daughter hit a pole...bumper questions... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > daughter hit a pole...bumper questions...
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Nitro Gear Packages Now Available at Rockridge 4wdGear Packages Available! Your # 1 Diff Shop is ROCKRIDGE 4
Unread 08-09-2014, 03:42 PM   #1
Bear304inc
All right so I let my daughter borrow my 98 zj laredo and... she hits a pole in the parking lot at school. Looking at the plastic bumper gaurd it didnt appear bad. But the radiator recently went out and when I go to replace the radiator I find the actual bumper pushed in abiut three or so inches on the right side, and is pinning the radiator to the steering box. Looking at the bumper it looks like it held on by some torq head bolts. Dont know if I can replace it . Or maybe pull it out with a come along. Doesnt need to be square just need to swap radiators. Anyone have any experience with something like this????
Any help would be greatly appreciated.
Bear304inc is offline   Reply With Quote
Unread 08-09-2014, 04:34 PM   #2
kg6mov
Hears the voices
kg6mov's Avatar
Pics would help.
If you're talking about the front crossmember it should be spot welded on, no bolts. I did mine pretty bad totaling a camry that stopped at a green light.
Pics here: http://www.jeepforum.com/forum/f13/n.../#post14521403
I bent it far enough back into shape with a c-clamp and a 2x6 to get the radiator back in correctly. Once my bumper was built I used that and a ratchet tow strap to bend it back some more.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is offline   Reply With Quote
Unread 08-09-2014, 11:49 PM   #3
Oldfrog
I pulled my rear one out with a come along. Hooked it to the side of a trash dumpster. Be aware, it can slide the dumpster towards your Jeep, so make sure the rear hatch is closed first ! Piece of cake.
Cajun Recipes and Fishing tips
Words of wisdom, Posted by Zeejay:
"..it's not air, it is the opposite of air... suckage so to speak."
Stalling? Work through Zeejay's list
Oldfrog is offline   Reply With Quote
Unread 08-10-2014, 06:20 PM   #4
Bear304inc
Well thanks guys ,your comments gave me enough confidence to go out and strap a come along and chain to a tree in my yard and slowly got that sucker pulled out enough to get the radiator swap done. Wasn't too bad, only problem was when I put that much tension on the come along I couldnt get it to release,, so I would have to carefully push the whole jeep up with another truck. Had to do this a dozen times or more while moving the come along hook to different spots. Its nowher close to pretty but I got that sucker in and she's running like a champ. No just waiting for my wheel adapters to come in the mail, and the jk Sahara wheels that have been sitting in the garage go on! Thanks again. Ps tried to upload pics but it kept telling me the file size was too large.
Unread 08-11-2014, 01:32 PM   #5
Bear304inc
Seems to be running fine, but I just noticed the oil pressure gauge sitting at zero,,, it was about a quart low so I added some and no change. The jeep was sitting a few months before I put the radiator in, wonder if that has anything to do with it?
Unread 08-11-2014, 04:06 PM   #6
Bear304inc
Yeah my adapters came today. Now if only I didnt feel like a recycled turd from this stupid summer cold, I would put them on tonight. Looks like its Nyquil and bed for today, get it done tomorrow.
Unread 08-12-2014, 05:28 PM   #7
Bear304inc
that was short lived....
Ok fellas new problem,, maybe an old problem...
Got my bumper pulled out radiators swapped, ran nice around the block a few times, parked it running a few more minutes checking for over heating and or leaks,, nothing. All appeared fine. Till today, I get in her to go get my tires put back on the beads (whole other issue involving me and some carb cleaner and fire.. didnt work)and I get maybe two blocks and I notice shes running a lil hot, so I turn around get home and it appears I have a leak, with the fan shroud on I cant immediately see where it is coming from, and... its pouring rain btw, so ill hunt that down tomorrow.....
Now I have a couple of questions,,,
Shouldnt I feel fluid in the top hose going into the thermostat housing? I got nothing.
If so would that indicate a faulty thermostat?
Water pump possibly?
Im also wondering if my system had this problem that caused my first radiator to fail. God I hope I didnt bust the new one on top of having another issue.
Didnt know if I should've started a new thread,, figured id try this one I already got going,,,,
Any ideas??????????
Unread 08-12-2014, 08:26 PM   #8
firsttimeZJ13
Sounds like you need to burp the system from air. Yes you should feel water in the top hose, but if there's isn't any water (air pocket) touching the stat, it isn't heating up right to open and circulate the water.
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline   Reply With Quote
Unread 08-17-2014, 04:21 PM   #9
Bear304inc
Well, I ended up changing my thermostat and the water pump, and the radiator... including several flushes, and parked it going up a pretty steep hill to burp all the air. So far so good. Not sure which one fixed my problem but it appears to be fixed.( fingers crossed)
