death wobble. what is it? - JeepForum.com
post #1 of 9 Old 10-04-2009, 07:44 PM Thread Starter
ronsaun
2003 WJ
just put a 3.5 lift on.(2 bb and 1.5 spring helpers) i know this sucks but thats what i did. had it up to 65 mph no noticeable shaking or anything. i was particularly looking for a shake or something. i have seen death wobble mentioned here regularly but dont know for sure what it is, what causes it or how to fix it. the only thing i noticed is the jeep seems top heavy. thinking of wheel spacers. they are cheap. any body have any experience with them?
ronsaun is offline
post #2 of 9 Old 10-04-2009, 07:45 PM
Greeeeenberg
Death wobble is shaking at higher speeds cause of worn out components on the suspension. Usually things like a bushing or a rounded out mount
Why wheel spacers?
97 ZJ Orvis 5.2 108K.
Member #1
Greeeeenberg is offline
post #3 of 9 Old 10-04-2009, 07:53 PM Thread Starter
ronsaun
2003 WJ
i feel top heavy since the lift. thought a wider wheelbase might help. any validity to this idea?
ronsaun is offline
post #4 of 9 Old 10-04-2009, 07:57 PM
silver_laredoSE
correct the wider the wheel base the lower the center of gravity...most go with rims with a different backspacing and wider tires
--Steve--
~RIP Tory Edwards "bigbluezj94"~
Silver Jeep Club Member #4
2008 JK
Black Diamond 3in
315/75R16 KM2s
XRC8
Smittybuilt XRC Stinger
Flat fenders
OLD WJ BUILD THREAD:
silver_laredoSE is offline
post #5 of 9 Old 10-04-2009, 07:59 PM
99avant
kinda looks like this
[yt]vwiv23dLhMY[/yt]
Thicker sway bars will help with the top heavy feeling
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #6 of 9 Old 10-04-2009, 07:59 PM
Greeeeenberg
My death wobble is a quick notes version. Every case is different.
Not gonna help that much. If you want less roll looking into some different sway bars. The stock ones are okay but you want something beefer. Addco is a good brand and easy to come by. You can contact Kolak, he is a dealer on the site and is trustsed and liked by many because he generally has the best price kolak@aol.com. Here is what they are to give you an idea IRON ROCK OFF ROAD: WJ Front Sway Bar (Addco). That is for the front.
IRON ROCK OFF ROAD: WJ Rear Heavy Duty Sway Bar (Addco) thats for the rear. One or the other should be enough. Someone should chime in with more WJ expierence then myself and confirm
Member #1
post #7 of 9 Old 10-04-2009, 08:28 PM Thread Starter
ronsaun
2003 WJ
wow! that video is really helpful in regards to" i know i dont want that". thanks!!!!!!!!!!!!!!!!!
ronsaun is offline
post #8 of 9 Old 10-04-2009, 08:32 PM
rjs79cj5
1979 CJ5
at least you can get yours up to 65, i can't go past 50, to much play in the wheel, trying to figure out how to fix it.
R.J.'s CJ
rjs79cj5 is offline
post #9 of 9 Old 10-05-2009, 02:39 AM
kentman
kentman's Avatar
2006 XK Commander
That DW is ridiculous. I would feel like an idiot driving like that.
Regarding center of gravity, unless those new wheels are very heavy, there will be no change in the vertical CG with a wider stance. Vertical CG is the elevation of midpoint of the mass distribution. Horizontal center will stay the same since the wheels will contribute evenly on both sides.
A wider stance will just decrease your chances of rollover a little. It takes more force to torque the weight of the vehicle over a longer moment arm.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
Is this a Death Wobble? Laid-Off ZJ Grand Cherokee Forum 7 10-30-2015 10:28 AM
Death Wobble? Plum_ZJ ZJ Grand Cherokee Forum 11 10-29-2015 09:24 AM
98 ZJ Death Wobble augnmike ZJ Grand Cherokee Forum 7 10-29-2015 09:16 AM
Death Wobble? azcoyote ZJ Grand Cherokee Forum 14 06-08-2010 09:21 PM
death wobble!!!! kidA ZJ Grand Cherokee Forum 23 11-16-2008 04:01 PM
