D44a swap into my 93 with drums... ? - JeepForum.com
post #1 of 9 Old 07-01-2009, 11:31 AM Thread Starter
aaron7
Still looking for someone parting a 97-98 V8 ZJ so I can get my D44a, but I was wondering about something.
I have a 93 with rear drum brakes. I don't have ABS (well, I do, but it's all unplugged).
Can I just install the D44a and be done? Or is there more to the rear disk conversion?
What about the e-brake?
89 MR2 MK1.5
74 CB360
83 Firebird
79 Dodge Shasta 22' RV
aaron7 is offline
post #2 of 9 Old 07-01-2009, 11:37 AM
CLNinja
CLNinja's Avatar
you need the ebrake cables that go from the axle to the bracket on the undercarriage of your jeep... the drum brake cables will not work
since your not hooking up your ABS... that is all you will need to get it to work
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #3 of 9 Old 07-01-2009, 11:43 AM Thread Starter
aaron7
So no need for a proportioning valve or anything like that?
And do I just need the cables for the e-brake or brackets and such too? I'll just order new cables if that's all I need.
89 MR2 MK1.5
74 CB360
83 Firebird
aaron7 is offline
post #4 of 9 Old 07-01-2009, 11:56 AM
CLNinja
CLNinja's Avatar
you just need the cables.. they hook into the same bracket ( thats bolted to the underbody of the ZJ ) as your D35 cables
Matt
CLNinja is offline
post #5 of 9 Old 07-01-2009, 02:56 PM
rm2001wj
rm2001wj's Avatar
Actually, what you have is a combination valve which contains a pressure differential valve and switch and a rear proportioning valve. With disc brakes, the pads are very close to the discs so they don't have to move very far to make contact. With drum brakes, the shoes are not so close to the drum so they have farther to move before contact is made. The combination valve causes the shoes to move and almost make contact with the drums before the front disc pads start to move. The idea is to not let the front brakes be applied before the rear brakes which could cause instability when braking. The rear proportioning valve, as you know, proportions fluid pressure so the the front brakes provide the correct majority portion of the braking action.
With rear disks, you won't need the rear pads to move before the front pads because the front and rear pads move the same distance. If you use the 93
combination valve with disc brakes, the rear brakes are likely to be applied before the front brakes. Also, I would expect the proportion of fluid pressure sent to the rear drums would be different than what is needed for rear discs.
Bottom line is that I think it would be best if you replaced the 93 combination valve with one from a 97-98 if at all possible.
rm2001wj is offline
post #6 of 9 Old 07-01-2009, 04:11 PM
Mickey_D
Originally Posted by rm2001wj View Post
*bunch of very important techy info*
I 100% agree. Going from drums to discs is a little more complicated than just slapping them in and making sure they're getting fluid.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #7 of 9 Old 07-01-2009, 04:30 PM Thread Starter
aaron7
That's what I thought. If I replace my combo valve with a later one I'll be OK?
Where... and what is this thing btw?
89 MR2 MK1.5
74 CB360
83 Firebird
aaron7 is offline
post #8 of 9 Old 07-01-2009, 04:45 PM
CLNinja
CLNinja's Avatar
ive been driving mine with the 93 valve for a while now and it works just fine
Matt
CLNinja is offline
post #9 of 9 Old 07-01-2009, 06:00 PM
rm2001wj
rm2001wj's Avatar
The attached pic shows what it looks like and where it's located on a 97-98. It's next to the master cylinder and brake booster. I guess it would be similar for a 93, but I can't be sure.
rm2001wj is offline
Swap D35 with D44a WhiteOut ZJ Grand Cherokee Forum 16 03-10-2010 10:34 PM
D44a swap ? bigjeep6303 ZJ Grand Cherokee Forum 5 12-19-2009 01:16 AM
d44a axle swap bigbluezj94 ZJ Grand Cherokee Forum 3 01-25-2009 04:34 PM
ZJ swap D44a brakes for a D35 BradMB2004 ZJ Grand Cherokee Forum 4 07-09-2007 06:24 PM
ZJ swap D44a brakes for a D35 BradMB2004 ZJ Grand Cherokee Forum 5 07-04-2007 05:56 PM
