Death wobble.. How to fix? - JeepForum.com
post #1 of 10 Old 10-24-2011, 08:58 PM Thread Starter
BRay09
1997 XJ Cherokee
I have a 95 Grand with the 4.0L and its lifted. Not to sure how high, but it is on 31x10.5x15in tires. Ill post pictures of the lift tomorrow and see if you guys think it is donw right or if i should change some stuff. Cant be more than 3in i would assume. The thing rides great, but when i break, the front end shakes like crazy! I jacked it up and thought maybe tie rods, but they and the ball joints are all tight with no play. I am in the process of putting in new Ujoints in the front and changed the hub assemblys on both sides. Would this be my problem?
Oh and on a side note.... anyone know where i can get new bolts for the hub assembly? had to burn two off and one broke.
Have some motor questions too, but those can wait till i get this fixed. Just got this thing and put rebuilt trans in it (42re).
My jeeps:
1997 Cherokee w/ 4.0L 215K
2003 Wrangler w/ 4.0L 75K
BONE stock.... For the moment!
BRay09 is offline
post #2 of 10 Old 10-24-2011, 09:44 PM
WhiteOut
WhiteOut's Avatar
Warped rotors, its not death wobble.
But just to be sure, check to see if the track bar is still nice and tight.
WhiteOut is offline
post #3 of 10 Old 10-24-2011, 11:00 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
If it's actually death wobble while braking, then it's upper control arm bushings, axle side.
ratmonkey is offline
post #4 of 10 Old 10-25-2011, 04:57 AM Thread Starter
BRay09
1997 XJ Cherokee
I'm not even sure where those two items are on this thing. Pictures would help! I'm replacing the rotors and hub assembly so we will see if it were just the rotors
My jeeps:
BRay09 is offline
post #5 of 10 Old 10-25-2011, 05:09 AM
rozco
93' ZJ - 5.2L. 4.5" IRO lift. front long arms rear short adjustables. bilsteins. daystar bumps. 33" KM2's. rancho ss. rc quick discos. flowmaster 10 series.
rozco is offline
post #6 of 10 Old 10-25-2011, 06:47 AM
KoreaZJ
1994 ZJ
Great pic. Upper Control Arm axle bushings... major PITA. Just did mine, get out the really BIG hammer.
KoreaZJ is offline
post #7 of 10 Old 10-25-2011, 07:22 AM Thread Starter
BRay09
1997 XJ Cherokee
Oh jeez... are they expensive to replace or just hard to get out
My jeeps:
BRay09 is offline
post #8 of 10 Old 10-25-2011, 07:49 AM
1stblack97ZJ
just hard to get out. the actual replacement bushings are like 10 bucks.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #9 of 10 Old 10-25-2011, 08:31 AM
PolkaPower
I hate replacing bushings. It helps to have a vice and a torch. You can freeze the bushing then heat up the eye hole and they go in easier. I just replace the whole arm now. They are not too expensive from www.rockauto.com
PolkaPower is offline
post #10 of 10 Old 10-25-2011, 09:30 AM
gabrod72
I replaced all 16 of mine once.... ONCE. Had to burn them out with a torch. Molten rubber took flight everywhere - it's really a wonder none of us got seriously injured!!
Yeah those bushings are a major PITA!
gabrod72 is offline
50mph wobble-not death wobble zeekracing ZJ Grand Cherokee Forum 7 07-27-2010 07:58 AM
Death Wobble...... SENECA ZJ Grand Cherokee Forum 35 09-15-2008 10:49 PM
Death Wobble subzero32 ZJ Grand Cherokee Forum 4 07-25-2006 09:52 PM
still have death wobble need help bryans 86 ZJ Grand Cherokee Forum 12 05-17-2006 05:24 PM
