Dead zj (AGAIN) - JeepForum.com
post #1 of 18 Old 08-12-2011, 05:38 PM Thread Starter
98mopar
Dead zj (AGAIN)
Hey all,
my jeep died again. This time 1/4 mile away from home.
This is just getting frustrating.
Not sure what did it this time though.
Luckily I had my volt meter, I am getting signal from my coil....
I have fuel pressure at the rail.
One thing I did notice is when I am cranking it, My tach isn't moving. Should it move when I am cranking?
My immediate thought is crank sensor?
Any other thoughts?
This is my 93 4.0 btw
--- 1998 ZJ 5.9 Limited - 4" lift, 31 x 10.50 15, Jet chip, Kenwood Excelon everything, current DD
--- 1996 ZJ Laredo - Parts parts and more parts
--- 1993 ZJ Laredo - 4.0 Bone stock for now (New to me)
98mopar is offline
post #2 of 18 Old 08-12-2011, 07:04 PM
RedZJ
Die while driving? Or stopped?
You say again.. So did you fix the problem last time? Or did it just start working again?
RedZJ is offline
post #3 of 18 Old 08-12-2011, 07:24 PM Thread Starter
98mopar
It died while driving.
Last time the coil went bad, so I replaced it and went on my way.
This time not so sure. It is just me so it is hard to visually check for spark, but I am getting signal with my volt meter.
Pulled a plug and is dry.
All my gauges work fine, I have fuel pressure at the rail, and fuel pump turns on when I turn the key.
Swapped relays
checked fuses
Ohm checked the crank sensor
checked for voltage at the plug wires and have it when cranking.
Sorta at a loss at this point...
98mopar is offline
post #4 of 18 Old 08-12-2011, 07:37 PM
newfieZJ
Got an OBDII code reader ? Have you looked inside the distributer cap ?
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #5 of 18 Old 08-12-2011, 07:42 PM Thread Starter
98mopar
I will edit my op, I should of been more specific.
This is my 4.0 1993 zj.
Yes I did check my cap and rotor.
98mopar is offline
post #6 of 18 Old 08-12-2011, 08:05 PM
PolkaPower
What does it do when you turn the key?
PolkaPower is online now
post #7 of 18 Old 08-12-2011, 08:10 PM Thread Starter
98mopar
just cranks and cranks no start
98mopar is offline
post #8 of 18 Old 08-12-2011, 08:47 PM
PolkaPower
Sensors maybe? CPS IAT TPS. It's got power? Lights radio?
post #9 of 18 Old 08-12-2011, 08:59 PM Thread Starter
98mopar
I got some more things to test tomorrow. But ya everything has power.
98mopar is offline
post #10 of 18 Old 08-12-2011, 09:08 PM
Ajaxxx
2010 JK Wrangler
Like my uncle used to tell me while slapping me on the head...
spark, fuel, air. Make sure you have these three before getting too wrapped around the axle.
I know this post is pretty useless, but I'm not there to slap you on the head to give it the full effect!
IowaAndy
2010 JK Unlimited Deep Ocean Blue, Auto, Cruise, Softtop, Half-doors, A/C
Ajaxxx is offline
post #11 of 18 Old 08-12-2011, 10:44 PM
Derph
1994 ZJ
Buy an adjustable spark plug tester. Test at 40,000 then at 60,000. Check your cps and crk sensor. It will start without your tps
Derph is offline
post #12 of 18 Old 08-12-2011, 11:17 PM
PolkaPower
Have you tried to start it in neutral?
post #13 of 18 Old 08-13-2011, 06:03 AM Thread Starter
98mopar
I am going to check the injectors and make sure I have a pulse this morning. I dont want to buy anything, cause I have it all at my shop, but thats 30 miles away.
98mopar is offline
post #14 of 18 Old 08-13-2011, 07:45 AM Thread Starter
98mopar
So I have some questions.
This is what I know.
I have spark. although it appears a little weak.
I sprayed starting fluid into the intake manifold, and nothing
I do have injector pulse
I hear full pump run, for about a second
I have pressure at the rail, via shrader valve
My plugs when pulled are always dry?
I am at a loss here.
98mopar is offline
post #15 of 18 Old 08-13-2011, 09:46 AM Thread Starter
98mopar
So after much reading on the site, I still have no conclusion.
Since I have the blade style coil, I have to drive pretty far to get one.
The one I have is now one week old.
But when I hooked a new spark plug up to the coil wire, I got a orange fire. From the coil. Seams weak to me.
After much cranking I did get my plugs wet so I am getting fuel.
What would give me a weak spark, if it wasn't the coil? Could my cps cause a weak spark. I believed it would cause a no spark.
Also I am not even getting a sputter. Just a cranking. Sounds good cranking though, has compression.
When it first died, if I cranked it for a second and let off the key, the motor would jump a little bit, not much, but it did kinda turn over by itself for a hot second. Not sure what that means.
98mopar is offline
dead zj 98mopar ZJ Grand Cherokee Forum 7 08-08-2011 05:27 PM
dead 4.7 rjfster ZJ Grand Cherokee Forum 2 02-22-2010 12:45 PM
Please help... dead WJ jimbos76cj ZJ Grand Cherokee Forum 18 12-19-2009 04:43 AM
Dead WJ NewJeepFever ZJ Grand Cherokee Forum 47 01-26-2009 08:36 PM
Dead 93 JGC Frostbite ZJ Grand Cherokee Forum 12 02-06-2005 10:58 AM
