dana 44a axle shaft bent. i hope its the axle shaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > dana 44a axle shaft bent. i hope its the axle shaft
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 01-12-2010, 03:17 PM   #1
southernmudzj
a few months ago i was 4wheeling and hit a stump it broke my rim and ever since then my passenger side makes a noise driving. i can tell somethings bent because if I'm going slow i can feel it kind of lumping. it goes up then down then up and down and so on. it doesn't vibrate that much but it gets bad when i get up to 60-65.
The lump makes me think its the axle shaft itself. How hard is it to replace an axle shaft and what alls involved besides taking of the rotor and caliper and the hub bolts? I've got to take the diff cover off and take out the c-clip if I remember right. If anyone can chime in that'd be great.
I found an axle at east coast gear supply for 155 shipped its a yukon axle they have a spicer axle for 25 more dollars. Whats the difference between yukon and spicer?
I've been driving on it for a few months now and probably will be at least another month until i get some money saved up.
96 zj. 31x10.50 uniroyal awts. 2.25 bb rough country 9000 shocks. rustys transmission crossmember
cobra radar detector future mods:rustys 5.5 long arm kit and smittybilt xrc8
southernmudzj is offline   Reply With Quote
Unread 01-12-2010, 05:41 PM   #2
MuddyLuxury
44a isn't a c-clip. take all the brakes and stuff off loosen those 4 bolts that are behind the dust shield. using a slide hammer pull away and it will slide right out. reinstall is the reverse minus the use of the slide hammer whole job took me about 20min on jack stands.
also FWIW use one of those niffty lazer level things that projects the beam and make sure you didn't move the tube out of the housing. it sounds like you took a hard hit.
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline   Reply With Quote
Unread 01-12-2010, 05:50 PM   #3
southernmudzj
on the wj it isnt but i think on the zj its c-clipped.
and thats a good idea ill try that
Unread 01-12-2010, 06:00 PM   #4
WJ04
WJ04's Avatar
Correct...
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
October 2011 GCOTM Winner
Some of my videos: http://www.youtube.com/user/LockedWJ?feature=mhee
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline   Reply With Quote
Unread 01-12-2010, 06:03 PM   #5
southernmudzj
Originally Posted by WJ04 View Post
Correct...
why thank you kind sir. I've been a member here a year or two and have learned alot since joining.
