Definite transmission issue. - JeepForum.com
post #1 of 7 Old 08-23-2011, 07:24 PM Thread Starter
Kurkku
Ended up changing out my Governer Pressure Sensor, to fix my "not shifting" problem. NOW, I had a long day at work. I drive home, to hear a lot of grinding, then a big clunk. My Jeep won't go forward, nor reverse. Doesn't seem to catch ANY gears. I got it towed back to my house (which was a mile away) and let it sit there. Just went outside to start it, and pulled it into my driveway before hearing the horrible *whirring* then no gears. >__<
About to throw in the towel on old ZJ and get a Wrangler. Any thoughts?
Kurkku is offline
post #2 of 7 Old 08-23-2011, 07:33 PM
sabzz
Sounds like what mine is doing, except it was perfectly fine, no slipping or anything and all of a sudden heard a grinding noise and bam, down hill from there. Mine will catch gears fine, until it gets warmed up, then it won't grab anything, but it will still idle just fine. But, I'm taking money out this week and its going in the shop next week to have it rebuilt or whatever it needs to be done. I'll let you know what mine is, I'll post it on my build thread.
1998 ZJ 4.0 work in progress/DD
'97 ZJ 4.0|3.5 RC|31" -SOLD
sabzz is offline
post #3 of 7 Old 08-23-2011, 07:54 PM
caligiuri87
1994 ZJ
hmmm i think ur chain might me loose in ur transfercase. easy to check just take it out. and if ur tc is good then look into ur tranny. if ur tc is out then u wont move. ' i believe' im replacing my tc soon i hope
caligiuri87 is offline
post #4 of 7 Old 08-23-2011, 08:02 PM
sabzz
I'm going to have the shop look at both my tcase and tranny. I've had a noise coming from the tcase for years now but never affected anything. I'm having them fix it all while its out and what not.
sabzz is offline
post #5 of 7 Old 08-23-2011, 09:44 PM Thread Starter
Kurkku
Transfer Case linkage.. Never really thought of that. It did sound like small whirring. Idk I'll look into it.
Kurkku is offline
post #6 of 7 Old 08-23-2011, 09:57 PM
sabzz
Never thought about that for my whirring problem before...the sound got worse if you moved the transfer case shifter (from side to side). I'll look into the linkage if they don't fix it at the shop next week. It was making a whirring noise at 35+ mph
sabzz is offline
post #7 of 7 Old 08-24-2011, 01:37 PM Thread Starter
Kurkku
Starting to think it's a transfer case issue. Just started my Jeep up, and drove fine, WHILE COLD. As soon as it started warming up, I notice a slight buzzing from my transfer case. I felt it, and it was shaking a little. Gonna take it apart and check everything out.
Kurkku is offline
transmission issue bigjohn1987 ZJ Grand Cherokee Forum 6 10-30-2009 04:09 AM
HELP!!! Transmission issue ezflip ZJ Grand Cherokee Forum 12 09-07-2009 08:56 AM
transmission issue edolivett ZJ Grand Cherokee Forum 4 08-07-2008 04:41 PM
01 WJ transmission issue sledneck700 ZJ Grand Cherokee Forum 5 11-10-2007 10:59 AM
Transmission issue... Firegod14 ZJ Grand Cherokee Forum 3 03-05-2007 09:09 PM
