death shake - JeepForum.com
post #1 of 14 Old 05-31-2009, 06:19 PM Thread Starter
mulcahy2713
death shake
what causes the death in these 95 grands??? its my girls daily driver so i need to fix it... i dunno much about these year zjs see im a wrangler guy an a dodge truck driver lol
mulcahy2713 is offline
post #2 of 14 Old 05-31-2009, 06:33 PM
97DCZJ
make sure all suspension and steering bolts anywhere under the car are all tight.
if that doesn't fix it, try alignment, or get tires all balanced.
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #3 of 14 Old 05-31-2009, 07:39 PM
_Kyle_
_Kyle_'s Avatar
Loose trac bars or wallowed our trac bar mounting holes or worn trac bar bushings are the cause like 95%+ of the time.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #4 of 14 Old 06-01-2009, 06:39 AM
SouthZJ
and Change the Stering Stabilizer
SouthZJ is offline
post #5 of 14 Old 06-01-2009, 06:41 AM
_Kyle_
_Kyle_'s Avatar
Steering stabilizer is just a band aide, not the root cause.
-Kyle
1996 Grand Cherokee
_Kyle_ is offline
post #6 of 14 Old 06-01-2009, 07:31 AM
moparrr07
yeah steering stabalizer can mask it, but is not the problem
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #7 of 14 Old 06-01-2009, 11:08 AM
hike4it
Yeah Like they all said SS is not the root but if it has high mileage check to see if the stabilizer is blown and change it as well but deffinately find the root of the problem. Like said above really take a good look to see if there is movement in the trackbar
hike4it is offline
post #8 of 14 Old 06-01-2009, 11:43 AM
WhiteOut
WhiteOut's Avatar
NO NO NO, track bars and bushings are gonna be the cause most of the time. The SS wount cause or cure DW, just mask or amplify it
WhiteOut is offline
post #9 of 14 Old 06-01-2009, 12:59 PM
hike4it
THIS IS SOOOOO TRUE ( but ) check your SS and if it is shot get a new one
hike4it is offline
post #10 of 14 Old 06-01-2009, 02:26 PM
coonash
coonash's Avatar
I changed my shocks and it went away for me
Originally Posted by 5-90
This is an online forum, and the written word is the primary method of communication. If you make an effort to communicate clearly, people will be willing to communicate in return. If you don't make an effort, I don't see why I should - write like an idiot, and I'm going to think you're an idiot, that's just how things work.
USN Jeep Club Number 41
coonash is offline
post #11 of 14 Old 06-01-2009, 02:32 PM
herrmy
On my WJ, I needed to adjust my toe.
ROLL TIDE!!!
2002 Grand Cherokee 4.7 HO
3" IRO Coils, MX6's, JKS Adj Trackbar, Rancho SS, KOR Dual SS, Addco rear, BBK 70mm TB, K&N CAI, Magnaflow catback w/ high flow cat and 265/75 M/T MTZ's on 16" M/T Classic II's
herrmy is offline
post #12 of 14 Old 06-01-2009, 05:25 PM
moparrr07
mine needed a new lower trac bar bolt, it was pounded and almost cut in half
post #13 of 14 Old 06-02-2009, 12:29 PM
RocketScientist
Yea, if the front tires are toed in too far, they will cause this. Adding a lift without adjusting will make the vehicle toe in worse. Make a quick check with a measuring tape.
RocketScientist is offline
post #14 of 14 Old 06-02-2009, 12:34 PM
aaron7
Wow, this topic never gets old. I mean really, it's posted nearly every day.
ZJ's are super ultra mega notorious for bad front ends. If you have over, say, 100,000 miles, replace ALL OF IT. Shocks, steering stabilizer, bushings, ball joints, track bar...
89 MR2 MK1.5
74 CB360
83 Firebird
79 Dodge Shasta 22' RV
aaron7 is offline
ZJ with !bad! shake! Rednecksusa ZJ Grand Cherokee Forum 7 05-05-2009 07:28 PM
Shake!! irate808 ZJ Grand Cherokee Forum 3 09-02-2007 12:13 PM
Death Wobble DW Shake Rford ZJ Grand Cherokee Forum 51 04-17-2005 06:57 AM
shake of death damianmantis ZJ Grand Cherokee Forum 24 07-06-2004 08:08 AM
shake of death on stock 95 grand roempty ZJ Grand Cherokee Forum 3 05-26-2004 03:49 PM
