Death Wobble - JeepForum.com
post #1 of 6 Old 08-09-2009, 05:19 PM Thread Starter
tomcat69
Death Wobble
I own a 96 Grand Cherokee, it has a 4'' Rancho Suspension lift with 31'' bfg tires, i have death wobble. How do I fix or where do I start. I checked everything in the front end and it seems tight, nothing is loose. Help me
tomcat69 is offline
post #2 of 6 Old 08-09-2009, 05:25 PM
Yardman Harry
O
Yardman Harry's Avatar
Best place to start is to get an alignment after you install your lift.
Then Check your Track bar to make sure it is snug and not wallowing out the hole.
If that doesnt solve your problem, thouroghly inspect ALL of the rubber bushings up front (including CA bushings), ALL of the ball joints, if a boot is torn suspect a bad BJ. Remove the tie rod ends one at a time to see if they are worn....
Then go through and retourque everything to factory specs.
Do a few searches, there are a lot of threads on this topic... but those listed above would be a good place to start. Good luck and let us know what you find.
Yard
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #3 of 6 Old 10-29-2015, 09:08 AM
4x4_DesertRat
1993 XJ Cherokee
I have a '93 Cherokee XJ with a 4.5" lift... when I bought it the DW was so bad that I couldn't go over 35mph.
Fixed the problem for $147.80 by replacing the stock Tie Rod (which was bent to hell) and the stock stabilizer (which was punctured by the Tie Rod bolt).... Now I have no issues with Death Wobble at all.
Tie Rod - Rough Country - Heavy Duty 1.25" - http://www.ebay.com/itm/361318655672...%3AMEBIDX%3AIT
Stabilizer - Rough Country - Performance 2.2 - http://www.ebay.com/itm/141049868626...%3AMEBIDX%3AIT
I'm assuming this helped ...I also bought brand new General Grabbers - But only because the BFG M/T's that were on it were completely shot! (And one of them was a BFG A/T that wasn't even the right size!)
I realize this post is about 6 yrs late but hey
1993 XJ - 5.5" Coils - Rancho RS5000 Shocks - DANA 30 - Welded Rear Chryco 8.25
4x4_DesertRat is offline
post #4 of 6 Old 10-29-2015, 09:28 AM
XJ93
Trying to get your post count up or something DesertRat? Looks like you posted on several threads regarding death wobble and almost all of them were years old dead threads.
XJ93 is offline
post #5 of 6 Old 10-30-2015, 08:57 AM
4x4_DesertRat
1993 XJ Cherokee
It's just called being a ....sorry to piss everybody off
post #6 of 6 Old 10-30-2015, 09:54 AM
XJ93
Didn't piss anyone off here, but it's courtesy to check the date on a thread before you post, especially when some of your postings are nothing more than mere smart alec comments. If it isn't a question posed to the original poster, which you could easily just ask them via p.m., or any helpful information to add to a thread there is no need to even comment. I may seem like I'm being a d!*k or something but I am really just passing on some info.
XJ93 is offline
Is this a Death Wobble? Laid-Off ZJ Grand Cherokee Forum 7 10-30-2015 10:28 AM
Death Wobble? Plum_ZJ ZJ Grand Cherokee Forum 11 10-29-2015 09:24 AM
98 ZJ Death Wobble augnmike ZJ Grand Cherokee Forum 7 10-29-2015 09:16 AM
Death Wobble? azcoyote ZJ Grand Cherokee Forum 14 06-08-2010 09:21 PM
death wobble!!!! kidA ZJ Grand Cherokee Forum 23 11-16-2008 04:01 PM
