-   -   Decoding transmission identification number (http://www.jeepforum.com/forum/f13/decoding-transmission-identification-number-1530619/)
Flatland88 05-31-2013 12:53 PM
I'm having trouble decoding the identification number on a transmission I purchased for my 96 Grand Cherokee.
Here are the numbers from the side of the transmission: PK521191082445 5341
The seller said that it is 46RE which should work according to comments I've found on the forum, but I wanted to verify that I have the correct transmission. It is mated to an NP249 TC. I simply haven't been able to locate a chart that breaks down the numbers. Does anybody have the secret decoder ring? Thanks.
tucsonzj 05-31-2013 02:25 PM
welcome!
fill out your jeep info here
so we know what you have besides a 96 ZJ.
Simplest way to find out, do a VIN breakdown, or Chrysler will send you your factory build sheet for free!
here's a vin decoder, if it doesn't give you tranny, somewhere on Chrysler site there's a way to get your build sheet, or call your dealership
http://www.jeepvindecoder.com/
There is a good chance you have the 46RE but I dont know for sure.
Flatland88 05-31-2013 03:18 PM
Thanks for the quick reply. I added a little more info to my profile as you suggested. I'll add more later but the keep is currently completely stock.
I don't have the vin number of the donor vehicle. I've been able to find places that show where to find the transmission identification numbers, but nowhere that breaks it down enough that I can verify that I bought a 46re.
tucsonzj 05-31-2013 03:35 PM
Sorry, hopefully someone else will know better then me. I'm not sure of model break downs on trannys
Flatland88 05-31-2013 04:45 PM
That's ok, I don't expect anyone to have all of the answers. I probably should have called and asked the dealer before the start of the weekend.
dusterdude 05-31-2013 05:44 PM
Is the right rear corner of the pan cut off? Or does the right front corner have a dog leg in it? Either answer will tell us what you have
dusterdude 05-31-2013 05:51 PM
2 Attachment(s)
Attachment 633060
Attachment 633061
1st pan is 46 and second is 42
kensnelling 05-31-2013 06:14 PM
Believe the seller may have told you wrong. That should be a 44RE for a 96-97 5.2L Grand Cherokee. Double check with you local dealer for a Chrysler PN 52119108.
Ken
Flatland88 06-01-2013 08:34 AM
You're right Ken, after work I was able to check my original transmission which is a 44RE. Sure enough, the numbers start off PK52119108.
Thanks for all of the comments. Even though I'm new posting here, I've found this forum invaluable resource of information for the past couple of years that I've had this vehicle. You guys will never know how much you've helped others by sharing your knowledge.
And dusterdude it looks like the 42RE and 44RE use the same pan: http://www.yourcovers.com/transmissi...mages/9862.PDF
dusterdude 06-03-2013 06:01 PM
Groovy,could someone tell me what a 44re is based on?,i know the 42 is a 904 based tranny and the 46 is 727 based tranng
jnicewan 06-03-2013 11:13 PM
The 44RE is based off the 42RE,A500,A904. The 46,47,48 is based from A518,A618,727.
I cant tell you what the difference in the 42 vs 44 is, but to get an up rating in torque from chrysler it was probably something minimal and most of the time they upgrade components that are not known for breakage. Probably added a friction disc or two to the clutch packs, wider band(s) and maybe a little more beef on the planetaries.
Flatland88 07-07-2013 08:53 PM
Just an update. I put the new (to me) transmission in and she runs great. Gotta love craigslist; $400 for transmission and transfer case.
kensnelling 07-09-2013 06:33 AM
Glad that one got you back on the road. If it had been a 46RE you would have been changing front and rear driveshafts too!
Ken
Flatland88 07-25-2013 12:24 PM
That's good to know tucsonzj. There may be another Grand Cherokee in my future. My daughter is learning to drive and has her eye on mine. Since we're driving old cars, I think it's best to have a spare around to drive when one them goes down. I'm not sure though what I'll be adding. I really like my son's XJ. The straight 6 and AW4 trans are a great combo.
The time now is 02:40 PM.
