d44a swap - JeepForum.com
post #1 of 12 Old 05-16-2013, 09:48 AM Thread Starter
Moparich
d44a swap
looking for a d44a to swap into my (d35)jeep.
did they come with rear disc and can i swap mine onto it and will i be able to use my drive shaft
Moparich is offline
post #2 of 12 Old 05-16-2013, 10:38 AM
WhiteOut
WhiteOut's Avatar
Only came with rear discs and 3.73 so you will need to make sure the gears match yours. You might need some driveshaft work.
WhiteOut is offline
post #3 of 12 Old 05-16-2013, 11:19 AM Thread Starter
Moparich
thanks. i was gonna switch gears. running 33's 4.10 looks pretty good
Moparich is offline
post #4 of 12 Old 05-16-2013, 11:38 AM
WhiteOut
WhiteOut's Avatar
4.56 or even 4.88 would be better with the 4.0
If you have 3.55 in the front you're going to need a new carrier anyway
WhiteOut is offline
post #5 of 12 Old 05-16-2013, 12:42 PM Thread Starter
Moparich
please enlighten me about the new carrier needed up front to run a 4.11
randy's got em but did not mention a carrier change
Moparich is offline
post #6 of 12 Old 05-16-2013, 04:16 PM
rooster51
Carrier break between 3:55 & 3:73.
Terry
rooster51 is offline
post #7 of 12 Old 05-16-2013, 06:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
definitely suggest 4.56 for 33's with a 4.0 or 4.6 equipped zj.
no carrier break on the 44a, but if you have 3.55's up front you'll need a new carrier there because of the break.
ratmonkey is offline
post #8 of 12 Old 05-16-2013, 06:29 PM
dnuccio
i wasnt aware there was even gear options out there for the 44a. learn something new every day
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 12 Old 05-16-2013, 06:43 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it came in a fair number of performance vehicles too.
they're expensive though.
post #10 of 12 Old 05-16-2013, 07:25 PM
Crasher
When you regear the 44a, be sure and have someone experienced with that axle do it or at least get all the tech info you can. They must be set up with .005-.006" back lash to avoid the dreaded gear howl. The guy that installed 488s in mine years ago, had to set the gears three times before it was acceptable. Even then it was never as quiet as the stock 373s were.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
post #11 of 12 Old 05-16-2013, 09:36 PM Thread Starter
Moparich
thanks fellas
http://www.ringpinion.com/ has many options for the d44a the trick is to find the same for the d30 upfront. maybe its because im coming from dragracing but the gear sets seem very reasonable. plus randys has always takin care of me.
@ Crasher thanks ive done quite a few gear set ups and feel comfortable with this one. if anything i usually end up being overkill on the set up. ive blown a few rear ends and left 1 on the launch pad. lol
Moparich is offline
post #12 of 12 Old 05-17-2013, 06:03 AM
KingtheZJ
http://www.jeepforum.com/forum/f13/w...-swap-1167646/
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
