Decel Noise from front - Help - JeepForum.com
post #1 of 9 Old 11-02-2009, 08:37 PM Thread Starter
EVILUTION
I have an 02 QD with 130k miles. The miles are mostly highway and the jeep is not beaten.
I have a shallow growling noise coming from the front of the vehicle. Its louder on decel but present during constant speed from 20mph on up. I've already replaced both wheel bearings, all fluids w/LSD modifier, and have new tires. The sound has been bugging me for about 20k miles.
I put the jeep on a lift and ran it up to 30mph but no noise... I guess its only present with a load.
I'm about to tape a microphone to the front diff to determine if it is the source. I've read it could be the pinion bearing. I'm not sure if it is or isn't and I don't know if thats a big job or not.
Suggestions welcome. Are there any upgrade options for a QD Limited?
2011 JEEP GRAND CHEROKEE OVERLAND 4X4 HEMI
2002 JEEP GRAND CHEROKEE LIMITED QD
EVILUTION is offline
post #2 of 9 Old 11-04-2009, 07:12 PM Thread Starter
EVILUTION
Anyone have a suggestion?
post #3 of 9 Old 11-04-2009, 07:20 PM
cmonson
you most likely need to rebuild your front diff.
cmonson is offline
post #4 of 9 Old 11-04-2009, 07:43 PM
gatorayde
Yep, sounds like a pinion bearing. Might as well replace the carrier bearings as well while you're in there.
gatorayde is offline
post #5 of 9 Old 11-04-2009, 09:21 PM
xJoshxx
2012 WK
i hate you. i looked on alldata it's like 3.5hrs to do..
mine has some decelerate noise. in the dana 30 better off buying a tru-trac for it and then havin them done.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #6 of 9 Old 11-05-2009, 05:03 PM Thread Starter
EVILUTION
Mine is a quadra drive..... are there any upgrade options? What is the expected expense for a rebuild?
post #7 of 9 Old 11-05-2009, 05:18 PM
cmonson
if only carrier and pinion bearings (and seals) are required then count on $650 or so.
I had mine completed a while ago for $600. basically 4 hours labor plus a bearing/seal kit.
cmonson is offline
post #8 of 9 Old 11-05-2009, 09:11 PM Thread Starter
EVILUTION
That's not too bad .... how would I tell if anything else needed replacement?
post #9 of 9 Old 11-05-2009, 10:27 PM
Virmagicus
Virmagicus's Avatar
I wouldn't rule out the TC. I had a couple now go bad with similar symptoms.
Jeff
Virmagicus is offline
96 ZJ Cruise won't resume after decel, ideas? StellaTheZJ ZJ Grand Cherokee Forum 2 07-01-2010 05:37 PM
96 ZJ 242 roaring noise in part time upon decel indianajeep ZJ Grand Cherokee Forum 9 01-30-2010 02:03 PM
249-->242 swapped...now more pullback on decel? APD ZJ Grand Cherokee Forum 3 07-02-2009 09:35 PM
Help! Front Diff Noise Or T-Case Noise ntaousakis ZJ Grand Cherokee Forum 6 04-22-2008 12:39 AM
Light thunking or knocking from front axle on decel? aaron7 ZJ Grand Cherokee Forum 14 02-04-2008 01:31 PM
