dana 30 with vacuum disconnect, what is it - JeepForum.com
post #1 of 10 Old 08-17-2013, 09:44 PM Thread Starter
93zjgrand
ok, what is vacuum disconnect on a dana 30 and what does it do and what is its purpose
93zjgrand is offline
post #2 of 10 Old 08-17-2013, 09:46 PM Thread Starter
93zjgrand
and how o tell if i had one
post #3 of 10 Old 08-17-2013, 10:13 PM
dnuccio
ZJ never had a vacuum disconnect axle.
its an actuator on the passenger side axle tube operated by vacuum. it disconnects the axle shaft from the rest of the axle. i dont know exactly what the purpose is, but i believe its supposed to act similar to manual locking hubs.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 10 Old 08-17-2013, 10:25 PM
Mickey_D
And it was only used on older generation XJ Cherokees.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #5 of 10 Old 08-18-2013, 08:06 AM
dnuccio
and didnt some YJs have it too?
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 10 Old 08-18-2013, 08:08 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
All YJ's came with it.
Luck Favours The Prepared
Anticanman is offline
post #7 of 10 Old 08-18-2013, 11:35 AM
Mickey_D
That I did not know. Huh, learn something new every day.
________________
#4
Mickey_D is offline
post #8 of 10 Old 08-18-2013, 11:39 AM
dnuccio
another reason im glad i got a ZJ
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 10 Old 08-18-2013, 11:45 AM
OverlandZJ
Some guys do like them, it's HP and the housing is stronger at the pass side upper CA mount. You also gain the option for 2wd low.
Upgrade to the cable action and HD shift fork.
However, most are the 260 ujoint
OverlandZJ is offline
post #10 of 10 Old 08-18-2013, 01:00 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The cad system isn't a big deal. Its high pinion and takes about ten minutes to turn into a solid shaft. There are a high number of xj's that have the larger ujoints but swapping shafts isn't a big deal either. I run solid shafts in my Yj disco housing and haven't had a problem until I needed a truss. I should probably upgrade to a stronger axle but mine is holding up just fine locked on 36's offroad. I also dd my jeep on 35's.
