Dash and gauge removing - JeepForum.com
post #1 of 8 Old 08-13-2006, 06:29 PM Thread Starter
mathieu660
Hi everybody, i'm new to this forum and a new owner of a GC 94. I wanted to modify all the dash backlight to blue but it's seem i need to weld some DEL on the printed circuit. By the way i tried to remove the dash cluster but i didn't find a easy way except to remove all the upper dash parts and all the fender on the steering wheel. Any one got some pics to remove all the cluster easy ? exploded schema will be very appreciated too. Thx all
mathieu660 is offline
post #2 of 8 Old 08-13-2006, 07:08 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
This should help you:
http://www.nagca.com/grandtech/el-glogaugeinstall.htm
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #3 of 8 Old 08-13-2006, 07:40 PM Thread Starter
mathieu660
Thanks Phil for your fast reply. But i got a GC 94 SE and the dashboard is not the same as the picture on the website. It seems that's the LAREDO version got a differant dash and it's easier to remove than mine. Do you have another website with the SE version or the exploded part of the dash could be nice too.
post #4 of 8 Old 08-13-2006, 09:05 PM
-Joe-
-Joe-'s Avatar
Theres like 3 screws above the cluster, 2 above the radio, and 2 in glove box. Then 4 under the defrost grill on the dash. Pop the top of the dash off, then 2 screws holding the cluster in. (At least on a 95)
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 8 Old 08-13-2006, 09:39 PM Thread Starter
mathieu660
Any one got some pics or exploded view of the dash ?
post #6 of 8 Old 08-15-2006, 09:57 PM Thread Starter
mathieu660
Any one could help me ?
post #7 of 8 Old 08-15-2006, 10:04 PM
jeep946
jeep946's Avatar
do you have msn chat or yahoo i have a fsm i can send you that will help you out
94 Grand Cherokee, 4.6 stroker, 7 inch custom long arm kit, 33x12.50x15 Firestone destinations m/ts, flow-master 40 series, magnaflow high flow cat, locked front and rear, super axle kits front and rear, pioneer head unit, CB on channel 10, and a B&M built transmission, switched from a 231 to a 242, 2000 Grand Cherokee steering and knuckles and brakes, no abs, wildwood adjustable proportioning valve, and lots more
jeep946 is offline
post #8 of 8 Old 08-15-2006, 11:01 PM
nashmd454
nashmd454's Avatar
I wish I could help..I took mine apart awhile back and it looked just like the one in the link...I like the indiglo look of either green or blue or dim and bright. I had a 94 before this 96 and don't recall anything majorly different. Like I said..I wish I could help. I did take pics of mine and they are in my sig.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
Removing dash, won't budge jtsjeep99 WJ Grand Cherokee Forum 17 05-31-2010 08:57 AM
Removing The Dash? How? Jakeb2k4 ZJ Grand Cherokee Forum 3 01-10-2009 02:56 PM
Dash/Gauge Lights... Dillonzj ZJ Grand Cherokee Forum 12 10-30-2008 10:11 PM
removing a dash in a zj 96GC08 ZJ Grand Cherokee Forum 5 01-14-2008 10:14 PM
Removing Dash OrvisOwner ZJ Grand Cherokee Forum 7 10-16-2003 06:53 AM
