Dead radio, interior lights, power mirrors and power locks. - JeepForum.com
post #1 of 6 Old 09-02-2005, 05:05 PM Thread Starter
Lisa
My radio, interior lights, power mirrors and power locks all went at the same time. Fuses are all good (both in the front under the hood and passanger side door), particularly fuse #10.
Any hints on what I should look for? Also anyone know where I can find a pdf of the users manual?
Lisa is offline
post #2 of 6 Old 09-02-2005, 06:36 PM
Meerkat
Welcome to the board!
You didn't say what kind or year Grand you have.
However, I'll take a shot at it.
All the circuits you list use the following fuses:
Junction Block (inside the Jeep)
Fuse 3
Fuse 6
Fuse 16
PDC (under the hood)
Fuse 8
Fuse 11
Fuse 15
Fuse 18
Other modules in common are the Driver Door Module and Passenger Door Module (though I doubt those are the problem). The Body Control Module controls the function of all the circuits (among others).
Are you looking for an owner's manual, or a factory service manual?
Again, you'll have to specify the year of your vehicle to get any further.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 6 Old 09-02-2005, 07:32 PM Thread Starter
Lisa
My bad, it's a 94.
As I said, all the fuses are good (pulled every single one of the bleeding things).
I'm looking for an owner's manual as my haynes manual doesn't list what each fuse does.
Lisa is offline
post #4 of 6 Old 09-02-2005, 08:09 PM
Meerkat
Go bid on This One
Good luck!
Warren
Meerkat is offline
post #5 of 6 Old 09-04-2005, 08:46 PM Thread Starter
Lisa
Originally Posted by wvd
Go bid on This One
Good luck!
Well it did turn out to be a fuse, dunno which #, it was labled I.O.D. I didn't check them properly, found the cause of the issue too, bad bulb under the hood. So next time I'll pull every fuse to check, instead of just putting that checkie thing on it.
Lisa is offline
post #6 of 6 Old 09-04-2005, 09:34 PM
Meerkat
Good job, Lisa!
Those checkie things can certainly lead you astray...
It can be frustrating to be told to check the very thing you are sure you have already checked, but more often than not, it usually turns out to be the very thing you swear it can't be causing the problem.
Warren
Meerkat is offline
Cruise control, power seats, power locks, don't work. Metzroth ZJ Grand Cherokee Forum 2 01-17-2010 10:05 PM
No Power Windows, Locks Or Mirrors! gritts ZJ Grand Cherokee Forum 2 06-25-2009 06:57 PM
Power Windows/Mirrors/Locks Failing 99 WJ Islesfan079 ZJ Grand Cherokee Forum 9 12-04-2008 04:53 PM
No power to radio, A/C, Computer, power locks drumtex ZJ Grand Cherokee Forum 2 05-11-2008 11:37 PM
Power Locks/Power Windows on Passenger Side ccox ZJ Grand Cherokee Forum 2 07-09-2005 08:46 AM
