The Definitive Injector Swap HOW TO - Page 2 - JeepForum.com
post #16 of 676 Old 12-25-2011, 04:27 PM
ZeeJay1997
Originally Posted by MilanJeep View Post
Also, it's incorrect to say the O2 sensors are adjusting to a 14.7 to 1 air fuel ratio.
No one here said that.
there is no way for the PCM to learn an injector size
I didn't say that, although the OP did. I think the OPs intent was to inform the unknowing that the PCM may need to adjust its injector pulsing (fuel trim) .
Thanks for the information. I'm done
ZeeJay1997 is offline
post #17 of 676 Old 12-25-2011, 04:45 PM Thread Starter
zander21510
No worries, I updated the wording to be accurate. That is what I wanted it to be, accurate lol. So people can not only do the swap, but understand why it is a benefit and why they are doing what they are doing.
zander21510 is offline
post #18 of 676 Old 12-25-2011, 05:16 PM
hdrocknroll
So! which vehicles injectors are easiest to pick off at the bone yard?
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #19 of 676 Old 12-25-2011, 05:21 PM Thread Starter
zander21510
The 703s were a piece of cake, 2 bolts off the chrysler cars and they're out. IIRC I read that some of the ford engines are in such a way where its a real PITA to get to them. But I didn't really look at ford injectors. I would say whatever you can find first lol. As long as they are all of the same type!
post #20 of 676 Old 12-25-2011, 05:29 PM
hdrocknroll
I can probably find what I need with 20 junk yards within 10 min of my house
post #21 of 676 Old 12-28-2011, 06:26 PM Thread Starter
zander21510
Here are the procedures for the injector swap on a 5.2/5.9 courtesy of 1SASjeepster:
Originally Posted by 1SASjeepster View Post
The job will take about two hours. You will smell like gasoline when you are finished, so keep that in mind with clothes and safety glasses. Also ONLY DO THIS UPGRADE WITH A COLD ENGINE!
REPLACING THE FUEL INJECTORS
FIRST, disconnect the negative battery cable and tuck it down on the side of the battery with a rag keeping it there. This job will have gasoline fumes throughout the engine compartment. You must make sure that the battery cable cannot touch the negative post whatsoever. Remember sparks ignite gasoline fumes easily.
SECOND, remove the air cleaner assembly. Since I don’t have a stock one, you have to do this on your own.
THIRD, remove the “A” bracket at the rear of the air compressor. All you have to do is loosen it so that it can pivot out of the way. Remove the top “A” bolt and the lower right corner “A” bolt... from the perspective of looking directly at it with your knees leaning on the front bumper. Loosen the lower left corner. Now pivot the bracket towards the passenger side as far as it will go. That’s it. It prevents you from getting full access to the driver’s side fuel rail.
FOURTH, unplug the three sensor plugs on the throttle body. There is one in front, one on the driver’s side and one at the rear. All three plugs are removed by gently pressing down the tabs while pulling. These plugs get very brittle. BE GENTLE. You do not want to damage them.
FIFTH, unbolt the throttle body. Do not remove or disconnect any of the throttle cables are linkages. It is not necessary. All that has to be done is that the throttle body needs to swing out of the way of each fuel fuel rail as you are lifting it. There are four bolts on top of the throttle body that hold it to the intake manifold. Remove these bolts and be careful lifting up the throttle body because you don’t want to damage the thin gasket underneath it.
SIXTH, release the fuel line pressure at the driver’s side fuel rail. The fuel line pressure port is at the midpoint of the rail, next to the throttle body. It has a cap on it. (If your vehicle does not have this “pressure port” you need to find out how to relieve the pressure before you do anything.) I just used a small baby food jar and put it under the port. With my safety glasses on and my baseball hat, I used a large Phillips screwdriver and pressed down on the nipple. The gas flowed out of the nipple into the jar. When it stops flowing, you’re done, but remember there is more fuel in the line, just not under pressure. (Whenever I suspect gasoline might "shoot out" I wear safety glasses and a baseball hat. I have had gas in my eyes before. It isn't pleasant.)
