Quantcast DEATH WOBBLE 96 grand cherokee - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > DEATH WOBBLE 96 grand cherokee
GR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent Prices
Old 01-12-2008, 09:47 AM   #1
nakita
Hello I have a problem with my ZJ I have 2" lift with 30" tires 230,000 miles.When I turn left hit a bump at 45 mph my jeep goes CRAZY I slow down and it goes away,Ive changed tires steering stablizers it all helps for awhile but comes back.I live in the mountains so I drive alot of curves,does anybody have any ideas please help
nakita is offline   Reply With Quote
Old 01-12-2008, 10:10 AM   #2
EVIL ZJ
Tie-rod ends ???
98 ZJ Laredo - 5.2 - 33/12.5 Kevlar MT/Rs - JKS(Modifide)Quicker Disocs - www.KevinsOffRoad.com - LP-1 SliderZ/ (*X-Member Skid*4-sale*) /Light bar w/Remote Lights - 2.25+3.5 RE Lift - Cobra Ultra lll w/FireStick - Bomb - XJ Front DS - Red-top - 10k winch w/Wired & Wireless - Aussie - Flex-a-lite - Garmin - www.ironrockoffroad.com - Iron-Y 3-link - Auburn E-locker - & A GREAT DANE Hangen out the window... GOT GAS??? Lets "GO"...
EVIL ZJ is offline   Reply With Quote
Old 01-12-2008, 10:12 AM   #3
rmtomasin
what's your set up regarding track bars front and rear they effect that alot
-Ryan-
Built Not Bought #233
98 ZJ I6
Build Thread
rmtomasin is offline   Reply With Quote
Old 01-12-2008, 12:23 PM   #4
That Guy
ive been having the same problem but i dont think its my tierod ends b/.c i have a new rugged ridge heavy duty steering....
94 XJ 4.5" D30 aussie/8.25 welded 4:10's 33's
94 ZJ 5.2 3" 31's
[url]www.undergroundjeeps.net[/url]
That Guy is offline   Reply With Quote
Old 01-12-2008, 01:34 PM   #5
Casper4x4
How are your bushings in the front?
Alonzo "Casper" Gonzalez
1993 Jeep Grand Cherokee Laredo
4.0L Engine w/ 231 TC
IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount
Bilstein 5150 shocks
JKS Quick Disconnects
JCR 1 Ton steering
Addco Front Sway bar
Flowmaster muffler
K&N air filter
2 Pro Comp 2 KC lights on KOR light bar
Coleman roof rack
Coming Soon! Gears and locker!
Casper4x4 is offline   Reply With Quote
Old 01-13-2008, 09:52 PM   #6
ant1goodyear
possible bad upper balljoints
ant1goodyear is offline   Reply With Quote
Old 01-13-2008, 11:03 PM   #7
FortCollinsZJ
Someone should add this to the FAQ. It must be missing!
My DW fix was upper track bar BRACKET was loose, and new control arms.
Nothing here
FortCollinsZJ is offline   Reply With Quote
Old 01-14-2008, 10:03 PM   #8
95KYsahara
1981 FSJ Cherokee
I'm thinking the setup on these is similar to that on my 99 Dodge 2500. I replaced the trac bar, drag link, ball joints, wheel bearings, tie rod ends, sway bar links, steering stabilizer, tires, and had it alligned before the death wobble was eliminated. Hope you don't have to do all that. The trac bar was the main problem and it goes about every 50k on those trucks but that Cummins is alot heavier than anything on a Jeep. I took the trac bars completly off my YJ and had no problems though... maybe the leaf springs were enough there?
95KYsahara is offline   Reply With Quote
Old 01-16-2008, 06:22 PM   #9
HalfShaft
Had the DW. Changed the front bushings. All of them on the front end. I will get the back end done but first must fix the garage heater. The DX went away. Drives straight and true. It was no suprise that it had a problem. The lower rear arm bushings were completely gone. Because they are covered by the brackets it was very difficult to visually inspect them without removal.
Best 120 bucks I have put into it.
My experience, yours may vary.
halfshaft
"Quitters only get stuck in the same place once"
1993 Grand Cherokee Limited - "Rose"
1994 Wrangler - "White Whale"
2000 Ford F250 Diesel - "Bigfoot"
2000 Ford Excursion V10 - "Hungry"
HalfShaft is offline   Reply With Quote
Old 01-16-2008, 06:56 PM   #10
FPKites
ZJjazzyJim
FPKites's Avatar
Nakita - there are a lot of threads on how to test for this.
Get a buddy to turn the wheel about 6" either direction, and watch every joint closely to see if it backs away from the mount. If it does, replace it. When you did the lift, did you get an alignment done? That would be a good idea.
I did notice you're in Golden - I work out there, so if you're near 6th and Indiana any time between 9-5, I can probably sneak away from work for a few to take a look at things with you.
Jim Karlin
"Duh! Big RED Jeep!!!"
Best mod you'll ever do on ANY vehicle!!!!
FPKites is offline   Reply With Quote
Old 01-16-2008, 07:01 PM   #11
greasefingers
1994 ZJ
From the FAQ section
http://www.jeepforum.com/forum/f13/death-wobble-cured-124861/
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Old 01-17-2008, 12:09 AM   #12
FortCollinsZJ
Oh... so it was in the FAQ's. weird.
Hope you solve the horrible disease knowns as, THE DW.
Nothing here
Glock Forum
