Dashlights out dome light stays on????????? - JeepForum.com
post #1 of 3 Old 02-07-2013, 09:12 PM Thread Starter
driftwood00
Im looking at buying another 94 JGC Loredo, the owner has told me that the dashlights just went out and the dome light stays on and the display says passenger door ajar, I assume that these things are realted but not sure where to start looking, I for sure dont want to get myself into some electrical mess, so I thought I would check here first to find out the main culprit that causes these types of problems, any input will be greatly appreciated, Thanks in advance.
1995 JGCL
4.0L
4x4
driftwood00 is offline
post #2 of 3 Old 02-07-2013, 09:28 PM
KoreaZJ
1994 ZJ
Not related...
Panel lights - check Fuse#24 (7.5amp) in Fuse Block located at passenger end of dash
Dome light - likely bad/misadjusted passenger door jamb switch.
KoreaZJ is offline
post #3 of 3 Old 02-10-2013, 09:09 AM Thread Starter
driftwood00
You were correct about dome light, and partially correct about the fuse for the dash lights, the fuse was blown but after replacing it, still no lights, I went ahead and replaced the dimmer switch and it worked. Thanks for the response, it put me in the right direction.
1995 JGCL
4.0L
4x4
