Deep-Cycle Battery - JeepForum.com
post #1 of 20 Old 07-13-2011, 01:25 PM Thread Starter
airwolf9090
Deep-Cycle Battery
What do y'all think of using Deep-Cycle Batteries in ZJ's?
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #2 of 20 Old 07-13-2011, 01:42 PM
MONSooNmonkey
I think using a regular marine grade deep cycle battery as a starter battery is dumb.
I think using a dual purpose deep cycle\start battery is a good idea.
I think doing a dual battery setup with a deep cycle as the second battery is a good idea.
Sadface :(
MONSooNmonkey is offline
post #3 of 20 Old 07-13-2011, 02:25 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I ran the biggest one Costco sells. Lasted under 3 years. Just died one day the weather changed and wouldn't take a charge. Deep cycle won't hold up to starting and running chores. They are designed to be run into the ground and then charged back up.
HighLonesome is offline
post #4 of 20 Old 07-13-2011, 02:28 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
what they said. deep cycle batteries don't handle small draw and recharge cycles very well.
ratmonkey is offline
post #5 of 20 Old 07-13-2011, 02:38 PM
MONSooNmonkey
You have to 'exercise' them, meaning kill\recharge from dead every so often.
As the others have stated.
Sadface :(
post #6 of 20 Old 07-13-2011, 06:22 PM
CrzyMtnMan
Agree, deep cycle is not for this application. If you plan to use vehicle accessories while the engine is off, just look for a standard battery with an increased reserve capacity.
1996 ZJ - That 2nd Oxygen sensor, yeah some serious butt connectors and heat shrink there, how is that for off road modification! - Still stock.
CrzyMtnMan is offline
post #7 of 20 Old 07-13-2011, 07:39 PM
stormer1092
1994 ZJ
i have a deep cycle in mine also a 600w amplifier and it runs it just fine. I can run my stereo even longer with the deep cycle.
stormer1092 is offline
post #8 of 20 Old 07-14-2011, 05:14 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Unless you are draining the battery to zero often, you are shortening it's life potential.
post #9 of 20 Old 07-14-2011, 07:47 AM Thread Starter
airwolf9090
Well the reason why i am wondering is because i have something draining the life out my battery over night (Think its the body ground controller) And i have an old deepcell in my camper and i been thinking about using it because it can handle the draining that is happening so i don't ruin the battery i have in the Heep right now.....
1996 Jeep ZJ Orvis
post #10 of 20 Old 07-14-2011, 08:16 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I think a multimeter and fuse puller would be a wiser investment right now.
post #11 of 20 Old 07-14-2011, 09:42 AM Thread Starter
airwolf9090
Like i said i got it just siting here doing nothing atleast it will stand up to it while i try and sort out that problem. its my DD so i can't just like it be down i still have to drive it.. Right now i got the #7 fuse pulled and its not draining it...
1996 Jeep ZJ Orvis
post #12 of 20 Old 07-14-2011, 06:04 PM
CrzyMtnMan
Tossing in a side note about batteries. I know one day this will haunt me, perhaps in the morning, however in 2003 I picked up a battery from Advance Auto Parts for my Subaru, 3 year pro rate, etc. I tend to use the car radio when I am outside working alot, and this has become a sick project. I still have that same battery today. No maintenance since then, the thing just works, it was the cheapest battery they had at the time, and although only starting a small turbo 4 cylinder, I am going to keep this thing until it does finally die one day. Passes the load test every service.
post #13 of 20 Old 07-14-2011, 07:31 PM Thread Starter
airwolf9090
Okay i got another Alt from the junkyard i didn't change the pully (Just one less rib) I just put it on to test wasn't leaving it on long enough to damage anything and when i ran it my mulitimeter showed the battery was getting the same voltage as with the other Alt. around 13.2V so i swap the alt's again putting the old one back on and i drive to the store going i had everything off and the gauge needle was near 14V but still below it so i get to the store shut it off and go in when i lefti turn on my radio, AC, headlights on with fog lights and my cooling fan now going down the road doing 65 i watched as my battery gauge starts dropping and i keep on like that and when i get home i pop the hood and hook my MM to the battery to see how many volts its getting and it was at 12something and so i turn everything off but leave it running and its back up but only 13.3V am i right in thinking my Alt is bad and the people at advance that tested it is just wrong? below is some show and tell. lol
With everything on like i said going down the road this is what my gauge looked like but with just it running and nothing on its almost to 14 like a hair off...
http://imageshack.us/photo/my-images...411195020.jpg/
this is the reading at my battery with just the engine and cooling fan running.
http://imageshack.us/photo/my-images...911195010.jpg/
and this is the reading i got from the battery when i had everything on.
http://imageshack.us/photo/my-images...911201820.jpg/
1996 Jeep ZJ Orvis
post #14 of 20 Old 07-14-2011, 07:52 PM
JrMechanic
Those readings look perfectly fine...
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #15 of 20 Old 07-14-2011, 08:16 PM Thread Starter
airwolf9090
If they are fine then why is it if i drive to town 10miles with just the AC on pull up to a gas pump leaving it running start pumping gas and it dies and i go to start it right back up the battery is too weak to start it but if i repeat with the AC off it will sit there and idle while pumping with no problems or even shut it off it starts right back as strong as can be????
1996 Jeep ZJ Orvis
Drive cycle anticrombie ZJ Grand Cherokee Forum 8 12-15-2013 02:20 PM
Drive Cycle on a WK Natemare13 WK Grand Cherokee & XK Commander Forum 10 04-02-2012 05:36 PM
Normal for A/c Compressor to cycle on/off when idling? AllGoNoShow ZJ Grand Cherokee Forum 8 11-21-2010 06:34 PM
need to cycle the ignition for my tail lights ivel ZJ Grand Cherokee Forum 4 08-27-2003 06:11 PM
Idle cycle vngdh ZJ Grand Cherokee Forum 0 06-30-2003 09:28 AM
