The Definitive Injector Swap HOW TO - Page 13 - JeepForum.com
 1Likes
post #181 of 678 Old 04-12-2012, 07:57 AM
BoostinChick
Originally Posted by rb2biker View Post
Did I miss something related to the intake? Why 99 or later?
Part of the OP's sig
1995 Jeep Grand Cherokee; 192,000 miles (3/16/12)
191k: 2/18/12; 190k: 12/31/11
Current mods: 703 injectors(my howto), intake modification, 99+ intake manifold (my howto), Cherry Bomb glasspack.
It is not directly related to this thread in regards to the injector upgrade. But since you will need to remove the fuel rail anyway to do the intake manifold why not do both mods in one shot?
1998 Jeep Grand Cherokee 5.9L
BoostinChick is offline
post #182 of 678 Old 04-12-2012, 09:33 AM
augiedoggy
they redesigned the intake in 99 to make it more efficient which added like 10 or 12 more hp I believe... thats why the factory HP ratings jumped in 99...
augiedoggy is offline
post #183 of 678 Old 04-12-2012, 09:57 AM
Tbone18
Yea i think im going to swap the 715s out and put the 703s in instead. It runs terrible and ive done everything to fix it and nothings helped one bit.
Tbone18 is offline
post #184 of 678 Old 04-12-2012, 10:27 AM Thread Starter
zander21510
It actually went down by 5hp in 99...the redesign was done to help offset the emissions crap they had to put on because of the government but even with it it still went down...
The latter 4.0s suffered all sorts of problems from trying to get them running cheaper and cleaner...its a shame really.
zander21510 is offline
post #185 of 678 Old 04-12-2012, 02:36 PM
augiedoggy
weird everything I've read says it went from 181 to 190 hp?
post #186 of 678 Old 04-12-2012, 04:02 PM Thread Starter
zander21510
Whoops...I was thinking of between 95 and 98 from 190 to 185. My bad.
post #187 of 678 Old 04-13-2012, 05:31 AM
KyBoy1991
The 99+ inline 4.0 intakes are double the air flow of the previous models....and better design for better flow. I think the old models are something like 2.5l capacity and the new are 4.3l.
There is stuff all over youtube showing this....
KyBoy1991 is offline
post #188 of 678 Old 04-13-2012, 03:54 PM
nickszj
Well besides the M1 intake install, I just put the 703's in my 5.9. Runs perfectly!!! Idles very, very nicely... no complaints at all... so I would say that according to Auggies experince... the Dodge and Jeep 5.9's are different, because mine runs prefectly!!!
1998 ZJ 5.9 limited in white. M1 intake and $20k+ mods brewing up in my head... SOLD
Looking for the right WJ to build into an expedition rig....
nickszj is offline
post #189 of 678 Old 04-13-2012, 04:59 PM
KyBoy1991
I don't think there is such an intake for us inline guys is there?
post #190 of 678 Old 04-13-2012, 05:42 PM
dusterdude
Clicford performance has one i think will work for 400 bucks
dusterdude is offline
post #191 of 678 Old 04-14-2012, 07:00 AM
KyBoy1991
Yeah, I will go with the upullit special for $50 our less.....can't believe that one would make that huge of a difference to warrant the high price over the 99+ model
post #192 of 678 Old 04-14-2012, 07:59 AM
augiedoggy
What about the other jeep guys with the same issues? we may have all had bad injectors I guess..
The smaller ones I'm using now are working good and the figures on the scanner look good also so I'm not just guessing...however I have noticed no MPG or power gains over stock myself.. I only have 120 miles on them so well see after the pcm finishes learning and adjusting..
I will say one of the trade offs to running rich is more power so that may be were some of the claims to more power are coming from...(or the previous injectors were plugged)
What really makes my skeptical is all the claims to more power AND way better gas mileage...
post #193 of 678 Old 04-14-2012, 08:07 AM
augiedoggy
The m1 is designed for wide open throttle racing applications....
You dont really have any power gains over stock until you approach 5,000 rpm... and unless you make other accommodations to the motor for the m1 you will actually loose a bit of power and torque in the normal driving powerband vs a stock kegger.... this has been explained many times and proven with dyno results...
The Chrysler and ford and chevy engineers used the long individual runner design to tune extra torque and power in the normal powerband at the expense of some power above 5,000rpm where many of use dont even go on a daily basis so....
And before everyone with m1 style intakes get all up in a roar , yes if the engine is modified enough and can breath well enough with better heads and such the m1 can make more power in the lower rpm range than a stock engine too....(but it really isnt due to the intake but rather the other mods in conjunction to allow better breathing)...
post #194 of 678 Old 04-20-2012, 04:15 PM
KennzX
I have a quick question. I have a 99 crown Vic in the driveway it has the 4.7 can I use those injectors?
Jeep, The dirtiest of the four-letter words
Not stuck; temporarily detained
KennzX is offline
post #195 of 678 Old 04-20-2012, 04:56 PM
dusterdude
It has a 4.6
703 , 715 , ford , fuel injector , neon , swap
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
1998 zj 5.2 fuel injector swap 1SASjeepster ZJ Grand Cherokee Forum 7 12-28-2011 06:17 PM
Injector swap? ZJPRKID ZJ Grand Cherokee Forum 24 11-20-2011 04:59 PM
junkyard fuel injector swap and result karik ZJ Grand Cherokee Forum 27 07-30-2011 06:10 PM
Fuel injector swap? airwolf9090 ZJ Grand Cherokee Forum 6 06-10-2011 05:46 AM
injector swap madhappy401 ZJ Grand Cherokee Forum 0 02-17-2010 05:28 PM
