dana 44, pinion gear mate shaft, lock screw head broke off - JeepForum.com
post #1 of 31 Old 06-05-2011, 09:57 PM Thread Starter
tallears
I was going to change my rear axle bearings & seals. However while unscrewing the lock screw that holds the pinion mate shaft into the diff.case.assembly the head of the lock screw broke off. So I reinstalled it with a little locktite. My question is this??? Has anyone else had this happen or ever heard of this happening. I'm guessing that if it happened to mine it has or can happen to others. So if you attempt to do this be very careful turning that little sucker, maybe want to apply some heat. Because what was going to be an enjoyable weekend (yes enjoyable) changing my bearings now may be anything but, because if I have to ruin that diff.case.assembly digging that lock screw out of there, then I would need to buy another case $$.. Before I ruin it does anyone know how hard of a job it is putting the case assembly back in there?? Sorry for the long post but had to explain this, cause this is my next adventure, my vacation starts in 3 more weeks, and this is my baby. Thanks for any info anyone can send me.
tallears is offline
post #2 of 31 Old 06-05-2011, 11:04 PM
FPKites
ZJjazzyJim
FPKites's Avatar
I just broke one yesterday...fun stuff. You can get a new one for about 5 bucks though.
http://www.jeep4x4center.com/product...mber=5015223AA (first google hit)
It's dealer/Crown part number 5015223aa, but it can be hard to get new. Any junkyard with ZJs and 44a axles will have them. I'd recommend scavenging them, which is what I did this morning.
I've sheared 2 of them in the 4 times my center pin has had to be removed.
The good news is, it's not high torque, and there should be no rust as long as your diff fluid level has always been good.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #3 of 31 Old 06-05-2011, 11:12 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Very common break in every axle that uses a bolt. They make a special easy out kit with a guide for the drill and a special length bit so that you can actually reach the hole with the carrier in the axle.
ratmonkey is offline
post #4 of 31 Old 06-06-2011, 07:07 AM Thread Starter
tallears
Thanks fpkites, I have already purchased a new lock screw to replace the broken one..Had to buy it at a dealer but at least its brand new, I believe now that this screw must be breaking from the stress on it, it is a very thin screw for such a job it does,....Thanks ratmonkey, I was told buy a shop that handles axles,diff. etc. that they may be able to get it out of there.. I'm hoping they don't ruin the case assembly just so they can rebuild the entire diff.. and leave me with a hugh bill $$... But now that you have mentioned this special tool bit I will let them know that I know and I will go to someone who has it..I already tried to get to it and its on such an angle that you can't drill straight into it and you're at an angle, so I see why you would need a special tool, have any idea what my changes are of getting that out without ruining that case???? thanks again...
tallears is offline
post #5 of 31 Old 06-06-2011, 07:43 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Did you try using a pick to back it out? I was successful in doing that this weekend. I suppose to Locktite might give you some trouble now though.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 31 Old 06-06-2011, 07:52 AM Thread Starter
tallears
Well I put locktite there so the darn thing didn't back on out and ruin my entire diff. I was planning to just add a little heat to it later when I get ready to get it out of there, had to do something to hold it in there for a while, and I don't think locktite is invincible.. Not sure we're talking about the same lock screw if your talking about backing it out with a pick.???
tallears is offline
post #7 of 31 Old 06-06-2011, 07:54 AM
justanotherjpr
If this is a D44, cant you pull the shafts and remove the carrier? Or is a C-Clip D44?
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #8 of 31 Old 06-06-2011, 08:04 AM Thread Starter
tallears
Its a dana 44 thats for sure. It has c-clips and to remove the c-clips you must remove the pinion gear mate shaft, but in order to remove the pinion gear mate shaft you must unscrew the lock screw that holds the mate shaft in there. However the head of the lock screw snapped off, leaving the entire shaft of the lock screw inside the mate shaft. Can't pull the axles out until this has been done..
tallears is offline
post #9 of 31 Old 06-06-2011, 08:37 AM Thread Starter
tallears
Because I have taken great care of my dana30 and dana44, changing the oil more than required, adding only Mobile1 75w 140 syn., so when you open them up and drain them theres never no metal shavings, only clean Mobile1 coming out, and new Mobile1 going back in..Tighten it all back up with my chrome bolts, frt and back..baby ready to ride
tallears is offline
post #10 of 31 Old 06-06-2011, 10:36 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Pretty sure we're talking about the same pig. It's a 1/4" head, less than an inch of thread, and the rest is a pin.
It's supposed to be very low torque, but sometimes it's a bit snug. Sometimes there's enough of a rough spot you can use a pick to back it out via the threads. Just spin it counterclockwise and it will come out. That's what I had to do on Saturday and I succeeded. You probably have 1, maybe 2 threads holding the pin half in.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #11 of 31 Old 06-06-2011, 12:45 PM
MaintMech
Old and in the way
MaintMech's Avatar
FWITW Loctite Blue breaks down at about 300* F. So when it comes time to take that bad boy out bring a torch!
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #12 of 31 Old 06-06-2011, 12:46 PM Thread Starter
tallears
Okay, you know what I'm dealing with now. Didn't know for sure if we were on the same bolt. But thats it (thepig), you described it to a tee. And your right I do still have a small amount of thread still left on the pin. Most of the thread came off with the snapped off head. So now i will give that a try, I do have a few pick tools I bought from sears so I will give it a try, will have to wait till this weekend, I need it to get to work...thanks
tallears is offline
post #13 of 31 Old 06-06-2011, 12:50 PM Thread Starter
tallears
yeah I figured I would worry about the loctite when I get there..Like I didn't want the f###pig to come out and destroy my entire diff...anyway I have heat so no problemo...
tallears is offline
post #14 of 31 Old 06-06-2011, 12:54 PM Thread Starter
tallears
I was told by a mechanic at the diff.shop that somethings they can tack-weld a bead on it and then back it out of there..??? anyone ever here of that one. Sounds like it might work.
tallears is offline
post #15 of 31 Old 06-06-2011, 02:27 PM
justanotherjpr
I tried welding one that was stripped once, didn't work. YMMV.
Differential lock screw snapped - best removal method advice needed Yardman Harry ZJ Grand Cherokee Forum 11 07-01-2009 05:53 AM
finished my lights and broke my screw in my ankle!! ZtotheJ ZJ Grand Cherokee Forum 33 10-17-2008 07:16 AM
Rear Brakes - Broke Bleeder Screw Greydane ZJ Grand Cherokee Forum 2 07-13-2008 03:54 PM
Pinion Gear Mate Shaft Screw cowteets ZJ Grand Cherokee Forum 7 04-04-2008 10:27 AM
How hard is it to replace the pinion gear shaft seal? bjl95mustang ZJ Grand Cherokee Forum 1 01-18-2008 04:59 PM
