wasn't clear. I have a full set of each of those...
post #429 of 675 Old 04-11-2013, 07:43 PM
PeteNnewburg
I currently have USCAR 24lb injectors with adapters in my 98 Mustang GT. I have a CEL "misfire" code, I'm not sure if it is one of my rebuilt injectors, an adapter or a plug. The engine is new, plugs are new and I'm not a happy camper.
My next step will be new injectors without adapters.
I am also in the process of building my own injector cleaning/ testing stand.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #430 of 675 Old 04-11-2013, 07:49 PM
Primordial
If you need some let me know. The only ones I have 8 of are the Denso and the 947...they're still 24# w/Jetronic and I can include the parts to rebuild them or I could rebuild them before I send them. PM if you're interested...I'm sure we could work out a very favorable deal.
post #431 of 675 Old 04-11-2013, 09:08 PM
PeteNnewburg
I would be interested in a set of EV3 - 6 19lb's, set of 8. Due to health issues, ( I had a double hernia repaired as well as my RH knee rebuilt). I "farmed" the PI head swap on my '98 GT to a friends garage. He gave me a price, I was OK with it so they started. It was like having my house built all over again, if it was not this, then it was that, a cluster F___. My New PI heads from a East Coast Ford dealer's Ford Racing Department, were perhaps not new - purchase date to build date was too late to complain. The cam in one head would not turn, it had apparently been dropped on the cam cap. The cams are so radical that the valves hit the pistons. #2 set of torque to yield head bolts went to install a stock set of non-PI heads. Then came the anouncment that my NEW BBK headers did not fit, ..ya right. After 5 minutes of inspection, it was noticed the motor mounts were broken, mind you the installation instructions describe unbolting the mounts, lifting the motor to install.
My bill now doubled, I said just install the exhaust, I'll finish the motor. On the way home (2 miles), my $700 Basanii exhaust melted the plastic zip ties and fell off.
I no longer need 24lb injectors, 19's will be fine. I adapted the PI aluminum intake, headers are good as well as exhaust but the PI heads are for sale as well as the cams. To think I was going to ask them to install a 32V Cobra motor, thats still on the stand.
On a brighter note, I do have the '95 ZJ front signal harnesses ready for you.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #432 of 675 Old 04-11-2013, 10:57 PM
Primordial
Man...to say that sucks just doesn't say enough. I may have a set of 19's as well but will have to check. Send me a PM tomorrow to remind me if I don't let you know...and we'll firm things up with those harnesses.
post #433 of 675 Old 04-14-2013, 09:04 PM
justbob
the 703 injector from the mopars , are they from a auto or manual trans ? I'm going to get mine from a junk yard and I need to know before I start pulling parts off. I would think they are from a auto since the listing has some vans in it. thank you much.
Once you can accept the universe as being something expanding into an infinite nothing which is something, wearing stripes with plaid is easy
justbob is offline
post #434 of 675 Old 04-15-2013, 03:52 AM
ejschultz
ejschultz's Avatar
If you're going to get the 703s from one of the 4 banger Stratus's or Cirrus's, you can read them before you disconnect anything. Same for Neons. I found they're way more prevalent on Stratus's and Cirrus's than Neons.
97 ZJ - 5.2L, 242, 4" IRO lift w/short arms & adj. TBs, JKS Discos/BPEs, DT3000s, Aussie'd 44A, sliders, bumpers, bunch o' skids, 31" Duratracs on 15x8s
Build
ejschultz is offline
post #435 of 675 Old 04-15-2013, 01:53 PM
DickDickle
What basic tools do you need to remove them from a stratus or cirrus? Heading to the junk yard on saturday
DickDickle is offline
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
