Death shaking at highway speed solved - JeepForum.com
post #1 of 8 Old 08-13-2012, 10:04 AM Thread Starter
WildTornado77
Check your axle stabilizer bar that is right in front of axle (Runs from Passenger side to ball joint on drivers side) Also check antiswaybar links, there are bushings inside the bolts on the bottom bolt.
WildTornado77 is offline
post #2 of 8 Old 08-13-2012, 10:07 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Number one is the track bar everyone refers to. sway bar won't cause death wobble.
Death wobble us a very personal thing. there are usual suspects, but many different things can cause it.
ratmonkey is offline
post #3 of 8 Old 08-13-2012, 11:03 AM Thread Starter
WildTornado77
The links from the sway bar to the spindle was worn on the bottom bolts I needed new bolts and inside bushings.
post #4 of 8 Old 08-13-2012, 11:06 AM
PolkaPower
Sway bar won't cause DW. I left my endlinks pins at the start of a 28 mile trail and had to drive back on the highway disconnected on a very windy day. Aside from the pucker factor from the wind pushing me around, no DW with no sway bar.
PolkaPower is offline
post #5 of 8 Old 08-13-2012, 11:06 AM
WhiteOut
WhiteOut's Avatar
Sway bar is not even a factor in death wobble. If it was, everyone who runs without one would not be able to drive.
WhiteOut is offline
post #6 of 8 Old 08-13-2012, 11:08 AM
PolkaPower
It's just covering up the real issue of why you have DW.
post #7 of 8 Old 08-13-2012, 11:09 AM
WhiteOut
WhiteOut's Avatar
But I put on 3 steering stablizers and my death wobble went away, so it cant be the trackbar. You put one from the passenger knuckle to the tie rod, one from the driver knuckle to the tie rod and one in between. The middle one further dampens the dampening effect of the outside dampeners. Thats like 4x the dampening effect.
WhiteOut is offline
post #8 of 8 Old 08-13-2012, 11:10 AM
PolkaPower
I bet you have not put a double SS on the rear axle thats why. Also check your tail pipe. If it wobbles then that can cause it too.
Funny how people think the SS does so much. Probably because it looks like it does. When in fact it barely does anything.
bump steer , shaking , vibrations
Death wobble solved sinbad85 ZJ Grand Cherokee Forum 6 06-10-2010 12:14 PM
Shaking on Highway Santos ZJ Grand Cherokee Forum 4 06-25-2008 09:34 AM
Death Wobble Maybe Solved But Want Reasurance rob_szma1212 ZJ Grand Cherokee Forum 2 07-24-2007 11:46 PM
95 Jeep GC Limited 4.0 Shaking At Highway Speeds & Other Problems?? Keith1975 ZJ Grand Cherokee Forum 1 07-24-2007 08:34 PM
