dead horn ? - JeepForum.com
post #1 of 14 Old 02-10-2016, 08:49 PM Thread Starter
Candymancan
dead horn ?
Noticed the last few weeks my niners Horns have sounded wierd.. locking the doors and even hitting the horn it sounds dull and weak, not loud.. I know there are two horns on the Jeep.. Is there anyway to fix this ?
2013 6.2 V8 Camaro SS 30k
98 5.9 V8 ZJ 180k
98 4.0 I6 ZJ 240k
90 5.9 SJ Grand Wagoneer 110k
Candymancan is offline
post #2 of 14 Old 02-10-2016, 08:58 PM
kg6mov
Hears the voices
kg6mov's Avatar
It may be just a wiring issue, but they do die eventually and must be replaced.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ 5.9 - Junked
kg6mov is offline
post #3 of 14 Old 02-10-2016, 09:00 PM
JonS
If it's a wiring Name:  image-3346578406.jpg
Size:  481.2 KB issue it's normally the block connector under the battery
http://www.jeepforum.com/forum/f13/early-signs-pcm-failure-3606481/
JonS is online now
post #4 of 14 Old 02-10-2016, 09:48 PM Thread Starter
Candymancan
So that thing is under the battery ? I guess ill have to pull the battery and tray out to find that ?
98 5.9 V8 ZJ 180k
98 4.0 I6 ZJ 240k
post #5 of 14 Old 02-11-2016, 12:02 AM
Uniblurb
Uniblurb's Avatar
Don't believe you pull battery and you get to the horns from underneath. Kinda behind or above the far passenger side front bumper. From underneath you can pull a rubber flap/plastic piece back to see the horns.
Uniblurb is offline
post #6 of 14 Old 02-11-2016, 06:17 AM
akk32
There are 2 horns, a high tone and a low tone. Don't get 2 of either, it won't sound right. You have to remove the bumper cover to get to them
This is what I used:
Low tone:
http://m.autozone.com/electrical-and...496/?location=
High Tone:
http://m.autozone.com/electrical-and...499/?location=
Only difference from OEM is the connector, sounds good.
Sent from my SM-G900V using Tapatalk
1997 Jeep Grand Cherokee Laredo 4.0 Selec-Trac 4WD Chargold II 230,000 Miles
1996 Jeep Grand Cherokee Laredo 4.0 Selec-Trac 4WD Chargold II 208,000 Miles (Totaled, working on rebuilding it)
akk32 is offline
post #7 of 14 Old 02-11-2016, 10:21 AM Thread Starter
Candymancan
I know where the horns are ive taken em off many times, but my plugs look wayy diff then that one Jon linked ?
98 5.9 V8 ZJ 180k
98 4.0 I6 ZJ 240k
post #8 of 14 Old 02-11-2016, 11:32 AM
kg6mov
Hears the voices
kg6mov's Avatar
I've seen nothing like Jons picture on either of my ZJ's.
I also can't find reference to the horns ever being under the battery in a ZJ from the factory.
kg6mov is offline
post #9 of 14 Old 02-11-2016, 11:37 AM
akk32
I've never seen that either
akk32 is offline
post #10 of 14 Old 02-11-2016, 12:09 PM Thread Starter
Candymancan
Ima take them off a d spray wd40 inside and twirl em to get it in the center of the horn.. i read if you do that it can free up a rubber flap or whatever its called and possibly make the horn work again
98 5.9 V8 ZJ 180k
98 4.0 I6 ZJ 240k
post #11 of 14 Old 02-11-2016, 12:17 PM
jrobeson18
Yard Mechanic
jrobeson18's Avatar
ive seen that connector before. in an older 94-ish ZJ horn question.
jrobeson18 is offline
post #12 of 14 Old 02-11-2016, 12:53 PM
Para32
I have replaced two horns, one on each jeep that I have had. Seems like an item that goes fairly easily
Before you bark up the wrong tree, make sure its the horn itself and not something else
You can access them from underneath the front corner of the bumper
Pick one connector and unplug it.
It will either continue to beep (you picked the dead one) or it will stop beeping (you picked the working one)
You MAY be able to go onto rock auto or a stealer and get a horn with that nice water tight connector
If not, a generic horn will work but you will need to crimp two spade clips to the ends of the wires
Since it is a 2-wire device there is no polarity, so its impossible to reverse + and -
On the last one I did the sheet metal nut that holds the thing in place went to crap
So I zip tied the whole assy to a brace under there
Turns out when the horns physically touch anything they sound half dead
I am going to pop a hole in the brace and mount with a bolt next time I am under there
Para32 is offline
post #13 of 14 Old 02-11-2016, 01:08 PM
JonS
Interesting . . . Mine is a '98 and original connector prior to my fix. The wires and metal ends were bad.
JonS is online now
post #14 of 14 Old 02-11-2016, 02:45 PM
Para32
JonS: I see you pic.....is that the feed further upstream that feeds power to BOTH horns?
Para32 is offline