SEVENTH, now remove the driver's side fuel rail, BUT BEFORE YOU DO... you need to realize a few things. (1) There is a vinyl/ plastic tube connecting both fuel rails which runs around the rear of the throttle body. DO NOT KINK THIS LINE, DO NOT DAMAGE THIS LINE. DO NOT PUT HOSE CLAMPS ON THIS LINE. This is considered a “non serviceable” item. If you damage it, it has to be replaced in its entirety. It is OK because you have just enough clearance to get the injectors out. Just be careful. (2) There is a fuel line connecting to the driver’s side fuel rail. (This is the "feed line" coming from the gas tank.) You do not have to remove this. Just be careful when you start handling the fuel rail. (3) Remaining gasoline will run out of the rail every time you pull out an injector. Have rags ready to wipe this up.
The fuel rails are held onto the intake manifold by two bolts. Remove the two bolts on the driver’s side fuel rail. Now grab the fuel rail and gently move the rail left and right, and to and fro. The idea is to do this gently. Once loose, pull the rail straight up. The injectors are vertical. Pull straight up. (Now, the rear of the fuel rails will not pull far up because of the vinyl fuel line connecting both rails. That is OK. You will have more than enough clearance. If you can’t pull them straight up, use a large, flat bladed screwdriver and pry up. Be careful what you rest the screwdriver on before you pry. You can break things like this, so be careful and think it through.
Once the fuel rail is up, you have four injectors connected to the fuel rail by thin sheet metal clips. Use a flat bladed screwdriver to remove the clip. The clip is shaped like a “square U” so work it off and then the injector pulls out. Notice how the clips come out because that is how you need to put them back during installation. The fuel injector holes in the intake manifold are tapered and mine were very clean.
EIGHTH, Remove all of the injectors from the driver’s side rail. Put them aside and get four of the replacement injectors. Use some oil to lubricate both “O” rings on the injector. This makes is a lot easier to get the injectors back in.
NINTH, Now the fun part... the only problem I had with this swap was getting the new injectors into the fuel rail. They were a PITA... but doable with patience. I found out that once you press the injector in a certain amount, that it just snaps in... but getting to that point is something else. I tried twisting them, pushing while twisting, etc., etc. If you find a great technique, LET ME KNOW!! Anyway, you will do better starting at the rear of the fuel rail. Once the injector is in, put the clip on. The clip fits in a thin groove cut into the injector body. It just presses on with finger pressure. Once you finish putting in the four injectors with their clips, start pushing down the fuel rail so the injectors go back into the holes in the intake manifold. You need to gently manipulate the injectors so each line up perfectly in the holes. You do not want to tear the “O” rings on the bottom. Once you have them in the holes, push the fuel rail down and they should center on their own. Now install the two bolts that hold the fuel rail to the intake manifold. You are now finished with one side. Go to the passenger’s side and repeat.
TENTH, Once this is all done, hook up the “A” bracket to the air compressor again. Install the throttle body, install the plugs for the three throttle body sensors, put on the air cleaner assembly and make sure there are no puddles of gasoline on your engine, intake manifold, exhaust manifold, etc., etc., Reconnect the negative cable to your battery. Now turn the key “on” but don’t start your engine yet. This will get the fuel pump to pressurize the fuel rails. (I gave it five seconds.) Now start the motor. My motor was idling rough at first, due to the fuel that was dumped into the holes in the intake manifold when I pulled the injectors. However, once the engine settled down, IT WAS GREAT!!! The computer had to "learn" again, so I took it for short run (20 minutes). There were no more sluggish response and the engine was running great. I was at 70 mph and punched it. Usually there is a sluggish response. Now it pulled unbelievably. I took my foot off the pedal at 90 mph, but I had plenty more to go. (Oh. please note... NOBODY WAS ON THE ROAD WITH ME ON THIS STRETCH OF HIGHWAY.) I drove it around some more on errands, and my starting problem was gone. It idles more smoother and the engine’s response is so much better. My fuel consumption was 15 mpg. Now it is 21 mpg. This swap worked for me.
