Death Wobble - JeepForum.com
post #1 of 9 Old 05-06-2013, 12:42 PM Thread Starter
KrisBeller
Death Wobble
i have a 3 inch lift on my 96 grand cherokee and its got this "Death Wobble" i don't have the slightest clue were to start please help
KrisBeller is offline
post #2 of 9 Old 05-06-2013, 12:52 PM
Mickey_D
http://www.jeepforum.com/forum/f13/d...-help-1518766/
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 9 Old 05-06-2013, 01:06 PM
jeepingforlife
I had the same problem. You are going to want to make sure you pinion able for your drive shaft is okay. Do you know how to do this?
jeepingforlife is offline
post #4 of 9 Old 05-06-2013, 01:20 PM Thread Starter
KrisBeller
no I'm new to all this so i need all the help i can get
post #5 of 9 Old 05-06-2013, 03:22 PM
WhiteOut
WhiteOut's Avatar
Please don't give incorrect advice.
OP: You should start with a dry steering test to identify any loose or worn components in the front end. To do this, put the key in the ignition and turn it to the first click "ACC". Have someone turn the steering wheel side to side while you look under the front, if you take a video it might be easier to help you out.
Also, check the bushing and nut on the trackbar at the axle end, then check the bolts holding the trackbar bracket at the frame side. There should be no play and the bushing needs to be in good shape. If it is loose, check to make sure the bolt hole is not wallowed out.
What does your lift consist of? If you did not replace the control arms, are the bushings in good shape? Is it possible to move the arms by trying to shake them?
WhiteOut is offline
post #6 of 9 Old 05-07-2013, 12:14 PM Thread Starter
KrisBeller
my lift is just a 3 inch block sitting on top of the springs I'm not sure if its even the correct lift for my vehicle but it works
post #7 of 9 Old 05-07-2013, 05:33 PM
durango-bob
2006 WK
You should also check your ball joints. You will most likely find that you have a bunch of stuff with a small amount of wear that adds up to your problem.
durango-bob is offline
post #8 of 9 Old 05-07-2013, 05:36 PM
1slo_camaro
take the blocks out of the coil buckets and tighten up the front end before you lift it lol. i believe someone posted the link to another thread, but there are a million places to look that could cause the DW. could be one of many bushings, could be the fact you might need ext control arms, could be an alignment issue, could be even your tires out of balance. there are several issues Whiteout is VERY knowledgable, when the person is turning the wheel look for anything moving abnormally, everything should move together you will see something out of the norm. i would recommend checking the track bar bushing down on the axle i see is the most common.
1998 ZJ~~V.r 4~~4.0 with a bunch of fancy stuff that makes it look pretty sitting in the driveway.
PM me for 99+ intake manifolds for sale
$125-sandblasted and painted and shipped
1slo_camaro is offline
post #9 of 9 Old 05-10-2013, 11:47 AM
JohnnyZJ
Fat Bobs strikes again. perfect way to make a good jeep crap.
because someone cheaped out on a 'lift' you are going to end up replacing everything.
issues come from worn out front end components; adding a lift usually increases the wear on many of these parts, and it is likely why you have issues. alignment and wheel balance at this point is A WASTE OF MONEY. what good is aligning somethng that is worn out?
first place to start; get underneith it and have someone wiggle the steering wheel back and forth; look for play in everything. nothing should move. if you see movement in any joints replace them.
typically the track bar is the first place to look. its likely shot and needs to be replaced. this is the #1 issue most of the time. look at tie rods, ball joints and hubs too. control arm bushings are another area where this is common. you lift the jeep, it has junk joints, they will help the front end break loose.
so to sum it up.
look for play. do the wiggle test described above. to chek for play in the wheels, jack the axle up, and grab the wheel. there should be absolutely no play in it. if there is, hubs or ball joints are gone.
so. in order of preference
1: track bar
2: control arm bushings
3: hubs/ball joints
4: steering components Tie Rod ends.
OR..... if the above is to much work or you don't understand it.........
add a steering stabilizer. the biggest meanest on you can find. then sell jeep and run. or take it to a shop and get bent over to take the flaming cactus
07' JKUR rollin on 35s
JohnnyZJ is offline
