Damaged tone ring - JeepForum.com
post #1 of 5 Old 06-28-2007, 08:16 AM Thread Starter
hatchmt
Damaged tone ring
Okay, so while I was replacing my U-joint on my passenger-side front axle, somehow I managed to destroy the ABS tone ring and the ABS sensor (the damaged tone ring made contact with it).
So -- right now, my ABS is dead and I have to deal with a naggy light on my dash. I can manage that, but I'd like to get this fixed. I've gone to several junk yards in the area, none of which have any Grand Cherokees that still have their front axles.
Here's my question -- is it possible to get just a replacement tone ring and press it on to my existing axle stub (yuk!), or do any of you know where I can get just a stub to replace the one I have?
A whole new axle shaft is expensive.
hatchmt is offline
post #2 of 5 Old 06-28-2007, 09:07 AM
zaq123
zaq123's Avatar
1941 JK Wrangler
U can pull tone rings off with a bearing puller but I would go a different route.
Get just an outer D30 shaft with ABS from ZJ/XJ/TJ and they will work. You need 5-297x joint outer shaft but as far as I know all ABS shafts have 297s u-joints. Junk yard/ ebay etc will get you one
Here is my write-up with XJ shafts. E-bay is where I found them. http://www.jeepforum.com/forum/f140/u-joint-axle-shaft-overhaul-w-upgrade-416890/
zaq123 is offline
post #3 of 5 Old 06-28-2007, 09:12 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
a brand new shaft can be bought for under $100 off ebay or napa or lees
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #4 of 5 Old 06-28-2007, 09:13 AM
zaq123
zaq123's Avatar
1941 JK Wrangler
That makes an outer shaft cost $40-50
zaq123 is offline
post #5 of 5 Old 06-28-2007, 09:18 AM
zaq123
zaq123's Avatar
1941 JK Wrangler
Here they sell new outer shafts with ABS for $150 vs. $210 for the whole axle shaft. see # 25a vs. 25
http://www.jeep4x4center.com/grand_c...eModel30ZJ.htm
zaq123 is offline
abs tone ring removal? rdrbssr11 ZJ Grand Cherokee Forum 8 05-21-2016 05:25 PM
broken abs tone ring schu98ZJ ZJ Grand Cherokee Forum 3 11-09-2008 12:23 PM
WJ Tone ring Width WJJEEPIN ZJ Grand Cherokee Forum 1 08-21-2008 10:36 PM
4.7 tone ring and swap questions itismejoshy ZJ Grand Cherokee Forum 9 12-06-2007 09:22 PM
ABS\tone ring question FearTheDentist ZJ Grand Cherokee Forum 4 10-25-2005 09:24 PM