post #22 of 676 Old 12-30-2011, 03:15 PM
neonhomer
Question - I have 8 of the 703 injectors.. 0280155703... Some of them don't have the little caps from the tip. I was going to order the injector rebuild kit for the injectors, which have the o-rings and everything. Question is... is this the right kit? According to the bosch part # above, this is a EV6 type injector, but that kit is for a EV3 injector.
NeonHomer
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
neonhomer is offline
post #23 of 676 Old 12-30-2011, 05:44 PM
1SASjeepster
Zander,
Fantastic write up! Truly you have organized all of the data in one great thread. If anyone can't do it after your thread, they need to pay a mechanic!! Great job! I am sure it will help many jeepers.
Take care and have a safe New Years.
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #24 of 676 Old 12-30-2011, 07:07 PM
torchd
2003 WJ
Yup I need to find me some "703" injectors and swap them in
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #25 of 676 Old 12-30-2011, 07:33 PM
extrememarine
1994 ZJ
Stratus / Breeze / Cirrus
I pulled 12 injectors today at a local pick'n'pull yard. The Dodge Stratus / Plymouth Breeze / Chrysler Cirrus with the 2.4L were definitely the easiest to pull - as stated - 2 bolts, pry the fuel rail out, unplug the harness and twist them out of the fuel rail. By the third car, it took less than 4-5 mins.
Thanks for putting the time and effort into a detailed write up on this.
Semper Fi,
Extrememarine
extrememarine is offline
post #26 of 676 Old 12-30-2011, 07:43 PM
General_Jeep
1994 ZJ
I did this swap and it seemed to do wonders for my V8. I took the injectors out of a Crown vic i believe it was a 1995 I was just looking for the right connector type. I couldn't find any with the 703's or 715's but I believe this is due to elevation. I put in some yellow Injectors in place of the POS ones that were there. I have been enjoying my idle and more power ever since.
1994 Jeep Grand Cherokee 5.2L V8- NV3500 - Blown D35 8.8 replacement some day.
2010 Jeep Patriot 5 speed manual-- DD, 27-31MPG :D
1996 Dodge Ram 1500 - Work Truck/Plow 5.2L NV3500
2005 Nissan Titan - Hauler
"The Jeep is Americas only real sports car!" - Enzo Ferrari
General_Jeep is offline
post #27 of 676 Old 12-30-2011, 08:04 PM
MilanJeep
MilanJeep's Avatar
If anyone needs neon injectors for their Jeeps PM me, I raided all the yards around my house and have enough for at least 4 V8 vehicles I believe. I already OHMed them all out too and matched them impedance wise for consistency. Not trying to make a killing on these I just want to help Jeepers who are having a hard time finding these and don't want to spend a millions dollars online.
98 5.9 ZJ - 4.5" lift, 33x12.50 MT/R Kevlars
02 Z06 - Supercharged, E85, lots of rwhp, built and tuned by me
Milan
MilanJeep is offline
post #28 of 676 Old 12-31-2011, 06:11 AM
torchd
2003 WJ
You want to sell 6 of them
2002 Trans Am
torchd is offline
post #29 of 676 Old 12-31-2011, 07:00 AM Thread Starter
zander21510
that is the correct kit, they fit on both.
post #30 of 676 Old 12-31-2011, 04:29 PM
extrememarine
1994 ZJ
Injectors
Mine are going into a 318 - so I need 8. I ended up take 10 total - so I've got 2 spares right now. Let me know if you need a set, I can go back and get more.
Semper Fi,
Extrememarine
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
