Deep-Cycle Battery - Page 2 - JeepForum.com
post #16 of 20 Old 07-15-2011, 01:23 PM Thread Starter
airwolf9090
What in these ZJ's control charge Voltage?
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #17 of 20 Old 07-15-2011, 01:30 PM
MONSooNmonkey
Originally Posted by airwolf9090 View Post
Well the reason why i am wondering is because i have something draining the life out my battery over night (Think its the body ground controller) And i have an old deepcell in my camper and i been thinking about using it because it can handle the draining that is happening so i don't ruin the battery i have in the Heep right now.....
I think fixing the cause would be a better way to go about this than covering up the symptom.
Clean all your leads off, check the fuse panel one may have blown but not entirely 'blown' if you get what I mean.
Sadface :(
MONSooNmonkey is offline
post #18 of 20 Old 07-15-2011, 01:55 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
what in these zj's control charge voltage?
pcm
HighLonesome is offline
post #19 of 20 Old 07-15-2011, 03:34 PM Thread Starter
airwolf9090
Thats what i thought controlled it. Is there a way to adjust it because the way it is right now if i run even just the AC the battery keeps getting weaker and weaker till it starts dieing at idle But if all i am running is the engine and cooling fan it doesn't weaken the battery.
1996 Jeep ZJ Orvis
post #20 of 20 Old 07-15-2011, 03:51 PM
HighLonesome
Check the charging voltage with a meter. It should average around 13.8 vdc. Sounds like you may need an alternator.
Drive cycle anticrombie ZJ Grand Cherokee Forum 8 12-15-2013 02:20 PM
Drive Cycle on a WK Natemare13 WK Grand Cherokee & XK Commander Forum 10 04-02-2012 05:36 PM
Normal for A/c Compressor to cycle on/off when idling? AllGoNoShow ZJ Grand Cherokee Forum 8 11-21-2010 06:34 PM
need to cycle the ignition for my tail lights ivel ZJ Grand Cherokee Forum 4 08-27-2003 06:11 PM
Idle cycle vngdh ZJ Grand Cherokee Forum 0 06-30-2003 09:28 AM
