The Definitive Injector Swap HOW TO - Page 17 - JeepForum.com
post #241 of 675 Old 05-14-2012, 02:12 PM
KyBoy1991
What am I going to gain if I purchase the new ones vs. the ones the JF vendor is selling as rebuilt/re-newed???? IF they have new screens, rings, lintel....isn't that essentially a new injector? Cause $10ea is sounding too good to pass up vs. $25 ea.
KyBoy1991 is offline
post #242 of 675 Old 05-14-2012, 02:29 PM
Proph2010
1994 ZJ
Im in the same bout as you are, youre getting new plastic thats it IMO...maybe some piece of mind that its new...IF it was coming from a walk in business, the whole ebay thing has never sat to well with me with impression of quality goods for cheap...because in all reaity 25 dollars is super cheap than what advanced auto sells these puppies new for, the sell them for like 150 a piece... makes me wonder how "new" his are as well...
At any rate mine have been in my jeep since 1994 they work just fine, im sure newer injectors used, cleaned, with important components replaced new will work just fine.
Proph2010 is offline
post #243 of 675 Old 05-15-2012, 12:18 AM
zturn13
well i got my new injectors they look great printed off the walk thru (have read it several times) is there any last minute advice I'm getting up early and doing this and hopefully will be done in time for work lol
zturn13 is offline
post #244 of 675 Old 05-15-2012, 12:20 PM Thread Starter
zander21510
Just take ur time and ull be fine! Good luck
zander21510 is offline
post #245 of 675 Old 05-15-2012, 01:51 PM
zturn13
ok so all went well with all the help from my gf and everyone on here and my trusty service manual.
My gf loves taking pictures so i have included some that she took
The hardest part was the driver side font two wouldn't hardly get out or go back in the rest was a cake walk
turning the injector makes it a lot easier to take off the clip
the comparison between the new and old injectors
my service manual said to oil the o-ring with some engine oil and boy did that make things easier
having it backwards to put the clip on makes thing easier also
and there we have it they are on when i turned the key to the on spot and waited about 45 seconds then off and on few more times then stared it and it and she ran really rough for the first few seconds and then started running smoother and now she runs great idles smother and throttle responds way better so i can confirm it works on a 98 jeep grand cherokee 5.2 v8
zturn13 is offline
post #246 of 675 Old 05-15-2012, 02:18 PM
divco13
Having read this entire post below.
http://www.jeepforum.com/forum/f13/d...p-how-1305456/
This post is a wealth of very good info.
Still want to ask ?
Has any one had any good improvement's with a injector swap on a 1998 5.9
Bob
divco13@aol.com
http://oldcarandtruckpictures.com/Divco/BobPatterson/
http://www.facebook.com/pages/Divco-Milk-Truck/102362503162366
divco13 is offline
post #247 of 675 Old 05-15-2012, 02:44 PM
dean477
Who is selling them for 10?
dean477 is offline
post #248 of 675 Old 05-15-2012, 08:03 PM
KyBoy1991
In the classified section....6 remans for $55. So I guess that's a little less than $10 ea
post #249 of 675 Old 06-05-2012, 11:32 AM
Tbone18
The ford 715 injectors do not work! My jeep runs terrible with them
Tbone18 is offline
post #250 of 675 Old 06-05-2012, 12:39 PM
Proph2010
1994 ZJ
When changing the injectors to 703's or as I my case 710's do I need to be concerned to altering spark plug gap or any other electrical/spark/ignition timing issue.
post #251 of 675 Old 06-05-2012, 12:57 PM Thread Starter
zander21510
Nope its just a straight swap
post #252 of 675 Old 06-05-2012, 05:18 PM
Proph2010
1994 ZJ
You think it would need adjustment really, everything is so precisely designed and timing is important, I know we're not changing the fuel amount too much just spray pattern but I would think that would affect timing of the spark and combustion etc...
post #253 of 675 Old 06-08-2012, 12:01 PM
dpshoup
2011 WK
can anyone tell me what size head is on the bolts that hold the 710s in to the fords? dont want to have to make a return trip to pick n pull...
HT1 (SW/AW) USN RETIRED (HT-4946)
24 Jun 81-30 Jun 01
ASNT NDT Level III (VT, MT, PT)
02 WJ-4.7 My DD [04 WJ-4.0, 00 XJ-4.0 Gone]
03 WJ-4.0 Dau #1 DD
93 ZJ-5.2 Dau #2 DD
USN Jeep Club #153
dpshoup is offline
post #254 of 675 Old 06-26-2012, 09:19 PM
ozzy_2_me
1994 ZJ
ok, i went to the junkyard today and found some 710 injectors to try out this swap to see what all the fuss is about. to answer dpshoup's question it's a 8mm deep socket. and bring a flat screwdriver with you. that's all you need. I was luckey enough to find a set of 710 injectors that look practicly bran new. when i pulled them out they where like super clean. when i got back home i switched them out, turned the key on and off a couple times and left the key on and then went to check to see if there was any fuel leaks. all was good so i started it up and started a litttle rough then smoothed out. like really smooth out. this is the smoothest idle i have very seen/heard from this jeep. i let it idle for about 15 minutes and while it was idling i was still looking for any fuel leaks. still couldn't see any. i guess it is good thing. after that i shut it off restarted and took it for a spin. i can report that it has better thottle response and as for any increase i gas mileage it is to early to tell. i will report back in a couple days of driving. the one thing i think that is lacking so far in this thread is a vehicle list for the 710 injectors. i totally forgot which vehicle it was that i got mine from other then it like a grand marqui or lincoln ....something like that the year was like around 96 or maybe 97. if some can chim in and maybe provide a list i think that would greatly help this thread and all the guy's and gals out there with the 5.2 that want to try the 710's out. thanks again for this thread. other then the lacking info on the 710's it was a weath of info.
ozzy_2_me is offline
post #255 of 675 Old 06-27-2012, 12:12 PM
johnt671
I did this swap just before I retired, so I'm not driving as much as I was, put still drive in the area. Driving up the mountain and going to work, my average MPG always showed 15.6 or 15.7. The trip home always showed 16.6 or .7. My over all average was 16.7.
The five days I drove to work after the swap it never went below 16.3, And the trip home showed 17. or 4 or 3. The first tank showed 17.3 and the second tank showed 17.4. So my net gain so far is between .6 and .7 MPG.
johnt671 is offline
703 , 715 , ford , fuel injector , neon , swap
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
