Dash lights flashing, loss of tail lights - JeepForum.com
post #1 of 7 Old 02-05-2011, 10:22 AM Thread Starter
ZOG
97 grand Laredo
A few weeks ago, while driving at night, all my lights started to pulse on and off, (head lights and dash panel lights). Light switch was set to AUTO.
Turning off ignition, or turning light switch from auto to ON, would stop this.
It happened once a week or so.
Now, I have no tail lights, nor dash lights at all, when switch is ON.
When switch is moved to AUTO the dash lights will flash, but still no tail lights.
All fuses appear to be fine. Battery is relatively new.
Researching this problem here, many people think the ignition switch is to blame, some other posts say light switch?
Is there any way to determine, other than replacing both switches? Which would you replace first? Any ideas?
__________________________________________________ __________________________________________________ ___
Update, No one has a light switch in stock locally, will take 2-3 days to get.
Now, when on AUTO , hit the brakes , the dash lights continue to flash, still no tail lights at all.
Thanks
ZOG is offline
post #2 of 7 Old 02-05-2011, 11:30 AM
newfieZJ
If you consider switching from auto to on changed the charactorics of the issue , I would have to vote for the light switch itself being the issue
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 7 Old 02-05-2011, 11:31 AM
94chb
sounds like it could be a bad relay, its under the passenger kick panel
94chb is offline
post #4 of 7 Old 02-05-2011, 11:57 AM
JS97ZJ
Ratmonkey answered a similar question yesterday
http://www.jeepforum.com/forum/f13/a...iving-1163252/
POST #5......when checking in the FSM, it made a whole lot of sense. A marvel of electrical engineering......
JS97ZJ is offline
post #5 of 7 Old 02-05-2011, 03:47 PM Thread Starter
ZOG
I was wondering if this was the case, I'll check the relay out.
ZOG is offline
post #6 of 7 Old 02-05-2011, 10:07 PM
MarkInTombstone
Could be the switch
You'd be doing me a favor if you called me Mark or Tombstone, but not both.
MarkInTombstone is offline
post #7 of 7 Old 02-06-2011, 04:48 PM Thread Starter
ZOG
OK , checked a few things and NO luck.
Took apart the light switch and saw some discoloration on the contacts, cleaned them up, reinstalled, no change.
Checked the relays and all seem good, all fuses are OK, too.
Is it the ignition switch?
I couldn't get at that as I didn't have a security torx T20. I'll have to get one this week.
I'd really just like to get the tail lights working, can't drive after dark now.
ZOG is offline
Lights keep flashing on and off on dash! machurtado WK Grand Cherokee & XK Commander Forum 27 03-10-2016 12:49 PM
Fried wire = no tail lights or dash lights kowboydmac ZJ Grand Cherokee Forum 3 05-20-2010 01:19 PM
Dash comp flashing tail light fault- but lights work??? Loki702 ZJ Grand Cherokee Forum 4 10-28-2008 08:19 AM
Dash lights flashing Doo Hauler WK Grand Cherokee & XK Commander Forum 10 01-12-2008 08:05 AM
No dash lights or tail lights - instantly blowing fuses oxrageous ZJ Grand Cherokee Forum 2 11-01-2007 09:00 AM
