Dana 35 - JeepForum.com
post #1 of 13 Old 08-16-2009, 03:38 AM Thread Starter
mr4x4
Dana 35
ok I have a stripped Dana 35 pinion gear in the rear of my zj I would hate to regear it but I will have to do something
I have a stock zj with the stock 3.73 gears
I can get a tj dana35 with 3.73 gears for $125 thats atleast half the cost of just the parts to regear my rearend
my question is will the tj rearend allmost bolt right in? I will have to change the brakes from drum to disk and I think move the shock mounts this tj rearend has 29,000 miles on it he changed it for a dana 44
I'm just trying to fix this as cheap as I can and if its changing the whole housing out for another then so be it
94 stock zj and a 95 zj with a 5.5" lift with 35" bfg km2 a rear currie 9in with 4.56 gears an arb and 35spine axle shafts and 4.56 gears in the front Hp30 super30 kit arb 4.1 low range transfercase
mr4x4 is offline
post #2 of 13 Old 08-16-2009, 04:05 AM
sandman
no all the brackets would need to be changed. your best bet is to get an axle out of another ZJ preferably a 44a
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 13 Old 08-16-2009, 07:30 AM
TMCXJ
^----- ditto
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
post #4 of 13 Old 08-16-2009, 07:53 AM
Katesdad
Katesdad's Avatar
shouldnt be hard to find a v8 zj junked somewhere.
Katesdad is offline
post #5 of 13 Old 08-16-2009, 08:03 AM
little_Jeep
Don't spend and money on a D35. Also the cost to convert a D35 from a TJ to a ZJ would be more than the axle is worth. There are a ton of 8.25s from XJs, but I don't think you would ever find one with 3:73 gears and the cost to change would be way more than the axle is worth.
little_Jeep is offline
post #6 of 13 Old 08-16-2009, 09:20 AM
gatorayde
Time for a d44a swap.
gatorayde is offline
post #7 of 13 Old 08-16-2009, 10:32 AM
TMCXJ
The 8.25 from an XJ will definitely not have ABS; if that's a factor, don't try it. Along with the cost of modification, it's not an option I'd recommend.
TMCXJ is offline
post #8 of 13 Old 08-16-2009, 01:34 PM Thread Starter
mr4x4
i dont have the money nor want to at this time put a d44 into the zj
I have 3 dana44's in my yard all out of comanches the cost for the dana44 swap is $300-$400 for brackets and close to $400 for gears master install kit
and carrier then I still have to weld the brackets on and re gear it and get the abs system setup for it
I would rather spend the $600 to fix my front axle on my tj
(my ox locker came apart and chewed up my ring and pinion)
as far as that D35 in the zj I just want to fix it as cheap as posoble its just my wifes daily driver we bought it one week ago for $700 if it was somthing I was going to build for wheeling right now the it would get an 8.8 and I would be replacing the front axle with one of the high pinion D30's I have in my yard
the regearing it for 4.88's and run some 35's at the least
or I would put the High pinion D60 I have in the front and the 14boltin the rear and try to tuff 42's
a junkyard axle from a zj is atleast $200
I'm able to pick this tj dana35 for $120 so besides the changing the brakes and shock mounts what other mounts would need to be moved
the upper control arm mounts look like there the same would I need to move the lower control arm mounts or are the fine how about the coil bucket
mr4x4 is offline
post #9 of 13 Old 08-16-2009, 01:39 PM
JrMechanic
There's a difference between a D44 and a D44a. The D44a came on all V8 ZJ's from 96-98 and some I6's. A D44a is a direct bolt in for your Jeep.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #10 of 13 Old 08-16-2009, 02:34 PM Thread Starter
mr4x4
I know the difference
I just would rather put the normal D44 in it has a stronger housing and more locker options
but I like the 8.8 because it doesnt leak out of the drivers side axle seal like the D44 has a tendency to do
I have change axles and axle seals in my tj five times and it still leaks
I have also changed the housing twice and it still leaks
I am just trying to figure out what to look foward to on what brackets I will have to take my plasma cutter to and what ones can stay I will reuse the brackets to save the money
but with out the tj axle in front of me I cant tell what I will need to do
I would look at my tj but the rear axle has all custom brakets on it as it is
mr4x4 is offline
post #11 of 13 Old 08-16-2009, 03:28 PM
befumo
God see them everywhere. Up here its like 318-land.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #12 of 13 Old 08-16-2009, 03:47 PM Thread Starter
mr4x4
Ive seen 2 and both of them are missing the rear axle and the motor and trans along with the front clip and interior
mr4x4 is offline
post #13 of 13 Old 08-17-2009, 02:21 AM
sandman
you should hold them together to see what needs to be moved. from what i can tell the only thing that will work are the uppers, but who knows. if you have a welder it really doesnt matter, if your paying someone to weld the brackets on, i stick to my original suggestion.
1993 Jeep ZJ. 4.0
sandman is offline
Dana 44 vs Dana 44HD vs Ford 8.8 pic BradMB2004 WJ Grand Cherokee Forum 23 10-01-2011 03:42 PM
Aluminum Dana 44 vs Dana 35 phipsi74 ZJ Grand Cherokee Forum 27 07-14-2009 09:52 AM
dana 30 & dana 44A regearing to 4.10 - your recomendation please. genislav ronen ZJ Grand Cherokee Forum 12 05-14-2009 12:14 PM
Dana 35 < Dana 44 Swap! jeepinjoe123 ZJ Grand Cherokee Forum 22 12-30-2007 04:02 PM
Dana 50TTB / Dana 60 Rear Questions Wulfman ZJ Grand Cherokee Forum 2 08-26-2006 08:40 AM
