deeper trans pan - JeepForum.com
post #1 of 9 Old 11-03-2009, 08:13 PM Thread Starter
vansskaterfreek
deeper trans pan
do they make such a thing as a deeper trans pan to hold more fluid? i think my trans burnt up from climbing hills, lack of fluid to the pump, caused the pump to stop working (now its whining badly). i was thinking of a deeper pan and maybe a longer filter to pick up the fluid in the back of the pan when the front of the jeep is pointing straight up
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #2 of 9 Old 11-03-2009, 08:46 PM
JrMechanic
Derale 14110 - Derale Transmission Pans - Overview - SummitRacing.com
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #3 of 9 Old 11-03-2009, 08:51 PM
sandman
what trans do you have? ill guess were talking 46re? im pretty sure mopar sells a deeper cast pan. not sure though. i know that the dodge a727 shares the same pan for cross reference if you have trouble finding one.
1993 Jeep ZJ. 4.0
sandman is offline
post #4 of 9 Old 11-03-2009, 08:53 PM
xJoshxx
2012 WK
Didnt search did you
http://www.jeepforum.com/forum/f13/d...n-pans-821141/
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #5 of 9 Old 11-03-2009, 11:15 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Get a skid made up. You don't want to be cracking that on the rocks.
ratmonkey is offline
post #6 of 9 Old 11-04-2009, 03:06 PM
MN_NATV
I wouldn't get a trans pan with cooling tubes in it if you ever plan on going off road. Mag Hytec makes a pan that holds 4 quarts more than stock, and has a port for a temp sensor as well. Mag Hytec Pan
They also make a slightly shallower one that holds 1.5 more quarts ATF than stock.
MN_NATV is offline
post #7 of 9 Old 11-04-2009, 04:18 PM
Travis873o
i like that one.
FOR SALE: ZJ 231 bezel. 1996 ZJ Lifted
Travis873o is offline
post #8 of 9 Old 11-04-2009, 04:54 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
I've had the the pan from yourcovers.com on my '98 44RE for a couple of years, and am happy. They give you longer bolts to go thru the thicker cast aluminum flange, but a word of warning that may apply to any of these cast replacements. The mounting holes drilled in the pan's flange did not allow too much wiggle room, due to the greater thickness. Drilling out each hole in the pan a tad, makes mounting it to the pan MUCH easier.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #9 of 9 Old 11-04-2009, 05:28 PM
Mopargearhead
B&M 10280 - B&M Automatic Transmission Deep Pans - Overview - SummitRacing.com
I have this pan on my Ram with the 46RE and I've been happy with it. It adds an extra 4 quarts and its half the price of most deep aluminum pans.
Mopargearhead is offline
Deeper Transmisson Pans. xJoshxx ZJ Grand Cherokee Forum 9 07-21-2009 02:43 AM
Trans Fluid/Filter Change, bad for trans? ddeadserious ZJ Grand Cherokee Forum 8 01-18-2009 08:23 PM
4.0 torn apart... but think i need to go deeper. help! kmd1776 ZJ Grand Cherokee Forum 6 06-23-2008 07:27 AM
Snow again...deeper this time =D *PICS* AgitatedPancake ZJ Grand Cherokee Forum 26 01-04-2007 11:14 PM
Deeper Exhaust PCuda73 ZJ Grand Cherokee Forum 3 09-14-2006 09:41 AM
