Dana 44a service - JeepForum.com
post #1 of 6 Old 10-03-2013, 05:31 AM Thread Starter
Giallo
Dana 44a service
Hello,
Here I am again with a new question.
My 5.9 rear axle Dana 44a seems to need some service: opening the differential I noticed two broken rings (the rings that are on the cluthes) as you can better see from this picture:
I ask if they are the same of Dana 44 axle.
Once opened the differential my idea is to change bearings too. Are they the same of Dana 44? Where can I find them?
Thank you
Poor Italy: my Country leaks like my t-case :-(
Giallo is offline
post #2 of 6 Old 10-03-2013, 05:33 AM
x10radsponge
I have the same issue with the ring on the drivers side.
x10radsponge is offline
post #3 of 6 Old 10-03-2013, 06:00 AM Thread Starter
Giallo
And what you did?
Giallo is offline
post #4 of 6 Old 10-03-2013, 09:16 AM
PolkaPower
They are not the same. The D44 and D44HD are two different axles. The D44HD is the D44a. The part number to rebuild the track lok is 707018X according to my invoice sheet. Same happened to mine. Thrust washers separated and I found metal chunks in the diff.
http://www.ronsmachiningservice.net/...h-kit-707018x/
PolkaPower is online now
post #5 of 6 Old 10-03-2013, 10:26 AM Thread Starter
Giallo
Wow! Thank you!
I didn't know this seller; hope he ships oversea.
Giallo is offline
post #6 of 6 Old 10-03-2013, 12:16 PM Thread Starter
Giallo
Found bearings kit too: http://www.ronsmachiningservice.net/...-kit-zk-d44hd/
Very nice seller, added to favorities
Giallo is offline
