The Definitive Injector Swap HOW TO - Page 27 - JeepForum.com
post #391 of 676 Old 03-03-2013, 08:12 AM
torchd
2003 WJ
Originally Posted by coralman
Torchd, I need some good pics of your front pipe, including where it attaches to the header, so I can say"see like this" to the exhaust dudes.
I'll see what I can do about getting you some good pics of the front pipe!!
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #392 of 676 Old 03-03-2013, 08:28 AM
Primordial
What's a good price for junkyard 703s? They want about $10/injector around here.
Primordial is offline
post #393 of 676 Old 03-03-2013, 08:40 AM
PolkaPower
I paid around 5 bucks per injector.
PolkaPower is online now
post #394 of 676 Old 03-03-2013, 09:31 AM Thread Starter
zander21510
Originally Posted by Uniblurb
Not necessarily true since if you look back at the first post in this thread (towards the middle) it's confirmed for some users the 703's work for 93-95 with the 39psi system. In fact that's what zander21510 w/95 4.0 who created this thread is running.
http://www.jeepforum.com/forum/f13/d...p-how-1305456/
The key is making sure all your injectors are good, and resetting your computer fully. You can leave the battery unhooked overnight or unhook it and hold the ignition in the start position for 30 seconds or so. Mine worked immediately after install.
zander21510 is offline
post #395 of 676 Old 03-03-2013, 09:35 AM Thread Starter
zander21510
Originally Posted by torchd
I still haven't been added to the list lol.
I have the new 4.0 manifold, 703 injectors and a header. Jeep runs perfect
Added you on
post #396 of 676 Old 03-03-2013, 09:39 AM
Scopez
1994 ZJ
So turn the key to the start position after you unhook the battery? What exactly does that do?
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #397 of 676 Old 03-03-2013, 09:48 AM Thread Starter
zander21510
Drains the rest of the current out of various capacitors and circuits inside your computer so it erases all its memory. It has a little grace period after you unhook the battery before it loses its memory. I'd say if you can leave it undone overnight so you know its completely dead.
post #398 of 676 Old 03-03-2013, 09:50 AM
Scopez
1994 ZJ
Ah okay. I gotcha. I'll probably be ordering some new 703 injectors soon.
Scopez is offline
post #399 of 676 Old 03-03-2013, 10:06 AM
RJZJ
Ok just did the 703 swap on my 93 4.0 last night, idles a lil rough and runs like sh*t driving, running rich also, I saw the post about driving to give the pcm time to "learn" the new injectors. OK not a prob put 30 miles on it today and same running characteristics so far.
Here is my question/problem, Have any of you guys had a hard time starting after the swap, I have to hold the pedal down to get it to start after it sits for about 5 minutes, if I start it let it run and cut it off and start it back immediatly no problems, but after sitting it wont start right up. Any thoughts?
93 ZJ, 3.5 RC lift, 31x10.50x15, 3/4 coil spacers, bilstein 5100's, Kolak 2.5 exhaust, 703 injectors, bedliner paint job, clear front lights , Black Magic's on bumper and a pillars
RJZJ is offline
post #400 of 676 Old 03-03-2013, 10:32 AM
hrtk
Did you get junkyard injectors? maybe one of the injectors is stuck open..
I put the 703s in my 5.2l, when I started the engine for the first time it was a little rough and eventually cleared itself out. I noticed a very small power gain, and smoother idle.
hrtk is offline
post #401 of 676 Old 03-03-2013, 01:50 PM
torchd
2003 WJ
Added you on
About darn time lol
2002 Trans Am
torchd is offline
post #402 of 676 Old 03-03-2013, 02:45 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Thanks man, i appreciate it!
Originally Posted by HighLonesome
coralman is online now
post #403 of 676 Old 03-03-2013, 07:25 PM
RJZJ
No I bought new injectors
RJZJ is offline
post #404 of 676 Old 03-04-2013, 06:18 PM
Primordial
Well I returned the 703s I paid too much for and got two sets of 8 injectors from another junkyard that I get better deals at...one set is of the 710 variety and the other are the blue top 24# injectors out of a 32 valve DOHC Lincoln. The blue tops are the single pintle type but can flow a bit more if I'm not mistaken. Would these be too much for the 4.0 though? With either of them I was thinking about getting a set of injector rebuild kits since some of the pintle caps have seen better shape and I figure why not freshen them up before I drop them in. What are your thoughts? Go with the 710s or the blue tops? Or go with the 710s now and the blue tops later after some mods are done?
post #405 of 676 Old 03-04-2013, 06:52 PM
Uniblurb
Uniblurb's Avatar
Thanks for the heads up and not sure if I left the neg cable unhooked overnight or not. Didn't know about turning the key over for 30 secs and real good tip. Regardless, the 703's are working real well now so I'm happy.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
