Deathwobble, at a loss - JeepForum.com
post #1 of 15 Old 07-08-2011, 10:14 PM Thread Starter
seanmearse
I know, another DW thread. Well, this ones a little different.
Here's the deal, I have replaced EVERY single bushing up front, ball joints, and steering stabilizer, along with an alignment. The only thing left is the upper track bar, its a Heim. The only movement I can see is about 1/32, seriously, I have to be right up on it to see it.
So, the question is, would that cause bad DW? It just looks so miniscule that it just doesn't sound possible, or maybe it is? Any feedback would be great.
1993 ZJ- 4.5" RE, K&N Intake, Flowmaster exhaust, 33X12.50R15 Thornbirds
1997 Venture- stock, K&N, Kenwood full system
2005 XR650L----2007 CRF230L
seanmearse is offline
post #2 of 15 Old 07-08-2011, 10:24 PM
Midnightluckey
Unbalanced / out of round tires can cause DW. When is the last time they were balanced?
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #3 of 15 Old 07-08-2011, 10:35 PM Thread Starter
seanmearse
Sorry, forgot about that, just had the thornbirds put on today, all balanced properly.
post #4 of 15 Old 07-08-2011, 10:48 PM
rooster51
Re torque everything to factory specs & aftermarket parts to manufacturers specs. Not convinced Thornbirds can be balanced perfectly. Fix your trackbar, you said you seen it move. Not supposed to, not even a little bit.
Terry
rooster51 is offline
post #5 of 15 Old 07-08-2011, 11:17 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Thorn turds can't be balanced.
Other options for dw include bad motor mounts. Bad rear bushings, bad steering box, etc...
ratmonkey is offline
post #6 of 15 Old 07-08-2011, 11:26 PM
GM-GDCA
1994 ZJ
have you considered balancing tires and checking trueness of rims? or bad gearing in your steering box? all things to look into. I havn't had the problem on my ZJ but did on a Silverado.
GM-GDCA is offline
post #7 of 15 Old 07-08-2011, 11:59 PM
newfieZJ
How old are your RE arms and did you replace those control arm bushings also ?
RE had a bad run of bushings . Mine failed in 3-6 months (estimate) After I finished replacing all the other parts , even though good , I then had to start retracing steps and found 2 outta 4 bushings (lwr arms) split .
newfieZJ is offline
post #8 of 15 Old 07-09-2011, 10:31 AM Thread Starter
seanmearse
Well, the tires came out to 0.00 after they were balanced. The bushings were all replaced with kragen/energy/moog. This was withing the last 2 weeks, along with all tie rods/ends, gearbox was replaced by the previous owner about two months ago due to the old one not turning left.
post #9 of 15 Old 07-09-2011, 11:18 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You have re arms and used bushings other then re in them? Rubicon express bushings are proprietary.
post #10 of 15 Old 07-09-2011, 11:27 AM
speedbucket
t birds will be out of balance before you get home, i dont care if you put 8oz of beads in them, they wont balance. any track bar play is enough to let DW start. steering box is your next option, do the adjustment per the FAQ/sticky
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #11 of 15 Old 07-09-2011, 12:34 PM Thread Starter
seanmearse
The bushings I got fit very tightly, I just got back from the local fab/crawler shop, he took one look at the caster setting and said wow, go fix that. Getting ready to head out in the garage and reset the caster to compensate for the lift.
post #12 of 15 Old 07-09-2011, 06:57 PM Thread Starter
seanmearse
So, I just spent the entire time adjusting the caster, some moron who owned it before got the bright idea to WELD the jam nut. I am so heated right now its ridiculous. But, alas, the DW is almost gone, just a light vibe for 45-50, nothing around that speed.
post #13 of 15 Old 07-10-2011, 09:41 PM
speedbucket
pinion angle should determine your caster
post #14 of 15 Old 07-10-2011, 10:19 PM Thread Starter
seanmearse
I know, but you cannot adjust the caster on adjustable arms if the nut is welded... So henceforth, I had to grind each nut so I could do that, Not going to just adjust it and say it's good, actually check the degree on the back of the diff, and on the driveshaft to make sure nothing would be overly stressed...
post #15 of 15 Old 07-11-2011, 06:28 AM
speedbucket
hahaha "henceforth" thats great
you can get a decent angle finder from lowe's/homedepot for about 7$
make sure your on level ground
Deathwobble caused by steering box, next step paddingtonbear ZJ Grand Cherokee Forum 14 09-19-2009 01:14 PM
Reasons for the Deathwobble... Tigggger ZJ Grand Cherokee Forum 5 03-08-2009 10:07 AM
94 grand cherokee/stock/deathwobble Jeep4fun ZJ Grand Cherokee Forum 1 06-17-2005 06:08 AM
Oil Loss jeeper31 ZJ Grand Cherokee Forum 12 04-09-2005 09:02 PM
help please! I'm at a loss. uwgKA ZJ Grand Cherokee Forum 5 07-19-2002 01:44 PM
