damaged ring tone - JeepForum.com
post #1 of 15 Old 08-13-2010, 05:30 PM Thread Starter
ZJPunk98
damaged ring tone
while rebuilding my used u-joint style axles for my dana30 i damaged my ringtone, lost a part about the size of a nickle. if i run it like this, will this mess up the ABS or possibly have bad balance issues while driving?
its not broken all the way through, just a little wedge is lost.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #2 of 15 Old 08-13-2010, 05:35 PM
JrMechanic
Tone ring, not ring tone. The only negative effect it will have is lack of ABS.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #3 of 15 Old 08-13-2010, 05:35 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
"Ringtones" are on your iPhone.
Those tone rings can be removed and replaced. If you have an old axle, tap the old ring off of it & replace the one you chipped.
I doubt you'll have balance issues, but your ABS probably won't work right.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #4 of 15 Old 08-13-2010, 05:49 PM Thread Starter
ZJPunk98
Those tone rings are replaceable? it looks fixed/one solid piece. I'llhave to look at it again.
Erik
ZJPunk98 is offline
post #5 of 15 Old 08-13-2010, 05:49 PM
Yardman Harry
O
Yardman Harry's Avatar
I had a few teeth missing from my tone rings once. never had a problem with them until i pulled the sensors and the axles out to do the seals. when i put the jeep back together and drove down the road, every stop the ABS kicked in.. it was kinda scary.
So when the sensor came to the part in the tone ring where the teeth were missing it thought that the wheel was locked so the ABS kicked in and I kept moving... I quickly replaced the tone rings and all was good...
if you have the axle out still i would replace the ring, you can use a torch and heat it up, then pop it off the axle with two pry bars... or you can use a cutting wheel on a grinder.
Yard
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #6 of 15 Old 08-13-2010, 05:58 PM
SJZ
SJZ's Avatar
Yes they are, I've done it.
Using a hammer & large punch, tap it off with alternating blows around it's circumference. No heat or grinder is needed.
-Steve
SJZ is offline
post #7 of 15 Old 08-13-2010, 06:05 PM Thread Starter
ZJPunk98
sweet! thanks guys for the infor. where did you get your replacement tone ring? Autozone, advance, or crown?
Erik
ZJPunk98 is offline
post #8 of 15 Old 08-13-2010, 06:13 PM
Yardman Harry
O
Might want to check the junkyards, or the dealer. I got mine from a shop, he had a bucket of them so he just gave it to me.
I also found this
ABS Tone Ring Dana 30 for 1999-2006 Wrangler TJ by Omix-ADA
But its for the TJ late models... and im not an expert if the 30s tone rings have changed over the years...
Hunter Green
White
~Junked~
post #9 of 15 Old 08-13-2010, 06:34 PM Thread Starter
ZJPunk98
thanks man
Erik
ZJPunk98 is offline
post #10 of 15 Old 03-29-2013, 11:25 PM
jabba974
I have the same problem...Of course while changing u-joints I broke a chunk out of both sides....Dorman products offers a replacement part number 917-540...under $15.00....I can figure out how to get them off, but do you just tap them back on? Would heating them up make it easier to install?
jabba974 is offline
post #11 of 15 Old 03-29-2013, 11:52 PM
jnicewan
Oreillys should be able to find one, at least they did around here. A tip would be to put the stub axle in a freezer or get as cold as possible then heat the ring in an oven or on stove. If done right the tone ring will almost drop right into place. If using a hammer then be very careful.
jnicewan is offline
post #12 of 15 Old 04-01-2013, 05:58 AM
moggie99
Yes
Not necessary
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2000 Nissan Patrol Y61
In the UK: 1969 MGC GT
moggie99 is offline
post #13 of 15 Old 04-01-2013, 10:33 AM
JS97ZJ
I did my brother-in laws Escape last year, $8 from the Ford dealer and taped the new one in place using the old cracked one as an installer tool.
JS97ZJ is offline
post #14 of 15 Old 04-02-2013, 04:52 PM
Foundrydude
That's a good idea.
They're not really a press fit, it's more like tapping a bearing race into a hub.
If a punch is used, stay close to the axle, don't get out on the edge.
Foundrydude is offline
post #15 of 15 Old 04-02-2013, 04:58 PM
amtcoupe
moggie99 ....are you stalking me ? , sheesh small world or what ?
tone rings , what are you crazy yanks on about ? do you mean abs reluctor rings ?
amtcoupe is offline
abs tone ring removal? rdrbssr11 ZJ Grand Cherokee Forum 8 05-21-2016 04:25 PM
broken abs tone ring schu98ZJ ZJ Grand Cherokee Forum 3 11-09-2008 11:23 AM
WJ Tone ring Width WJJEEPIN ZJ Grand Cherokee Forum 1 08-21-2008 09:36 PM
Damaged tone ring hatchmt ZJ Grand Cherokee Forum 4 06-28-2007 08:18 AM
ABS\tone ring question FearTheDentist ZJ Grand Cherokee Forum 4 10-25-2005 08:24 PM
