The definitive 2" BB thread - JeepForum.com
post #1 of 78 Old 08-07-2008, 07:47 PM Thread Starter
WhiteOut
WhiteOut's Avatar
Since there have been a bunch of threads started about this same topic, I figured its time to have one place for all the info.
What is it?
The 2" Budget boost (BB) uses polyurethane coil spacers to give you WJ or ZJ a 2" height boost over stock. Spacers are sold my almost every offroad company and sometime come with shocks, bumpstop extensions and extended coil spring retaining posts. The BB is easy enough to install in your home garage and should take no more than 5-6 hours.
The BB will take you Jeep from stock:
And give it a more aggressive look:
What do i need?
A budget boost is basically what it says a cheap way to lift your Jeep. Usually the whole lit can be done for less than $350-$400, depending on the parts purchased.
Parts Needed:
- 2" Polyurethane spacers (4)
- Extended shocks (4) , stock shocks can be used but will wear out faster. Black Diamond or Skyjacker shocks are generally used due to the fact that they are affordable and well suited to this lift
- Extended coil spring posts for rear coils (2) If you wheel with your sway bar disconnected you might drop a spring, either the kit or just exhaust tubing welded or epoxyed in place
- Bumpstop extensions
- Quick disconnects for the sway bar can also be added but are not crucial to the install
What size tires can I fit?
The generally accepted max tire size that can be installed after a BB is a 31" tire, with some minor trimming. There is some possibility of rubbing on steering components, especially if you install an 31x10.5 tire onto a stock rim. Wheel spacers, new wheels with correct backspacing and adjusting the steering stops will correct this problem. If you don't want to do this you can run a 30x9.5 tire and be fine.
When choosing tires and rims, keep the tire width within 4" of the rim width. eg. max tire width for a 7" wide rim is 11". Do not install a 10.5" wide tire on a 10" wide rim
What should I not do?
- DO NOT STACK SPACERS!! doing so is very dangerous
- Only do a 2", 2.25" or 2.5" spacer lift or you risk dropping a spring, spring post should be lengthened anyways.
**Thanks to spife7980 for this part**
Feel free to post up more stuff if I missed it.
For the WJ guys.
These are pictures of a WJ with a 2" BB from Fat Bobs Garage and 265/65r17 Nitto Tires. Special thanks to hammerz71 for the use of his pictures.
WhiteOut is offline
post #2 of 78 Old 08-07-2008, 09:55 PM
spife7980
very good.
you should add a do not do part.
ex) do not stack spacers
do not go over 2" as they will be lower that the spring retainers and they can very easily lose a spring etc
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #3 of 78 Old 08-07-2008, 09:56 PM
moparrr07
this should be stickyed or added to the FAQs
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #4 of 78 Old 08-07-2008, 09:59 PM
-Joe-
-Joe-'s Avatar
i would agree with the sticky if there were pics of the install..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 78 Old 08-07-2008, 10:04 PM Thread Starter
WhiteOut
WhiteOut's Avatar
Yeah I know I forgot to take pics of my install. This basically to keep people from starting 5-10 threads a week on BB's and tire size.
WhiteOut is offline
post #6 of 78 Old 08-07-2008, 10:23 PM
moparrr07
you should also mention its much easier on the install if you disconnect just the lca front bolts, unlike most instructions say
post #7 of 78 Old 08-07-2008, 10:28 PM Thread Starter
WhiteOut
WhiteOut's Avatar
Ya but getting those re-torqued is a *****. If you do it when the front end is off the ground you mess it all up.
WhiteOut is offline
post #8 of 78 Old 08-07-2008, 10:34 PM
moparrr07
yeah i guess... with the right tools
post #9 of 78 Old 08-07-2008, 11:55 PM
Mike Cooper
You say you can do a 2.5", and some one else is saying 2" max, which is it? As well, with my 2" lift, I can fit 265/75/16's with little rubbing if you wanted to add that, thanks starting this thread, would be good to get all the info on one post and add it to the FAQ as this is a common beginers lift
SOLD: 1998 5.9 Grand cherokee: Suspension: 3.5" IRO Lift, JKS Rear Track Bar & Quick Discos, IRO Double shear front track bar, Black Diamond Shocks,33X12.5 BFG Muds, ARB Front Bumper, Home made Rock Sliders, 242 Swap
New Toy:
2007 Wrangler Unlimited. 2" BB, 1 1/2" wheel spacers, 285/70/17 Goodyear Duratracks.
Mike Cooper is offline
post #10 of 78 Old 08-08-2008, 12:41 AM
CMARJEEP
CMARJEEP's Avatar
For WJ people Arlo wrote a great thread on about everything you ever need to know on WJ suspensions.
http://www.jeepforum.com/forum/f310/wj-suspension-info-thread-314066/
CMARJEEP is offline
post #11 of 78 Old 08-08-2008, 09:02 AM
ZJTechie
Well done Fraser1986brown, now we all have something to throw at those BB thread starters! x2 on the BB with Skyjackers and post extensions by the way! You might wish to add good places to get these boosts as well, I know mine came from Kevins Offroad.
ZJTechie,
My current JEEP score: 205 (see site below)
ZJTechie is offline
post #12 of 78 Old 08-08-2008, 09:05 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
The WJ is a 2.5" max and the ZJ is 2.25", maybe 2".
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #13 of 78 Old 08-08-2008, 10:11 AM
moparrr07
zj is 2.25, htat matches the spacer to the length of post extensions, the spacers do smash down after allittle driving
post #14 of 78 Old 08-08-2008, 10:13 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
no way will you be able to run 265/75R16s on a 2".... i had a 3.5" and they still rubbed a bit at full stuff.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #15 of 78 Old 08-08-2008, 10:18 AM
moparrr07
a 265/75r16 rubbed alittle bit on the bumper with 2 3/4 lift for me
W/Pics-Seeking definitive ABS/DRB Tool Answer LonnieB ZJ Grand Cherokee Forum 12 07-22-2009 06:31 PM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 07:38 PM
Another "clunk" thread - ignore the noise? (2004 WJ) JustSomeDude ZJ Grand Cherokee Forum 5 03-30-2009 10:15 AM
What is the definitive answer for a stereo DIN size.... gregwho WJ Grand Cherokee Forum 2 02-02-2009 02:39 PM
Front end clunk, the definitive answer? handee521 ZJ Grand Cherokee Forum 3 11-05-2008 05:26 PM
